After updating today, I’ve just started getting an error in timeshift where it says it’s in “Live USB Mode (Restore Only)”. All previous snapshots are missing & an error message is listed which states "Device not found: UUID=’[my-hexadecimal-device-id]’. This is now also interfering with pacman updates as I now get the following error.
:: Running pre-transaction hooks...
(1/1) Creating Timeshift snapshot before upgrade...
E: ts: Failed to get partition list.
E: System disk not found!
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: command failed to execute correctly
error: failed to commit transaction (failed to run transaction hooks)
Most recently updated pacman packages:
[2021-06-04T09:50:21+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.28-1 -> 1:0.3.29-1)
[2021-06-04T09:50:21+0100] [ALPM] upgraded util-linux-libs (2.36.2-1 -> 2.37-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded ca-certificates-utils (20181109-4 -> 20210529-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded ca-certificates (20181109-4 -> 20210529-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded js78 (78.10.1-1 -> 78.11.0-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded util-linux (2.36.2-1 -> 2.37-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded polkit (0.118-1 -> 0.119-1)
[2021-06-04T09:50:22+0100] [ALPM] installed libcolord (1.4.5-3)
[2021-06-04T09:50:22+0100] [ALPM] upgraded colord (1.4.5-1 -> 1.4.5-3)
[2021-06-04T09:50:22+0100] [ALPM] upgraded poppler (21.05.0-1 -> 21.06.1-1)
[2021-06-04T09:50:22+0100] [ALPM] upgraded gdal (3.2.3-2 -> 3.2.3-3)
[2021-06-04T09:50:22+0100] [ALPM] upgraded gtk-update-icon-cache (1:4.2.1-1 -> 1:4.2.1-2)
[2021-06-04T09:50:22+0100] [ALPM] upgraded libinput (1.17.3-1 -> 1.18.0-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded gtk3 (1:3.24.29-1 -> 1:3.24.29-2)
[2021-06-04T09:50:23+0100] [ALPM] upgraded poppler-glib (21.05.0-1 -> 21.06.1-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded inkscape (1.1-2 -> 1.1-3)
[2021-06-04T09:50:23+0100] [ALPM] upgraded ipython (7.24.0-1 -> 7.24.1-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded webrtc-audio-processing (0.3.1-2 -> 0.3.1-3)
[2021-06-04T09:50:23+0100] [ALPM] upgraded pipewire (1:0.3.28-1 -> 1:0.3.29-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded lib32-pipewire (1:0.3.28-1 -> 1:0.3.29-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded lib32-util-linux (2.36.2-1 -> 2.37-1)
[2021-06-04T09:50:23+0100] [ALPM] upgraded libmbim (1.24.6-1 -> 1.24.8-1)
[2021-06-04T09:50:25+0100] [ALPM] upgraded libreoffice-fresh (7.1.3-1 -> 7.1.3-2)
[2021-06-04T09:50:25+0100] [ALPM] upgraded openexr (3.0.3-1 -> 3.0.4-1)
[2021-06-04T09:50:25+0100] [ALPM] upgraded libvips (8.10.6-4 -> 8.10.6-5)
[2021-06-04T09:50:26+0100] [ALPM] upgraded linux-lts (5.10.41-1 -> 5.10.42-1)
[2021-06-04T09:50:28+0100] [ALPM] upgraded linux-lts-headers (5.10.41-1 -> 5.10.42-1)
[2021-06-04T09:50:29+0100] [ALPM] upgraded linux-zen (5.12.8.zen1-1 -> 5.12.9.zen1-1)
[2021-06-04T09:50:31+0100] [ALPM] upgraded linux-zen-headers (5.12.8.zen1-1 -> 5.12.9.zen1-1)
[2021-06-04T09:50:31+0100] [ALPM] upgraded nodejs (16.2.0-1 -> 16.3.0-1)
[2021-06-04T09:50:31+0100] [ALPM] upgraded pacman-contrib (1.4.0-2 -> 1.4.0-3)
[2021-06-04T09:50:31+0100] [ALPM] upgraded poppler-qt5 (21.05.0-1 -> 21.06.1-1)
[2021-06-04T09:50:32+0100] [ALPM] upgraded qt5-webengine (5.15.3-5 -> 5.15.4-3)
[2021-06-04T09:50:32+0100] [ALPM] upgraded recode (3.7.8-1 -> 3.7.9-1)
inxi -Fazy output:
Kernel: 5.12.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=f4a38316-ac59-4e5c-a8b1-8eaf4671e28f rw rootflags=subvol=@ quiet
loglevel=3 nowatchdog mitigations=off
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Intel Client Systems product: NUC8i7HVK v: J71485-504
serial: <filter> Chassis: Intel Corporation type: 3 v: 2.0 serial: <filter>
Mobo: Intel model: NUC8i7HVB v: J68196-504 serial: <filter> UEFI: Intel
v: HNKBLi70.86A.0064.2020.1028.1438 date: 10/28/2020
Battery:
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Info: Quad Core model: Intel Core i7-8809G bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 49599
Speed: 3114 MHz min/max: 800/8300 MHz Core speeds (MHz): 1: 3114 2: 2218
3: 1915 4: 1500 5: 2440 6: 3071 7: 3354 8: 2996
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0380
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:694c class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati,intel unloaded: fbdev,modesetting,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DisplayPort-3 res: 1920x1080 hz: 60 dpi: 93
OpenGL: renderer: AMD VEGAM (DRM 3.40.0 5.12.9-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.1.1 direct render: Yes
Device-1: Intel CM238 HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: AMD Polaris 22 HDMI Audio vendor: Intel driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 1002:ab08 class-ID: 0403
Device-3: Logitech Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 6-1:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.9-zen1-1-zen running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.29 running: no
Device-1: Intel Ethernet I219-LM driver: e1000e v: kernel port: f040
bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel I210 Gigabit Network driver: igb v: kernel port: b000
bus-ID: 05:00.0 chip-ID: 8086:157b class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: b000
bus-ID: 06:00.0 chip-ID: 8086:24fd class-ID: 0280
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 8087:0a2b class-ID: e001
Report: This feature requires one of these tools: hciconfig/bt-adapter
Local Storage: total: 1.86 TiB used: 602.21 GiB (31.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXP7 scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 rotation: SSD serial: <filter> rev: SS0411B scheme: GPT
ID-1: / raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
used: 224.41 GiB (23.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 560 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 29.8 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 70.0 C mobo: 29.8 C gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A
Processes: 277 Uptime: 12m wakeups: 17 Memory: 31.27 GiB
used: 2.65 GiB (8.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10/9 clang: 11.1.0 Packages: pacman: 1655 lib: 444
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.03
I am lazy, I had mine installed from archlinuxcn
