Lutris says that vulkan is not supported, i have the recommended packages installed and the nvidia driver…please help
Does you NVIDIA GPU even support Vulkan? If it an RTX, definitely. On GTX cards, as low as the GTX 1080 should work.
Its an gtx 960, supports vulkan normally on other distros…
What Vulkan game are you trying to play?
I dont tried to play yet, but i dont have vulkan support and i will need it, dolphin dont work too, says failed to create vulkan instance…
I have the packages recommended by lutris team on the graphics driver page, followed the arch based distro guide but no success, lutris still says that vulkan is not supported, its the first time i have this kind of error, vulkan works very well on rebornos, ubuntu, mint and solus…
Welcome
Yep, your GPU supports vulkan (at least on proprietary drivers it should)
Please follow requirements in this guide
Linux gaming [Tutorial]
Thanks man, but i already followed this guide, i have the proprietary drivers and vulkan installed, but i have the same error…
Well, following the same guide again fixed the problem…thx
