Update:
First attempt failed because I failed to understand mounting properly. I am using this video by EF-Linux along with the arch installation guide as my references. The main difference is that Ermanno is using GPT with UEFI while I want to use GPT with BIOS.
I was confused whether I can run the command given in Arch Wiki - Grub
grub-install --target=i386-pc /dev/vda
after changing root to mnt
arch-chroot /mnt
without mounting the grub partition. I’m planning to see the entire video, taking notes and then attempting it again.
just to be clear. i help you so good as i can. but if your not using endeavouros and intead Mint, it makes troubleshooting a lot more harder/complicated, because the Software included in Mints repositories is already rotten away at release of the Distribrution
With virtio as gpu? and you could use keyboard an mouse?
