I started using hyprland 3/4 months ago. It worked fine until recently.
A while ago, like 4 weeks ago, I started experiencing some OS freezes.
I couldn’t find any patterns or programs to blame for this behavior. I’m not sure if it’s a resource issue, a specific software or maybe hardware.
I’m suspicious of vscode or chromium => Electron?
What I tried
I switched to KDE (Wayland) thinking it was a hyprland issue, but I still got freezes.
I switched to KDE (X11) and it’s still happening.
I increased the swap memory from 8 to 16 GB, but according to btop the swap memory is hardly used
With the Ryzen 2500 you may need to try some kernel parameters such as
idle=nomwait
Not sure if you are using grub or systemd-boot because it’s different to add them. This is just one that I’m guessing at trying. There are others but need to think which ones would be likely candidates.
Hopefully it works for you. If you still have issues try adding the other one along with it with the same procedure over again. These are the only two that i can think of that may help.
I have the same problem with the same laptop, but with another processor, which is the Ryzen 3 2200u.
The problem appeared only a few days ago, after updating to Mesa 24.3.1 or kernel 6.12.4.
By the way, I am on pure Arch with KDE Plasma
