Because you had config files in xorg.conf.d. Without the driver package, they will fail.
Start Welcome using a terminal
sh /usr/share/endeavouros/scripts/welcome
Post the output.
Oh I see, so I will remove intel files stored in that directory then.
You can use eos-welcome instead now.
So my display manager is sddm
@anotherusername
I just used the command which is used in the launcher. ![]()
systemctl status sddm
The output is:
● sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; vendor preset: disa>
Active: active (running) since Sun 2020-03-01 19:06:07 AEDT; 11min ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 759 (sddm)
Tasks: 8 (limit: 19037)
Memory: 137.4M
CGroup: /system.slice/sddm.service
├─759 /usr/bin/sddm
└─761 /usr/lib/Xorg -nolisten tcp -auth /var/run/sddm/{68218b77-307b-4cbd->
Mar 01 19:06:16 somepc sddm-helper[876]: pam_kwallet5(sddm:auth): (null): pam_sm_authen>
Mar 01 19:06:16 somepc sddm-helper[876]: [PAM] returning.
Mar 01 19:06:16 somepc sddm[759]: Authenticated successfully
Mar 01 19:06:16 somepc sddm-helper[876]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_>
Mar 01 19:06:16 somepc sddm-helper[876]: pam_unix(sddm:session): session opened for use>
Mar 01 19:06:16 somepc sddm-helper[876]: pam_kwallet5(sddm:session): pam_kwallet5: pam_>
Mar 01 19:06:16 somepc sddm-helper[876]: Starting: "/usr/share/sddm/scripts/Xsession \">
Mar 01 19:06:16 somepc sddm[759]: Auth: sddm-helper exited successfully
Mar 01 19:06:16 somepc sddm[759]: Greeter stopped.
Mar 01 19:06:16 somepc sddm[759]: Session started
Launch the welcome app from the terminal. It’ll let you know what might be the problem.
As @anotherusername jumped in, I’m out for now.
So I typed eos-welcome in terminal and it only launched the Welcome launcher
I pressed Detect system issues and it removed these packages dkms-2.8.1-1 nvidia-installer-db-2.1-5 broadcom-wl-dkms-6.30.223.271-20 nvidia-installer-dkms-3-2 xf86-video-amdgpu-19.1.0-1 xf86-video-ati-1:19.1.0-1
That’s exactly the reason why I asked if you have any non intel stuff installed. The output of intel_gpu_top showed there was some Nvidia and AMD stuff involved.
I never installed it though, sorry for the hassle.
No hassle at all. But some possible causes for problems removed.
But now I’m really out. Will be back later.
I see.
Thanks mate ![]()
Just a question if anybody knows, is Chromium based on electron? I think Electron is what is not working properly on my PC since even Atom is also laggy.
It’s the other way around. Electron uses Chromium’s rendering library and JavaScript engine
Ah I see, so its not electron it is chromium that is causing huge problems, even in Atom it is the same thing.
So I managed to remove xf86-video-intel without any issues this time round. Still laggy but yeah.
Well, you can try to look through the Chromium’s bugtracker for the similar issues related to Blink.
https://bugs.chromium.org/p/chromium/issues/list?q=component%3ABlink&can=2
But honestly after so many posts I lost track of what the actual problem is exactly. Does it work ok with other rendering engines?
