I have edited the three files but like in the third file, the guy who made the video had an error, he says to type Driver "intel" But as you can see in the vim editor he types Driver "Intel" (the first letter of the word Intel was capitalised) so the confusion is do I type intel or Intel? And yes I have tested it after a reboot and I guess it is smoother but like still a bit choppy.
Okay if you are adding the third file for testing for Intel thatās fine. But iām only looking at the first part of the video that has to do with modesettiing. They have two config files. The other one is for if you are going to install the Intel driver. Itās fine that you set it up if you are going to test one or the other. There is also the modprobe file to set for the intel drivers. So there are two to set up for modesetting and two you have to deal with and set for Intel. There are only two options either modesetting or Intel. My understanding reading is that modesetting should be better but youāll have to judge that. I donāt have Intel and from all the dealings that i have had and seen with the i915 Intel if i were to get a laptop it would not have Intel graphics or hybrid graphics. I would only go for dedicated graphics. I donāt care how much power it uses. I care about how it works.
Chromium-based browsers are all unnecessarily taking up too much CPU processing power. I pressed shift+esc on both Windows and Linux within the browsers and I found that Brave was taking up way too much CPU processing power compared to Windows. So I compared two websites Benchmark Your Graphics Card On Linux and WhatsApp Web
CPU use for Brave for Windows
Idle: 1-4
Scrolling: 30-40
WhatsApp Web
Idle: 0
Scrolling: 30-60
GPU Process (for Benchmark Your Graphics Card On Linux website)
Idle: 0-3
Scrolling: 18-48
CPU use for Brave for EndeavourOS
Idle: 17
Scrolling: 140-160
WhatsApp Web
Idle: 0
Scrolling: 153
Idle: 2-5
Scrolling: 110
So I am not too sure why on Linux Chromium-based browsers are taking up more CPU processing power compared to Windows, if anyone knows what is going on I would love to know. Thanks
Ok so as mentioned above, the problem is that the chromium-based browsers are taking up way to much processing power compared to on Windows. That is what is possibly causing so much lag. I donāt know why on Linux does it take up so much more processing power. Generally speaking using other softwares such as Blender on Linux performs better than on Windows, I end up with more fps on Linux.
Have you tried any differente distribution? Like Ubuntu? Theyāre packed distributions. If the browser in question perform better on those distributions, weāll know that weāre missing some piece of package.
I have tried Xubuntu, pretty much the same issue, I donāt believe EndeavourOS or any distros are the culprit for this lag, the drivers work fantastic on my laptop. its chromium that is just taking up way too much excessive processing power.
Why use a a Chromium based browser then? Just use Firefox ā¦my favorite bar none! Did you try PopOS? I am not a Ubuntu fan but out of all Ubuntu based distroās PopOS would be my choice. Why? Because i believe in what System76 is doing with open source hardware and core boot.
The problem is itās the hardware. Not all things can be fixed with settings and software. It is what it is unless you replace it with something that works. Or you can use Windows. I will never use Facebook either.
I just tested the website you claim to be laggy. Indeed it is displayed smoother when using Firefox. But I think itās not a browser problem. I think the website is quite crappy and performs better when using Firefox. I too have an Intel chipset integrated in the computer Iām writing on right now. Here is some technical info :
Iām using Chromium on that machine and it meets my needs for daily needs and work.
You will not get a better performance, no matter what parameters, kernel settings or whatever you might change. Disabling modesetting would be the worst thing to do. That would completely cut the high level communication between kernel and GPU. This would end up in a bad display resolution and the system could no longer take advantage of speed optimzing features of your graphic card.
Edit : That little machine allows even to watch smooth full HD video in chromium.
Edit 2 : Iām also running KDE on that computer (alongside some other DEs).
I did a quick research how browser performance can be improved. Maybe profile-sync-daemon does the job for you.
profile-sync-daemon (psd) is a tiny pseudo-daemon designed to manage browser profile(s) in tmpfs and to periodically sync back to the physical disc (HDD/SSD). This is accomplished by an innovative use of rsync to maintain synchronization between a tmpfs copy and media-bound backup of the browser profile(s). Additionally, psd features several crash recovery features.
Since the profile(s), browser cache*, etc. are relocated into tmpfs (RAM disk), the corresponding I/O associated with using the browser is also redirected from the physical drive to RAM, thus reducing wear to the physical drive and also greatly improving browser speed and responsiveness.
It can easily be installed via package management (Community).
For me I donāt like firefox because it is laggy on both Windows and Linux when using web applications such as WhatsApp Web. Chromium-based on Windows feels very smooth.
Nah but I donāt think I want to use Debian based distros as my daily driver. I hate apt over pacman.
That particular website is indeed crap, but on Windows using chromium it takes up far less processing power. When I scroll on any website the browser takes an insane amount of CPU on Linux compared to Windows.
Ok I wonāt do that and I have not done it yet.
Thanks I will take a look at it and see what comes up.
You seem to have a lot of lag issues. I find it very strange. I donāt believe it is browser problems. There are lots of other users on Intel graphics that do not have any issue with Firefox or Chromium based browsers. You keep referring to no problem on Windows. Why are you using Linux then if it is not working for you? You should just use Windows then the problem solved.
I donāt get it either, I want to use Linux cause honestly it is much easier to use over Windows, there is no preinstalled spyware, its so much more powerful, and also it actually performs better with everything else. Remember the benchmarks that I have done, and even using Blender works much nicer than on Windows (I often use Blender). Also with Windows using languages such as Rust do not work correctly whereas on Linux it works properly. Its just chromium that takes up way too much CPU. I am sure on Windows it would be laggier if it took up the same amount of CPU.
Have you tried the vaapi enable chromium browsers from the AUR?
chrome://flags
Hardware-accelerated video decode (set to enable)
h264ify extension for Chromium browser (This is an extension for Chromium)
Edit: The chrome flags is unavailable on my platform
To enable hardware acceleration in Chromium (GPU accelerated video decoding) youāll need to use Chromium with a VAAPI patch. Not sure any of this will work but you can try it if you like.
You may be able to set the flag here but not sure whether it works on your currently installed Chromium browser.
