I am using EOS on my Thinkpad T480s.
There is a built in Nvidia MX150 GPU in that system.
A few days ago i switched to 4k Displays. The Performance is sluggish. If I play any 4k Video on Youtube all 8 CPU cores are nearby 100% (using Vivaldi). Using Firefox the Performance is much better, but that anywhere I would like it to be.
So, i thought that the solution is using the internal MX150 GPU. At the moment I am using the Intel GPU.
How can I activate the nvidia card without crashing my system?
This will not help you, but I have always had problems with 4k and YouTube on Linux. No matter what distro or computer I had. Think hardware acceleration is not good yet. CPU has to work hard.
thank you for you responding and sorry for my delayed answer.
The main Question for me is:
I am currently running on Intel GPU. If i Use the nvidia installer, will I be able to use it effective immediately or do i have to go through some blank screens after rebooting?
in most cases it will boot up on intel after installing Nvidia drivers, depending if you nvidia chip is supported by latest Nvidia driver or it is such legacy chip.
