How do I know if the USB ports on the front on my desktop is USB 2 or USB 3?
Hi,
I have 6 USB ports mounted on my motherboard. 4 of them are black which afaik are USB 2.0 ports & the remaining 2 are blue which indicates USB 3.
There are 2 USB ports in front of the cabinet connected by a header cable which is connected to the motherboard. These 2 ports are black in color.
Since they are not mounted on my motherboard I am not sure if I should judge them by their black color.
Any command that can confirm ?
Check the motherboard manual, then check the case front panel specification.
If the motherboard has a different version than the one that is present in the front panel, the slower of the two will be the speed.
In my motherboard B550-F gaming, I have 2 x ports USB 3.2 Gen 1 pins, but my case front panel is 3.0 only, so it will work at 3.0 bandwidth.
inxi -Jazy1
If you’re not sure which of those hubs are from front panel - connect something obvious to it (usb dongle, mouse - whatever), then run this command and see under which hub your device is listed
$ inxi -Jazy1
USB:
  Hub-1: 1-0:1
    info: Hi-speed hub with single TT
    ports: 10
    rev: 2.0
    speed: 480 Mb/s
    chip-ID: 1d6b:0002
    class-ID: 0900
    Device-1: 1-3:2
      info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
      type: Bluetooth
      driver: btusb
      interfaces: 2
      rev: 2.0
      speed: 12 Mb/s
      chip-ID: 0a12:0001
      class-ID: e001
    Device-2: 1-5:3
      info: Logitech M105 Optical Mouse
      type: Mouse
      driver: hid-generic,usbhid
      interfaces: 1
      rev: 2.0
      speed: 1.5 Mb/s
      power: 100mA
      chip-ID: 046d:c077
      class-ID: 0301
    Device-3: 1-6:4
      info: Dell KB212-B Quiet Key Keyboard
      type: Keyboard
      interfaces: 1
      rev: 1.1
      speed: 1.5 Mb/s
      power: 100mA
      chip-ID: 413c:2107
      class-ID: 0301
    Device-4: 1-9:8
      info: SanDisk Cruzer Blade
      type: Mass Storage
      driver: usb-storage
      interfaces: 1
      rev: 2.1
      speed: 480 Mb/s
      power: 224mA
      chip-ID: 0781:5567
      class-ID: 0806
      serial: <filter>
    Device-5: 1-10:5
      info: Shining [hex] 2.4G Composite Devic
      type: Keyboard,Mouse
      interfaces: 2
      rev: 1.1
      speed: 12 Mb/s
      power: 100mA
      chip-ID: 2318:2808
      class-ID: 0301
  Hub-2: 2-0:1
    info: Super-speed hub
    ports: 4
    rev: 3.0
    speed: 5 Gb/s
    chip-ID: 1d6b:0003
    class-ID: 0900
SanDisk Cruzer Blade is the device that I have connected for testing.
Seems it’s Hub-1: USB 2.0 / 480 Mb/s then
Usb 3 ports are almost always blue internally.
USB
I wonder why Asus decided to make the front USB ports 2.0.
I mean they could have easily made the header female port 3.0 so that the front ports can get 3.0 speeds.
I have DELL laptop which doesn’t give a crap about blue internals, but is 3.0 :laughing:
Cost cuts probably :man_shrugging:
Also it depends on age of hardware
You know, usually to cut costs people cut peripherals, materials quality etc, stuff that’s not obvious for most people.
A USB3 cable from the case mounted USB ports will have a connector that will look like this
usb3-2
A USB2 cable from the case mounted USB ports will have a connector that will look like this
usb2
Pudge
I HATE it when some manufacturers make USB 2.0 ports blue. That triggers me almost as badly as someone using #!/bin/sh for Bash scripts…
Port-trolling
How dare they!!!
other way
sudo lsusb -vt
