Up until about 1–2 weeks ago everything was working fine on my system. Since then, I’ve been unable to launch any Steam games that require Proton. I’ve tried a few things, but I can’t work out what the problem is:
- Tried other games requiring Proton:
- Ticket to Ride (Fails).
- Pandemic: The Board Game (Fails).
- Switched versions of Proton (Properties > Compatibility > Force the use of a specific Steam Play compatibility tool):
- Proton Experimental
- Proton 6.3-7
- Proton 5.13-6
- Verified the integrity of the aforementioned versions of proton (Properties > Local files > Verify integrity of tool files…).
- Uninstalled, then reinstalled Steam:
- Ran
sudo pacman -Rns steamin the terminal. - Deleted the
~/.steam/,~/.local/share/Steam/directories. - Deleted the
~/.steampath&~/.steampidsymlinks. - Ran
sudo pacman -Syu steamin the terminal.
- Ran
- Switched Steam launch options (Properties > General > Launch options):
PROTON_USE_WINED3D=1 %command%PROTON_NO_D3D11=1 %command% -force-d3d9
If I append the PROTON_LOG=1 launch option, I get the following output log:
Steam Log
Proton: 1633030452 proton-6.3-7
SteamGameId: 108200
Command: ['/home/benjamin/.local/share/Steam/steamapps/common/Ticket to Ride/Ticket to Ride.exe', 'steam', '-force-d3d9']
Options: {'forcelgadd', 'nod3d11'}
depot: 0.20210923.28
pressure-vessel: 0.20210906.2
scripts: v0.20210917.0-0-g1cf127d
soldier: 0.20210920.0 soldier 0.20210920.0
fsync: up and running.
wine: Using setpriority to control niceness in the [-10,10] range
3591.837:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wineboot.exe" at 0000000140000000: builtin
3591.837:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3591.838:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3591.838:0028:002c:trace:seh:install_bpf Installing seccomp filters.
3591.838:0028:002c:trace:seh:check_bpf_jit_enable enabled 0x31.
3591.839:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3591.839:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3591.839:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3591.839:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ws2_32.dll" at 00007FB1F9480000: builtin
3591.858:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\services.exe" at 0000000140000000: builtin
3591.859:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3591.859:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3591.859:0030:0034:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3591.859:0030:0034:trace:seh:install_bpf Seccomp filters already installed.
3591.860:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3591.860:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3591.860:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3591.861:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3591.861:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3591.861:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3591.862:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\userenv.dll" at 0000000388E20000: builtin
3591.883:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 0000000140000000: builtin
3591.883:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3591.884:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3591.884:003c:0040:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3591.884:003c:0040:trace:seh:install_bpf Seccomp filters already installed.
3591.885:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3591.885:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3591.885:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3591.886:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 00000001C8DB0000: builtin
3591.886:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 00000002279A0000: builtin
3591.890:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3591.893:003c:0050:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0x162f870,30,(nil))
3591.895:003c:004c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\mountmgr.sys" at 00007FEE86450000: builtin
3591.898:003c:004c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3591.898:003c:004c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3591.901:003c:004c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\iphlpapi.dll" at 00007FEE86090000: builtin
3591.901:003c:004c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\ndis.sys" at 00000001DC4B0000: builtin
3591.916:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\plugplay.exe" at 0000000140000000: builtin
3591.917:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3591.917:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3591.917:005c:0060:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3591.917:005c:0060:trace:seh:install_bpf Seccomp filters already installed.
3591.918:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3591.918:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3591.918:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3591.918:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3591.919:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 000000026B4C0000: builtin
3591.919:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3591.919:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3591.919:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 000000023D820000: builtin
3592.103:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 0000000327020000: builtin
3592.103:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00000002E8F10000: builtin
3592.103:005c:0060:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 00000003AFD00000: builtin
3592.120:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 0000000140000000: builtin
3592.120:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3592.121:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3592.121:0074:0078:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3592.121:0074:0078:trace:seh:install_bpf Seccomp filters already installed.
3592.122:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3592.122:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3592.122:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3592.123:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 00000001C8DB0000: builtin
3592.123:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 00000002279A0000: builtin
3592.127:0074:0078:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.130:0074:0084:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0x162f870,30,(nil))
3592.132:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winebus.sys" at 00007F5C8ED70000: builtin
3592.133:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3592.133:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3592.134:0074:0080:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0x101f180,30,(nil))
3592.137:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hidclass.sys" at 000000031DF10000: builtin
3592.137:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winehid.sys" at 00000003BA2A0000: builtin
3592.138:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hid.dll" at 00000001F51E0000: builtin
3592.139:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 000000026B4C0000: builtin
3592.139:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 000000023D820000: builtin
3592.172:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 0000000327020000: builtin
3592.172:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00000002E8F10000: builtin
3592.172:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 00000003AFD00000: builtin
3592.173:0074:008c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0x1c5f960,30,(nil))
3592.197:0074:0080:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\wineusb.sys" at 00007F5C8CFC0000: builtin
3592.217:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\svchost.exe" at 0000000140000000: builtin
3592.218:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3592.218:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3592.218:00a4:00a8:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3592.218:00a4:00a8:trace:seh:install_bpf Seccomp filters already installed.
3592.219:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3592.219:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3592.219:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3592.223:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wevtsvc.dll" at 00000002EBA70000: builtin
3592.224:00a4:00a8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.227:003c:0050:trace:seh:NtQueryInformationThread (0x64,0,0x162f810,30,(nil))
3592.228:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 000000026B4C0000: builtin
3592.229:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.229:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 000000023D820000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 0000000327020000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00000002E8F10000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 00000003126F0000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 00000002E3540000: builtin
3592.230:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007FB1F8840000: builtin
3592.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 00000003AFD00000: builtin
3592.264:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\steam.exe" at 7E8E0000: builtin
3592.265:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
3592.265:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
3592.266:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
3592.267:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
3592.267:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
3592.267:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
3592.267:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 62FC0000: builtin
3592.268:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
3592.268:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
3592.268:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
3592.268:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 68500000: builtin
3592.268:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 6A400000: builtin
3592.269:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 63BC0000: builtin
3592.269:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 64A40000: builtin
3592.269:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 7DE00000: builtin
3592.458:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
3592.463:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\explorer.exe" at 0000000140000000: builtin
3592.463:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3592.464:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3592.464:00bc:00c0:trace:seh:install_bpf Installing seccomp filters.
3592.464:00bc:00c0:trace:seh:check_bpf_jit_enable enabled 0x31.
3592.465:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3592.465:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3592.465:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3592.466:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 000000026B4C0000: builtin
3592.466:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.466:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3592.467:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3592.467:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 000000023D820000: builtin
Setting breakpad minidump AppID = 108200
Steam_SetMinidumpSteamID: Caching Steam ID: 76561197972327665 [API loaded no]
3592.503:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 0000000327020000: builtin
3592.503:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00000002E8F10000: builtin
3592.503:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 00000003AFD00000: builtin
3592.506:0020:00c4:err:steam:initialize_vr_data Could not load libopenvr_api.so.
3592.506:0020:00c4:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x122ff1c,4,(nil))
3592.507:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 00007F0D309E0000: builtin
3592.560:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 00000003126F0000: builtin
3592.560:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 00000002E3540000: builtin
3592.560:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007F0D2F2B0000: builtin
3592.563:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 00000002739C0000: builtin
3592.563:00bc:00c0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\actxprxy.dll" at 00000001D0830000: builtin
3592.563:00bc:00c0:trace:seh:dispatch_exception code=6ba flags=0 addr=000000007B01236E ip=000000007B01236E tid=00c0
3592.563:00bc:00c0:warn:seh:dispatch_exception unknown exception (code=6ba) raised
3592.563:00bc:00c0:trace:seh:dispatch_exception rax=000000007b012320 rbx=000000000073e9d8 rcx=000000000073e6f0 rdx=0000000000000000
3592.563:00bc:00c0:trace:seh:dispatch_exception rsi=000000000000006c rdi=0000000000269970 rbp=0000000040010028 rsp=000000000073e6d0
3592.563:00bc:00c0:trace:seh:dispatch_exception r8=0000000000000000 r9=0000000000000000 r10=0000000000260020 r11=00000000a55a5aa5
3592.563:00bc:00c0:trace:seh:dispatch_exception r12=000000000073e9d8 r13=0000000000286360 r14=000000000016f950 r15=0000000000000005
3592.563:00bc:00c0:trace:seh:call_vectored_handlers calling handler at 000000007B00C660 code=6ba flags=0
3592.563:00bc:00c0:trace:seh:call_vectored_handlers handler at 000000007B00C660 returned 0
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 1 rip 000000007B01236E rsp 000000000073E6D0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 12320-123a7
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007B0A5480 flags 0 prolog 0x11 bytes function 000000007B012320-000000007B0123A7
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xa: pushq %rsi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x9: pushq %rdi
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 1 rip 0000000231B22812 rsp 000000000073E7B0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 42800-42847
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 0000000231B453C0 flags 0 prolog 0x4 bytes function 0000000231B22800-0000000231B22847
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 1 rip 0000000231AE9736 rsp 000000000073E7E0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 96b0-9737
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 0000000231B4332C flags 0 prolog 0x7 bytes function 0000000231AE96B0-0000000231AE9737
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x7: subq $0x40,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x3: pushq %rbx
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x2: pushq %rsi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x1: pushq %rdi
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 1 rip 0000000327044BF0 rsp 000000000073E840
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 24af0-24d51
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000032705A67C flags 0 prolog 0x10 bytes function 0000000327044AF0-0000000327044D51
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x10: subq $0x338,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x9: pushq %rbx
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x8: pushq %rsi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x7: pushq %rdi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x6: pushq %r12
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x4: pushq %r13
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x2: pushq %r14
3592.563:00bc:00c0:trace:seh:call_stack_handlers found wine frame 000000000073E8B0 rsp 000000000073EBB0 handler 0000000327043B30
3592.563:00bc:00c0:trace:seh:call_teb_handler calling TEB handler 0000000327043B30 (rec=000000000073E6F0, frame=000000000073E8B0 context=000000000073DC10, dispatch=000000000073DAE0)
3592.563:00bc:00c0:trace:seh:call_teb_handler handler at 0000000327043B30 returned 1
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 1 rip 00000003270397B7 rsp 000000000073EBB0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 196d0-197dd
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 0000000327059EB0 flags 0 prolog 0xa bytes function 00000003270396D0-00000003270397DD
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xa: subq $0x178,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x2: pushq %r12
3592.563:00bc:00c0:trace:seh:call_stack_handlers found wine frame 000000000073EBF0 rsp 000000000073ED40 handler 0000000327045FB0
3592.563:00bc:00c0:trace:seh:call_teb_handler calling TEB handler 0000000327045FB0 (rec=000000000073E6F0, frame=000000000073EBF0 context=000000000073DC10, dispatch=000000000073DAE0)
3592.563:00bc:00c0:trace:seh:RtlUnwindEx code=6ba flags=2 end_frame=000000000073EBF0 target_ip=0000000327045F4A rip=000000007bc5ac82
3592.563:00bc:00c0:trace:seh:RtlUnwindEx rax=000000003ffe0000 rbx=000000000073e8b0 rcx=000000000073d4e0 rdx=0000000027045f4a
3592.563:00bc:00c0:trace:seh:RtlUnwindEx rsi=000000000073e1f0 rdi=000000000073dc10 rbp=000000000073cf90 rsp=000000000073ce10
3592.563:00bc:00c0:trace:seh:RtlUnwindEx r8=000000000073e6f0 r9=0000000027045f80 r10=000000000073d6d6 r11=0000000000000293
3592.563:00bc:00c0:trace:seh:RtlUnwindEx r12=000000000073e6f0 r13=000000000073d4e0 r14=000000000073ebf0 r15=000000000073e6f0
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5AC82 rsp 000000000073CE10
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 5ac30-5b53e
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007BC8398C flags 0 prolog 0x13 bytes function 000000007BC5AC30-000000007BC5B53E
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x13: subq $0x658,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xc: pushq %rbx
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xb: pushq %rsi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xa: pushq %rdi
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x9: pushq %rbp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x8: pushq %r12
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x6: pushq %r13
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x4: pushq %r14
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x2: pushq %r15
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5B55F rsp 000000000073D4B0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 5b540-5b568
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007BC839A4 flags 0 prolog 0x7 bytes function 000000007BC5B540-000000007BC5B568
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x7: subq $0x508,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000327045F4A rsp 000000000073D9C0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 25f30-25f4c
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000032705A754 flags 0 prolog 0x8 bytes function 0000000327045F30-0000000327045F4C
3592.563:00bc:00c0:trace:seh:dump_unwind_info frame register rbp offset 0x0(%rsp)
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x8: subq $0x20,%rsp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x4: leaq 0x0(%rsp),rbp
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x1: pushq %rbp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000327045F79 rsp 000000000073D9F0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 25f50-25f7a
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000032705A760 flags 0 prolog 0x4 bytes function 0000000327045F50-0000000327045F7A
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000327046004 rsp 000000000073DA20
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 25fb0-26005
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000032705A770 flags 0 prolog 0xa bytes function 0000000327045FB0-0000000327046005
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0xa: subq $0x30,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A1BF rsp 000000000073DA70
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 59ee0-5a431
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007BC83948 flags 0 prolog 0x13 bytes function 000000007BC59EE0-000000007BC5A431
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x13: subq $0x678,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A747 rsp 000000000073E130
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 5a440-5a94f
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007BC83960 flags 0 prolog 0x10 bytes function 000000007BC5A440-000000007BC5A94F
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x10: subq $0x58,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC583C4 rsp 000000000073E1D0
3592.563:00bc:00c0:trace:seh:dump_unwind_info **** func 5835c-583d1
3592.563:00bc:00c0:trace:seh:dump_unwind_info unwind info at 000000007BC838B0 flags 0 prolog 0x7 bytes function 000000007BC5835C-000000007BC583D1
3592.563:00bc:00c0:trace:seh:dump_unwind_info 0x7: subq $0x4f8,%rsp
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 000000007B01236E rsp 000000000073E6D0
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000231B22812 rsp 000000000073E7B0
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000231AE9736 rsp 000000000073E7E0
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 0000000327044BF0 rsp 000000000073E840
3592.563:00bc:00c0:trace:seh:RtlUnwindEx found builtin frame 000000000073E8B0 handler 0000000327043B30
3592.563:00bc:00c0:trace:seh:call_teb_unwind_handler calling TEB handler 0000000327043B30 (rec=000000000073E6F0, frame=000000000073E8B0 context=000000000073D4E0, dispatch=000000000073CEA0)
3592.563:00bc:00c0:trace:seh:call_teb_unwind_handler handler at 0000000327043B30 returned 1
3592.563:00bc:00c0:trace:seh:RtlVirtualUnwind type 2 rip 00000003270397B7 rsp 000000000073EBB0
3592.563:00bc:00c0:trace:seh:RtlRestoreContext returning to 0000000327045F4A stack 000000000073EBB0
3592.577:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\explorer.exe" at 0000000140000000: builtin
3592.578:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3592.578:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3592.578:00dc:00e0:trace:seh:install_bpf Installing seccomp filters.
3592.578:00dc:00e0:trace:seh:check_bpf_jit_enable enabled 0x31.
3592.579:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3592.579:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3592.579:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3592.579:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcss.exe" at 0000000140000000: builtin
3592.579:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 000000026B4C0000: builtin
3592.580:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.580:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
3592.580:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B600000: builtin
3592.580:00d4:00d8:trace:seh:sigsys_handler SIGSYS, rax 0xffff, rip 0x600000000005.
3592.580:00d4:00d8:trace:seh:install_bpf Seccomp filters already installed.
3592.580:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 00000002F1FA0000: builtin
3592.580:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000021A7E0000: builtin
3592.580:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 000000023D820000: builtin
3592.581:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00000003AF670000: builtin
3592.581:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 000000032A700000: builtin
3592.581:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 0000000330260000: builtin
3592.581:00d4:00d8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 0000000231AE0000: builtin
3592.589:0030:00d0:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x3e7fe2c,4,(nil))
3592.591:0020:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at F5F60000: builtin
3592.620:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 0000000327020000: builtin
3592.620:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 00000002E8F10000: builtin
3592.620:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 00000003AFD00000: builtin
3592.624:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 00007F6E7C550000: builtin
3592.643:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 00000003126F0000: builtin
3592.643:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 00000002E3540000: builtin
3592.643:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007F6E7AEE0000: builtin
3592.647:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 00000002739C0000: builtin
3592.647:00dc:00e0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\actxprxy.dll" at 00000001D0830000: builtin
3592.648:00d4:0108:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x325fe2c,4,(nil))
3592.667:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\Ticket to Ride.exe" at 00400000: native
3592.668:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
3592.668:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
3592.670:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
3592.670:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
3592.670:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
3592.671:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 6C9C0000: builtin
3592.671:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 62FC0000: builtin
3592.672:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 63480000: builtin
3592.672:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6BCC0000: builtin
3592.672:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 6ED00000: builtin
3592.672:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\combase.dll" at 68500000: builtin
3592.672:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 6A400000: builtin
3592.673:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 64EC0000: builtin
3592.673:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\propsys.dll" at 69940000: builtin
3592.674:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 63BC0000: builtin
3592.674:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 64A40000: builtin
3592.674:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WindowsCodecs.dll" at 62D40000: builtin
3592.675:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\IPHLPAPI.DLL" at 7E960000: builtin
3592.679:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\SHELL32.dll" at 7DF80000: builtin
3592.682:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\icudt46.dll" at 4AD00000: native
3592.684:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSVCR120.dll" at 01BE0000: native
3592.684:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSVCP120.dll" at 00130000: native
3592.685:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\libicuuc.dll" at 4A800000: native
3592.686:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WS2_32.dll" at 7DF20000: builtin
3592.687:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\libicuin.dll" at 4A900000: native
3592.687:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\pthreadVC2.dll" at 001F0000: native
3592.687:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\CFLite.dll" at 01CD0000: native
3592.688:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msacm32.dll" at 6A040000: builtin
3592.688:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WINMM.dll" at 01DB0000: builtin
3592.689:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\WTF.dll" at 001B0000: native
3592.690:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\JavaScriptCore.dll" at 01E70000: native
3592.692:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\SQLite3.dll" at 022F0000: native
3592.693:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\bcrypt.dll" at 66240000: builtin
3592.693:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\CRYPT32.dll" at 6E8C0000: builtin
3592.693:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\zlib1.dll" at 02380000: native
3592.694:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WSOCK32.dll" at 69180000: builtin
3592.695:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\LIBEAY32.dll" at 023A0000: native
3592.695:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\SSLEAY32.dll" at 02510000: native
3592.696:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WLDAP32.dll" at 7DEB0000: builtin
3592.696:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\libcurl.dll" at 02560000: native
3592.698:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSIMG32.dll" at 70E80000: builtin
3592.699:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\OPENGL32.dll" at 7A840000: builtin
3592.699:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\cairo.dll" at 025B0000: native
3592.700:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 71200000: builtin
3592.700:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\comctl32.dll" at 6CC40000: builtin
3592.700:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winspool.drv" at 7DE70000: builtin
3592.700:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\COMDLG32.dll" at 70D00000: builtin
3592.702:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\libxml2.dll" at 02710000: native
3592.702:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\libxslt.dll" at 026E0000: native
3592.702:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\WebKit.dll" at 10000000: native
3592.702:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\steam_api.dll" at 3B400000: native
3592.704:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-runtime-l1-1-0.dll" at 63740000: builtin
3592.704:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-string-l1-1-0.dll" at 6FF00000: builtin
3592.705:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-heap-l1-1-0.dll" at 02990000: builtin
3592.705:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-stdio-l1-1-0.dll" at 6B7C0000: builtin
3592.705:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-convert-l1-1-0.dll" at 61F00000: builtin
3592.705:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\VCRUNTIME140.dll" at 02970000: native
3592.706:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-locale-l1-1-0.dll" at 66600000: builtin
3592.706:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-math-l1-1-0.dll" at 61F80000: builtin
3592.706:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-multibyte-l1-1-0.dll" at 6F600000: builtin
3592.706:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-time-l1-1-0.dll" at 6CF40000: builtin
3592.707:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-filesystem-l1-1-0.dll" at 65D40000: builtin
3592.707:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-environment-l1-1-0.dll" at 029A0000: builtin
3592.707:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-utility-l1-1-0.dll" at 029B0000: builtin
3592.707:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSVCP140.dll" at 02900000: native
3592.708:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSWSOCK.dll" at 6E4C0000: builtin
3592.709:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-crt-conio-l1-1-0.dll" at 64DC0000: builtin
3592.710:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 6A280000: builtin
3592.710:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\SDL2.dll" at 6C740000: native
3592.710:010c:0110:trace:loaddll:build_module Loaded L"Z:\\home\\benjamin\\.local\\share\\Steam\\steamapps\\common\\Ticket to Ride\\glew32.dll" at 62AA0000: native
3592.711:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\mpr.dll" at 70940000: builtin
3592.712:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WININET.dll" at 61940000: builtin
3592.746:010c:0110:trace:seh:NtQueryInformationThread (0xfffffffe,1,0x1bdec50,20,(nil))
3592.748:010c:0110:trace:seh:NtQueryInformationThread (0x60,0,0x1bde844,1c,(nil))
3592.751:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 7D440000: builtin
3592.761:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\uxtheme.dll" at 68700000: builtin
3592.763:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\dnsapi.dll" at 7D220000: builtin
3592.763:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\netapi32.dll" at 7D240000: builtin
3592.763:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\secur32.dll" at 7D280000: builtin
3592.764:010c:0110:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
3592.766:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\Kerberos.dll" at 7D200000: builtin
3592.766:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-core-synch-l1-2-0.dll" at 6DE80000: builtin
3592.767:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-core-fibers-l1-1-1.dll" at 6AC80000: builtin
3592.767:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\api-ms-win-core-localization-l1-2-1.dll" at 62B80000: builtin
3592.775:010c:0110:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
3592.920:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\lsteamclient.dll" at F5960000: builtin
3592.920:010c:0110:trace:loaddll:build_module Loaded L"C:\\Program Files (x86)\\Steam\\steamclient.dll" at 38000000: native
3592.921:010c:0110:warn:debugstr:OutputDebugStringA "[S_API] SteamAPI_Init(): Loaded 'C:\\Program Files (x86)\\Steam\\steamclient.dll' OK.\n"
3592.921:010c:0110:trace:seh:dispatch_exception code=40010006 flags=0 addr=7B0110B7 ip=7b0110b7 tid=0110
3592.921:010c:0110:trace:seh:dispatch_exception info[0]=00000054
3592.921:010c:0110:trace:seh:dispatch_exception info[1]=01bdf140
3592.921:010c:0110:warn:seh:dispatch_exception "[S_API] SteamAPI_Init(): Loaded 'C:\\Program Files (x86)\\Steam\\steamclient.dll' OK.\n"
3592.921:010c:0110:trace:seh:call_vectored_handlers calling handler at 7B00AE10 code=40010006 flags=0
3592.921:010c:0110:trace:seh:call_vectored_handlers handler at 7B00AE10 returned 0
3592.921:010c:0110:trace:seh:call_stack_handlers calling handler at 7B632630 code=40010006 flags=0
3592.921:010c:0110:trace:seh:__regs_RtlUnwind code=40010006 flags=2
3592.921:010c:0110:trace:seh:__regs_RtlUnwind eax=00000000 ebx=00000000 ecx=40010006 edx=01bdeb6c esi=01bdeaa0 edi=01bdeb6c
3592.921:010c:0110:trace:seh:__regs_RtlUnwind ebp=01bde618 esp=01bde610 eip=7b6325c6 cs=0023 ds=002b fs=0063 gs=006b flags=00000202
3592.921:010c:0110:trace:seh:__regs_RtlUnwind calling handler at 7BC585A0 code=40010006 flags=2
3592.921:010c:0110:trace:seh:__regs_RtlUnwind handler at 7BC585A0 returned 1
3592.950:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\PSAPI.DLL" at 67840000: builtin
3592.950:010c:0110:trace:loaddll:build_module Loaded L"C:\\Program Files (x86)\\Steam\\steam.dll" at 03AE0000: native
3592.962:010c:0110:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\xaudio2_7.dll" at F5FF0000: builtin
3592.970:010c:0110:trace:seh:dispatch_exception code=c0000005 flags=0 addr=F5FBCC66 ip=f5fbcc66 tid=0110
3592.970:010c:0110:trace:seh:dispatch_exception info[0]=00000000
3592.970:010c:0110:trace:seh:dispatch_exception info[1]=0000007c
3592.970:010c:0110:warn:seh:dispatch_exception EXCEPTION_ACCESS_VIOLATION exception (code=c0000005) raised
3592.970:010c:0110:trace:seh:dispatch_exception eax=00000000 ebx=f5fdb000 ecx=01bdf1c0 edx=01ac17d0 esi=017b1130 edi=00000000
3592.970:010c:0110:trace:seh:dispatch_exception ebp=01bdf1a8 esp=01bdf170 cs=0023 ds=002b es=002b fs=0063 gs=006b flags=00010246
3592.970:010c:0110:trace:seh:call_vectored_handlers calling handler at 7B00AE10 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_vectored_handlers handler at 7B00AE10 returned 0
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 01008CE8 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 01008CE8 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 01008EDB code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 01008EDB returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00FDB5B6 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00FDB5B6 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00F6B66F code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00F6B66F returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00FDDF50 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00FDDF50 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00F6AC37 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00F6AC37 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00F6A028 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00F6A028 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 00F1F462 code=c0000005 flags=0
3592.970:010c:0110:trace:seh:_XcptFilter (c0000005,01BDEBAC)
3592.970:010c:0110:trace:seh:call_stack_handlers handler at 00F1F462 returned 1
3592.970:010c:0110:trace:seh:call_stack_handlers calling handler at 7BC673E0 code=c0000005 flags=0
wine: Unhandled page fault on read access to 0000007C at address F5FBCC66 (thread 0110), starting debugger...
3592.970:010c:0110:trace:seh:start_debugger Starting debugger L"winedbg --auto 268 236"
3592.987:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedbg.exe" at 7E9A0000: builtin
3592.987:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
3592.987:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B600000: builtin
3592.988:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 70B40000: builtin
3592.988:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\dbghelp.dll" at 6FA80000: builtin
3592.989:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 6BC00000: builtin
3592.989:0118:011c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 61740000: builtin
3592.992:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: eax=ffffffff ebx=00000002 ecx=f7e8ac71 edx=f625eb20 esi=00000002 edi=01bde780
3592.992:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: ebp=01bde898 esp=01bde73c eip=7bc0ab8c cs=0023 ss=002b flags=00000246
3592.992:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: ds=002b es=002b fs=0063 gs=006b
3592.993:0118:011c:trace:seh:NtQueryInformationThread (0x4c,0,0x73fa54,1c,(nil))
3592.998:0118:011c:trace:seh:NtQueryInformationThread (0x60,0,0x73fa54,1c,(nil))
3593.062:0118:011c:trace:seh:NtQueryInformationThread (0x2e4,0,0x73fa54,1c,(nil))
3593.063:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: eax=ffffffff ebx=00000002 ecx=f7e8ac71 edx=f625eb20 esi=00000002 edi=01bde780
3593.063:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: ebp=01bde898 esp=01bde73c eip=7bc0ab8c cs=0023 ss=002b flags=00000246
3593.063:010c:0110:trace:seh:NtGetContextThread 0xfffffffe: ds=002b es=002b fs=0063 gs=006b
3593.063:010c:0110:trace:seh:call_stack_handlers handler at 7BC673E0 returned 1
3593.063:010c:0120:trace:seh:NtQueryInformationThread 0xfffffffe: eax=00000000 ebx=00000000 ecx=00000000 edx=00000000 esi=00000000 edi=00000000
3593.063:010c:0120:trace:seh:NtGetContextThread 0xfffffffe: ebp=03e3fe98 esp=03e3fe5c eip=7bc0a60c cs=0023 ss=002b flags=00000206
3593.063:010c:0120:trace:seh:NtGetContextThread 0xfffffffe: ds=002b es=002b fs=0063 gs=006b
3593.063:0118:011c:trace:seh:NtGetContextThread 0x4c: eax=00000000 ebx=f5fdb000 ecx=01bdf1c0 edx=01ac17d0 esi=017b1130 edi=00000000
3593.063:0118:011c:trace:seh:NtGetContextThread 0x4c: ebp=01bdf1a8 esp=01bdf170 eip=f5fbcc66 cs=0023 ss=002b flags=00010246
3593.063:0118:011c:trace:seh:NtGetContextThread 0x4c: ds=002b es=002b fs=0063 gs=006b
3593.063:0118:011c:trace:seh:NtGetContextThread 0x4c: dr0=00000000 dr1=00000000 dr2=00000000 dr3=00000000 dr6=00000000 dr7=00000000
Unhandled exception: page fault on read access to 0x0000007c in 32-bit code (0xf5fbcc66).
3593.063:0118:011c:trace:seh:NtQueryInformationThread (0x4c,0,0x73f3a0,1c,(nil))
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:f5fbcc66 ESP:01bdf170 EBP:01bdf1a8 EFLAGS:00010246( R- -- I Z- -P- )
EAX:00000000 EBX:f5fdb000 ECX:01bdf1c0 EDX:01ac17d0
ESI:017b1130 EDI:00000000
Stack dump:
0x01bdf170: f3543948 00000001 01bdf218 f3542000
0x01bdf180: 7d3c04b0 01bdf1a8 01bdf218 f34b522f
0x01bdf190: 7d3c04b0 f7ea0605 01bdf1c0 f5fdb000
0x01bdf1a0: 04e6c8c8 041071e8 01bdf218 f5fafdd5
0x01bdf1b0: f5fdb000 f342d296 f5fdb000 f5fafdd5
0x01bdf1c0: 017b1130 00000000 00000010 f5fafd4b
3593.070:0118:011c:trace:seh:NtQueryInformationThread (0x4c,6,0x73fac4,c,(nil))
Backtrace:
=>0 0xf5fbcc66 (0x01bdf1a8)
1 0xf5fafdd5 (0x01bdf218)
2 0xf5ffb1f7 (0x01bdf2a8)
3 0xf5ff52ee (0x01bdf308)
4 0x6c808c48 in sdl2 (+0xc8c47) (0x01bdf77c)
5 0x6c745736 EntryPoint+0x4305() in sdl2 (0x01bdf830)
6 0x00ba0b66 EntryPoint+0xffffffff() in ticket to ride (0x01bdf860)
7 0x00b9ca84 EntryPoint+0xffffffff() in ticket to ride (0x01bdf8c4)
8 0x00b9df30 EntryPoint+0xffffffff() in ticket to ride (0x01bdf8f4)
9 0x00901dcb EntryPoint+0xffffffff() in ticket to ride (0x01bdf91c)
10 0x0048c9b5 EntryPoint+0xffffffff() in ticket to ride (0x01bdf93c)
11 0x00a0b328 EntryPoint+0xffffffff() in ticket to ride (0x01bdf950)
12 0x00920ab7 EntryPoint+0xffffffff() in ticket to ride (0x01bdf9dc)
13 0x0048269d EntryPoint+0xffffffff() in ticket to ride (0x01bdfb34)
14 0x0047ab16 EntryPoint+0xffffffff() in ticket to ride (0x01bdfee4)
15 0x00f1ea8b EntryPoint+0xffffffff() in ticket to ride (0x01bdff30)
16 0x7b62ddf0 EntryPoint+0xffffffff() in kernel32 (0x01bdff48)
17 0x7bc5c6a7 EntryPoint+0xffffffff() in ntdll (0x01bdff5c)
18 0x7bc5c8f0 EntryPoint+0xffffffff() in ntdll (0x01bdffec)
0xf5fbcc66: movl 0x7c(%eax),%eax
Modules:
Module Address Debug info Name (88 modules)
PE 130000- 1a1000 Deferred msvcp120
PE 1b0000- 1eb000 Deferred wtf
PE 1f0000- 1fb000 Deferred pthreadvc2
PE 400000- 15cf000 Export ticket to ride
PE 1be0000- 1cce000 Deferred msvcr120
PE 1cd0000- 1da1000 Deferred cflite
PE 1db0000- 1e6b000 Deferred winmm
PE 1e70000- 22ea000 Deferred javascriptcore
PE 22f0000- 2375000 Deferred sqlite3
PE 2380000- 239a000 Deferred zlib1
PE 23a0000- 2503000 Deferred libeay32
PE 2510000- 2556000 Deferred ssleay32
PE 2560000- 25a5000 Deferred libcurl
PE 25b0000- 26e0000 Deferred cairo
PE 26e0000- 2710000 Deferred libxslt
PE 2710000- 28f4000 Deferred libxml2
PE 2900000- 296d000 Deferred msvcp140
PE 2970000- 2985000 Deferred vcruntime140
PE 2990000- 2998000 Deferred api-ms-win-crt-heap-l1-1-0
PE 29a0000- 29a7000 Deferred api-ms-win-crt-environment-l1-1-0
PE 29b0000- 29b8000 Deferred api-ms-win-crt-utility-l1-1-0
PE 3ae0000- 3c1d000 Deferred steam
PE 10000000-10d77000 Deferred webkit
PE 38000000-39188000 Deferred steamclient
PE 3b400000-3b43d000 Deferred steam_api
PE 4a800000-4a8fc000 Deferred libicuuc
PE 4a900000-4aa51000 Deferred libicuin
PE 4ad00000-4bbad000 Deferred icudt46
PE 61740000-61782000 Deferred advapi32
PE 61940000-619c9000 Deferred wininet
PE 61f00000-61f09000 Deferred api-ms-win-crt-convert-l1-1-0
PE 61f80000-61f8b000 Deferred api-ms-win-crt-math-l1-1-0
PE 62aa0000-62af4000 Deferred glew32
PE 62b80000-62b88000 Deferred api-ms-win-core-localization-l1-2-1
PE 62d40000-62e0d000 Deferred windowscodecs
PE 62fc0000-6304d000 Deferred rpcrt4
PE 63480000-6348d000 Deferred version
PE 63740000-63749000 Deferred api-ms-win-crt-runtime-l1-1-0
PE 63bc0000-63bd9000 Deferred shcore
PE 64a40000-64a94000 Deferred shlwapi
PE 64dc0000-64dc8000 Deferred api-ms-win-crt-conio-l1-1-0
PE 64ec0000-64fed000 Deferred oleaut32
PE 65d40000-65d48000 Deferred api-ms-win-crt-filesystem-l1-1-0
PE 66240000-66257000 Deferred bcrypt
PE 66600000-66607000 Deferred api-ms-win-crt-locale-l1-1-0
PE 67840000-6784a000 Deferred psapi
PE 68500000-68559000 Deferred combase
PE 68700000-6872e000 Deferred uxtheme
PE 69180000-69190000 Deferred wsock32
PE 69940000-6996a000 Deferred propsys
PE 6a040000-6a062000 Deferred msacm32
PE 6a280000-6a325000 Deferred msvcrt
PE 6a400000-6a530000 Deferred ole32
PE 6ac80000-6ac87000 Deferred api-ms-win-core-fibers-l1-1-1
PE 6b7c0000-6b7c9000 Deferred api-ms-win-crt-stdio-l1-1-0
PE 6bc00000-6bc2c000 Deferred sechost
PE 6bcc0000-6bd3f000 Deferred setupapi
PE 6c740000-6c83f000 Export sdl2
PE 6c9c0000-6cb1d000 Deferred gdi32
PE 6cc40000-6cd9f000 Deferred comctl32
PE 6cf40000-6cf47000 Deferred api-ms-win-crt-time-l1-1-0
PE 6de80000-6de88000 Deferred api-ms-win-core-synch-l1-2-0
PE 6e4c0000-6e4cc000 Deferred mswsock
PE 6e8c0000-6e994000 Deferred crypt32
PE 6ed00000-6ef18000 Deferred user32
PE 6f600000-6f60a000 Deferred api-ms-win-crt-multibyte-l1-1-0
PE 6ff00000-6ff09000 Deferred api-ms-win-crt-string-l1-1-0
PE 70940000-7095f000 Deferred mpr
PE 70b40000-70c12000 Deferred ucrtbase
PE 70d00000-70e08000 Deferred comdlg32
PE 70e80000-70e8a000 Deferred msimg32
PE 71200000-7121c000 Deferred imm32
PE 7a840000-7a844000 Deferred opengl32
PE 7b000000-7b0e8000 Deferred kernelbase
PE 7b600000-7b81a000 Export kernel32
PE 7bc00000-7bca6000 Export ntdll
PE 7d200000-7d203000 Deferred kerberos
PE 7d220000-7d224000 Deferred dnsapi
PE 7d240000-7d243000 Deferred netapi32
PE 7d280000-7d283000 Deferred secur32
PE 7d440000-7d444000 Deferred winex11
PE 7de70000-7de7b000 Deferred winspool
PE 7deb0000-7decb000 Deferred wldap32
PE 7df20000-7df24000 Deferred ws2_32
PE 7df80000-7e857000 Deferred shell32
PE 7e960000-7e964000 Deferred iphlpapi
PE f5960000-f5963000 Deferred lsteamclient
PE f5ff0000-f5ff4000 Deferred xaudio2_7
Threads:
process tid prio (all id:s are in hex)
00000020 steam.exe
00000024 0
000000b8 0
00000030 services.exe
00000034 0
00000038 0
00000044 0
00000048 0
00000054 0
00000064 0
0000007c 0
00000088 0
000000ac 0
000000e4 0
000000e8 0
0000003c winedevice.exe
00000040 0
0000004c 0
00000050 0
00000058 0
0000005c plugplay.exe
00000060 0
00000068 0
0000006c 0
00000070 0
00000090 0
00000094 0
00000074 winedevice.exe
00000078 0
00000080 0
00000084 0
0000008c 0
00000098 0
0000009c 0
000000a0 0
000000a4 svchost.exe
000000a8 0
000000b0 0
000000b4 0
000000bc explorer.exe
000000c0 0
000000c8 0
000000cc 0
000000d4 rpcss.exe
000000d8 0
000000ec 0
000000f0 0
000000f4 0
000000f8 0
000000fc 0
00000100 0
0000010c (D) Z:\home\benjamin\.local\share\Steam\steamapps\common\Ticket to Ride\Ticket to Ride.exe
00000110 0 <==
00000114 0
00000120 0
System information:
Wine build: wine-6.3
Platform: i386 (WOW64)
Version: Windows 10
Host system: Linux
Host version: 5.14.14-zen1-1-zen
3594.105:00d4:00fc:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x263fe2c,4,(nil))
3595.111:0030:00ac:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x386fe2c,4,(nil))
3595.113:00d4:00f4:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x1a1fe2c,4,(nil))
3595.113:005c:0090:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x204fe2c,4,(nil))
3595.113:005c:0070:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x1a3fe2c,4,(nil))
3595.114:00d4:00f8:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x202fe2c,4,(nil))
3595.116:0074:00a0:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x2e8fe2c,4,(nil))
3595.118:005c:006c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x142fe2c,4,(nil))
3595.119:0030:0054:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x202fe2c,4,(nil))
3595.120:0074:0084:trace:seh:dispatch_exception code=6ba flags=0 addr=000000007B01236E ip=000000007B01236E tid=0084
3595.120:0074:0084:warn:seh:dispatch_exception unknown exception (code=6ba) raised
3595.120:0030:0044:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x140fe2c,4,(nil))
3595.120:0074:0084:trace:seh:dispatch_exception rax=000000007b012320 rbx=000000000162f578 rcx=000000000162f2a0 rdx=0000000000000000
3595.120:0074:0084:trace:seh:dispatch_exception rsi=00000000000000cc rdi=00000000000000be rbp=0000000000000050 rsp=000000000162f280
3595.120:0074:0084:trace:seh:dispatch_exception r8=0000000000000000 r9=0000000000000000 r10=00000000c33c3cc3 r11=00000000a55a5aa5
3595.120:0074:0084:trace:seh:dispatch_exception r12=000000000162f578 r13=00000000016a0050 r14=0000000000000000 r15=00000000016a0050
3595.120:0074:0084:trace:seh:call_vectored_handlers calling handler at 00000002279AD540 code=6ba flags=0
3595.120:0074:0084:trace:seh:call_vectored_handlers handler at 00000002279AD540 returned 0
3595.120:0074:0084:trace:seh:call_vectored_handlers calling handler at 000000007B00C660 code=6ba flags=0
3595.120:0074:0084:trace:seh:call_vectored_handlers handler at 000000007B00C660 returned 0
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 000000007B01236E rsp 000000000162F280
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 12320-123a7
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007B0A5480 flags 0 prolog 0x11 bytes function 000000007B012320-000000007B0123A7
3595.120:0074:0084:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
3595.120:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rsi
3595.120:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rdi
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 0000000231B22812 rsp 000000000162F360
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 42800-42847
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B453C0 flags 0 prolog 0x4 bytes function 0000000231B22800-0000000231B22847
3595.120:0074:0084:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 0000000231AE98A4 rsp 000000000162F390
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 97b0-98a5
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B43340 flags 0 prolog 0x6 bytes function 0000000231AE97B0-0000000231AE98A5
3595.120:0074:0084:trace:seh:dump_unwind_info 0x6: subq $0x38,%rsp
3595.120:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %rbx
3595.120:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rsi
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 00000002279C2EAE rsp 000000000162F3E0
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 22cf0-22f10
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4EC0 flags 0 prolog 0xe bytes function 00000002279C2CF0-00000002279C2F10
3595.120:0074:0084:trace:seh:dump_unwind_info 0xe: subq $0x330,%rsp
3595.120:0074:0084:trace:seh:dump_unwind_info 0x7: pushq %rbx
3595.120:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %rsi
3595.120:0074:0084:trace:seh:dump_unwind_info 0x5: pushq %rdi
3595.120:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r12
3595.120:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r13
3595.120:0074:0084:trace:seh:call_stack_handlers found wine frame 000000000162F450 rsp 000000000162F740 handler 00000002279C27B0
3595.120:0074:0084:trace:seh:call_teb_handler calling TEB handler 00000002279C27B0 (rec=000000000162F2A0, frame=000000000162F450 context=000000000162E7C0, dispatch=000000000162E690)
3595.120:0074:0084:trace:seh:call_teb_handler handler at 00000002279C27B0 returned 1
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 00000002279BAD65 rsp 000000000162F740
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 1ac90-1ad76
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4A70 flags 0 prolog 0x8 bytes function 00000002279BAC90-00000002279BAD76
3595.120:0074:0084:trace:seh:dump_unwind_info 0x8: subq $0x160,%rsp
3595.120:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rbx
3595.120:0074:0084:trace:seh:call_stack_handlers found wine frame 000000000162F770 rsp 000000000162F8B0 handler 00000002279C40A0
3595.120:0074:0084:trace:seh:call_teb_handler calling TEB handler 00000002279C40A0 (rec=000000000162F2A0, frame=000000000162F770 context=000000000162E7C0, dispatch=000000000162E690)
3595.120:0074:0084:trace:seh:RtlUnwindEx code=6ba flags=2 end_frame=000000000162F770 target_ip=00000002279C403A rip=000000007bc5ac82
3595.120:0074:0084:trace:seh:RtlUnwindEx rax=000000003ffc0000 rbx=000000000162f450 rcx=000000000162e090 rdx=00000000279c403a
3595.120:0074:0084:trace:seh:RtlUnwindEx rsi=000000000162eda0 rdi=000000000162e7c0 rbp=000000000162db40 rsp=000000000162d9c0
3595.120:0074:0084:trace:seh:RtlUnwindEx r8=000000000162f2a0 r9=00000000279c4070 r10=000000000162e470 r11=0000000000026590
3595.120:0074:0084:trace:seh:RtlUnwindEx r12=000000000162f2a0 r13=000000000162e090 r14=000000000162f770 r15=000000000162f2a0
3595.120:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5AC82 rsp 000000000162D9C0
3595.120:0074:0084:trace:seh:dump_unwind_info **** func 5ac30-5b53e
3595.120:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC8398C flags 0 prolog 0x13 bytes function 000000007BC5AC30-000000007BC5B53E
3595.120:0074:0084:trace:seh:dump_unwind_info 0x13: subq $0x658,%rsp
3595.120:0074:0084:trace:seh:dump_unwind_info 0xc: pushq %rbx
3595.120:0074:0084:trace:seh:dump_unwind_info 0xb: pushq %rsi
3595.120:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rdi
3595.120:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rbp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x8: pushq %r12
3595.121:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %r13
3595.121:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r14
3595.121:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r15
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5B55F rsp 000000000162E060
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 5b540-5b568
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC839A4 flags 0 prolog 0x7 bytes function 000000007BC5B540-000000007BC5B568
3595.121:0074:0084:trace:seh:dump_unwind_info 0x7: subq $0x508,%rsp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C403A rsp 000000000162E570
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 24020-2403c
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F68 flags 0 prolog 0x8 bytes function 00000002279C4020-00000002279C403C
3595.121:0074:0084:trace:seh:dump_unwind_info frame register rbp offset 0x0(%rsp)
3595.121:0074:0084:trace:seh:dump_unwind_info 0x8: subq $0x20,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x4: leaq 0x0(%rsp),rbp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rbp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C4069 rsp 000000000162E5A0
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 24040-2406a
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F74 flags 0 prolog 0x4 bytes function 00000002279C4040-00000002279C406A
3595.121:0074:0084:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C40F4 rsp 000000000162E5D0
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 240a0-240f5
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F84 flags 0 prolog 0xa bytes function 00000002279C40A0-00000002279C40F5
3595.121:0074:0084:trace:seh:dump_unwind_info 0xa: subq $0x30,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %r12
3595.121:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r13
3595.121:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r14
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A1BF rsp 000000000162E620
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 59ee0-5a431
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC83948 flags 0 prolog 0x13 bytes function 000000007BC59EE0-000000007BC5A431
3595.121:0074:0084:trace:seh:dump_unwind_info 0x13: subq $0x678,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0xc: pushq %rbx
3595.121:0074:0084:trace:seh:dump_unwind_info 0xb: pushq %rsi
3595.121:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rdi
3595.121:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rbp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A747 rsp 000000000162ECE0
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 5a440-5a94f
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC83960 flags 0 prolog 0x10 bytes function 000000007BC5A440-000000007BC5A94F
3595.121:0074:0084:trace:seh:dump_unwind_info 0x10: subq $0x58,%rsp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC583C4 rsp 000000000162ED80
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 5835c-583d1
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC838B0 flags 0 prolog 0x7 bytes function 000000007BC5835C-000000007BC583D1
3595.121:0074:0084:trace:seh:dump_unwind_info 0x7: subq $0x4f8,%rsp
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007B01236E rsp 000000000162F280
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 12320-123a7
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007B0A5480 flags 0 prolog 0x11 bytes function 000000007B012320-000000007B0123A7
3595.121:0074:0084:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rsi
3595.121:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rdi
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 0000000231B22812 rsp 000000000162F360
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 42800-42847
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B453C0 flags 0 prolog 0x4 bytes function 0000000231B22800-0000000231B22847
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 0000000231AE98A4 rsp 000000000162F390
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 97b0-98a5
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B43340 flags 0 prolog 0x6 bytes function 0000000231AE97B0-0000000231AE98A5
3595.121:0074:0084:trace:seh:dump_unwind_info 0x6: subq $0x38,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %rbx
3595.121:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rsi
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C2EAE rsp 000000000162F3E0
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 22cf0-22f10
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4EC0 flags 0 prolog 0xe bytes function 00000002279C2CF0-00000002279C2F10
3595.121:0074:0084:trace:seh:dump_unwind_info 0xe: subq $0x330,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x7: pushq %rbx
3595.121:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %rsi
3595.121:0074:0084:trace:seh:dump_unwind_info 0x5: pushq %rdi
3595.121:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r12
3595.121:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r13
3595.121:0074:0084:trace:seh:RtlUnwindEx found builtin frame 000000000162F450 handler 00000002279C27B0
3595.121:0074:0084:trace:seh:call_teb_unwind_handler calling TEB handler 00000002279C27B0 (rec=000000000162F2A0, frame=000000000162F450 context=000000000162E090, dispatch=000000000162DA50)
3595.121:0074:0084:trace:seh:call_teb_unwind_handler handler at 00000002279C27B0 returned 1
3595.121:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279BAD65 rsp 000000000162F740
3595.121:0074:0084:trace:seh:dump_unwind_info **** func 1ac90-1ad76
3595.121:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4A70 flags 0 prolog 0x8 bytes function 00000002279BAC90-00000002279BAD76
3595.121:0074:0084:trace:seh:dump_unwind_info 0x8: subq $0x160,%rsp
3595.121:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rbx
3595.121:0074:0084:trace:seh:RtlRestoreContext returning to 00000002279C403A stack 000000000162F740
3595.123:0074:0084:trace:seh:dispatch_exception code=6ba flags=0 addr=000000007B01236E ip=000000007B01236E tid=0084
3595.123:0074:0084:warn:seh:dispatch_exception unknown exception (code=6ba) raised
3595.123:0074:0084:trace:seh:dispatch_exception rax=000000007b012320 rbx=000000000162f578 rcx=000000000162f290 rdx=0000000000000000
3595.123:0074:0084:trace:seh:dispatch_exception rsi=00000000000000d2 rdi=0000000001660230 rbp=0000000000000050 rsp=000000000162f270
3595.123:0074:0084:trace:seh:dispatch_exception r8=0000000000000000 r9=0000000000000000 r10=00000000c33c3cc3 r11=00000000a55a5aa5
3595.123:0074:0084:trace:seh:dispatch_exception r12=000000000162f578 r13=00000000016a0050 r14=0000000000000000 r15=00000000016a0050
3595.123:0074:0084:trace:seh:call_vectored_handlers calling handler at 00000002279AD540 code=6ba flags=0
3595.123:0074:0084:trace:seh:call_vectored_handlers handler at 00000002279AD540 returned 0
3595.123:0074:0084:trace:seh:call_vectored_handlers calling handler at 000000007B00C660 code=6ba flags=0
3595.123:0074:0084:trace:seh:call_vectored_handlers handler at 000000007B00C660 returned 0
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 000000007B01236E rsp 000000000162F270
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 12320-123a7
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007B0A5480 flags 0 prolog 0x11 bytes function 000000007B012320-000000007B0123A7
3595.123:0074:0084:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rsi
3595.123:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rdi
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 0000000231B22812 rsp 000000000162F350
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 42800-42847
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B453C0 flags 0 prolog 0x4 bytes function 0000000231B22800-0000000231B22847
3595.123:0074:0084:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 0000000231AE9736 rsp 000000000162F380
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 96b0-9737
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 0000000231B4332C flags 0 prolog 0x7 bytes function 0000000231AE96B0-0000000231AE9737
3595.123:0074:0084:trace:seh:dump_unwind_info 0x7: subq $0x40,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x3: pushq %rbx
3595.123:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %rsi
3595.123:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rdi
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 00000002279C2DED rsp 000000000162F3E0
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 22cf0-22f10
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4EC0 flags 0 prolog 0xe bytes function 00000002279C2CF0-00000002279C2F10
3595.123:0074:0084:trace:seh:dump_unwind_info 0xe: subq $0x330,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x7: pushq %rbx
3595.123:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %rsi
3595.123:0074:0084:trace:seh:dump_unwind_info 0x5: pushq %rdi
3595.123:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r12
3595.123:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r13
3595.123:0074:0084:trace:seh:call_stack_handlers found wine frame 000000000162F450 rsp 000000000162F740 handler 00000002279C27B0
3595.123:0074:0084:trace:seh:call_teb_handler calling TEB handler 00000002279C27B0 (rec=000000000162F290, frame=000000000162F450 context=000000000162E7B0, dispatch=000000000162E680)
3595.123:0074:0084:trace:seh:call_teb_handler handler at 00000002279C27B0 returned 1
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 1 rip 00000002279BAD65 rsp 000000000162F740
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 1ac90-1ad76
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4A70 flags 0 prolog 0x8 bytes function 00000002279BAC90-00000002279BAD76
3595.123:0074:0084:trace:seh:dump_unwind_info 0x8: subq $0x160,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rbx
3595.123:0074:0084:trace:seh:call_stack_handlers found wine frame 000000000162F770 rsp 000000000162F8B0 handler 00000002279C40A0
3595.123:0074:0084:trace:seh:call_teb_handler calling TEB handler 00000002279C40A0 (rec=000000000162F290, frame=000000000162F770 context=000000000162E7B0, dispatch=000000000162E680)
3595.123:0074:0084:trace:seh:RtlUnwindEx code=6ba flags=2 end_frame=000000000162F770 target_ip=00000002279C403A rip=000000007bc5ac82
3595.123:0074:0084:trace:seh:RtlUnwindEx rax=000000003ffc0000 rbx=000000000162f450 rcx=000000000162e080 rdx=00000000279c403a
3595.123:0074:0084:trace:seh:RtlUnwindEx rsi=000000000162ed90 rdi=000000000162e7b0 rbp=000000000162db30 rsp=000000000162d9b0
3595.123:0074:0084:trace:seh:RtlUnwindEx r8=000000000162f290 r9=00000000279c4070 r10=000000000162e276 r11=0000000000000293
3595.123:0074:0084:trace:seh:RtlUnwindEx r12=000000000162f290 r13=000000000162e080 r14=000000000162f770 r15=000000000162f290
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5AC82 rsp 000000000162D9B0
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 5ac30-5b53e
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC8398C flags 0 prolog 0x13 bytes function 000000007BC5AC30-000000007BC5B53E
3595.123:0074:0084:trace:seh:dump_unwind_info 0x13: subq $0x658,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0xc: pushq %rbx
3595.123:0074:0084:trace:seh:dump_unwind_info 0xb: pushq %rsi
3595.123:0074:0084:trace:seh:dump_unwind_info 0xa: pushq %rdi
3595.123:0074:0084:trace:seh:dump_unwind_info 0x9: pushq %rbp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x8: pushq %r12
3595.123:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %r13
3595.123:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r14
3595.123:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r15
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5B55F rsp 000000000162E050
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 5b540-5b568
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC839A4 flags 0 prolog 0x7 bytes function 000000007BC5B540-000000007BC5B568
3595.123:0074:0084:trace:seh:dump_unwind_info 0x7: subq $0x508,%rsp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C403A rsp 000000000162E560
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 24020-2403c
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F68 flags 0 prolog 0x8 bytes function 00000002279C4020-00000002279C403C
3595.123:0074:0084:trace:seh:dump_unwind_info frame register rbp offset 0x0(%rsp)
3595.123:0074:0084:trace:seh:dump_unwind_info 0x8: subq $0x20,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x4: leaq 0x0(%rsp),rbp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x1: pushq %rbp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C4069 rsp 000000000162E590
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 24040-2406a
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F74 flags 0 prolog 0x4 bytes function 00000002279C4040-00000002279C406A
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C40F4 rsp 000000000162E5C0
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 240a0-240f5
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 00000002279D4F84 flags 0 prolog 0xa bytes function 00000002279C40A0-00000002279C40F5
3595.123:0074:0084:trace:seh:dump_unwind_info 0xa: subq $0x30,%rsp
3595.123:0074:0084:trace:seh:dump_unwind_info 0x6: pushq %r12
3595.123:0074:0084:trace:seh:dump_unwind_info 0x4: pushq %r13
3595.123:0074:0084:trace:seh:dump_unwind_info 0x2: pushq %r14
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A1BF rsp 000000000162E610
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 59ee0-5a431
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC83948 flags 0 prolog 0x13 bytes function 000000007BC59EE0-000000007BC5A431
3595.123:0074:0084:trace:seh:dump_unwind_info 0x13: subq $0x678,%rsp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC5A747 rsp 000000000162ECD0
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 5a440-5a94f
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC83960 flags 0 prolog 0x10 bytes function 000000007BC5A440-000000007BC5A94F
3595.123:0074:0084:trace:seh:dump_unwind_info 0x10: subq $0x58,%rsp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007BC583C4 rsp 000000000162ED70
3595.123:0074:0084:trace:seh:dump_unwind_info **** func 5835c-583d1
3595.123:0074:0084:trace:seh:dump_unwind_info unwind info at 000000007BC838B0 flags 0 prolog 0x7 bytes function 000000007BC5835C-000000007BC583D1
3595.123:0074:0084:trace:seh:dump_unwind_info 0x7: subq $0x4f8,%rsp
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 000000007B01236E rsp 000000000162F270
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 0000000231B22812 rsp 000000000162F350
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 0000000231AE9736 rsp 000000000162F380
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279C2DED rsp 000000000162F3E0
3595.123:0074:0084:trace:seh:RtlUnwindEx found builtin frame 000000000162F450 handler 00000002279C27B0
3595.123:0074:0084:trace:seh:call_teb_unwind_handler calling TEB handler 00000002279C27B0 (rec=000000000162F290, frame=000000000162F450 context=000000000162E080, dispatch=000000000162DA40)
3595.123:0074:0084:trace:seh:call_teb_unwind_handler handler at 00000002279C27B0 returned 1
3595.123:0074:0084:trace:seh:RtlVirtualUnwind type 2 rip 00000002279BAD65 rsp 000000000162F740
3595.123:0074:0084:trace:seh:RtlRestoreContext returning to 00000002279C403A stack 000000000162F740
3595.126:0074:008c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x1c5fe2c,4,(nil))
3595.127:0074:0098:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x226fe2c,4,(nil))
3595.127:0074:009c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x287fe2c,4,(nil))
3595.130:0074:0084:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\winebus.sys" : builtin
3595.131:00d4:00f0:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x140fe2c,4,(nil))
3595.132:0074:0084:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\wineusb.sys" : builtin
3595.134:0074:0084:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\winehid.sys" : builtin
3595.134:0074:0084:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\hidclass.sys" : builtin
3595.136:0074:0084:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x162fe2c,4,(nil))
3595.215:0030:0064:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x263fe2c,4,(nil))
3595.221:0030:00e4:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x448fe2c,4,(nil))
3595.221:0030:007c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x2c4fe2c,4,(nil))
3595.221:0030:012c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x52bfe2c,4,(nil))
3595.221:0030:0038:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xdffe2c,4,(nil))
3595.222:0030:0088:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x325fe2c,4,(nil))
pid 31628 != 31627, skipping destruction (fork without exec?)
System Info:
System Info
inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=2fab759e-ecae-4e84-a991-4b024381cc6e rw
cryptdevice=UUID=6d38f759-8c9a-4ad3-aa7a-89300f47a7a5:root:allow-discards
root=/dev/mapper/root loglevel=3 udev.log_level=3 vt.global_cursor_default=0
nowatchdog quiet splash mitigations=off
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Arch Linux
Type: Desktop System: Intel Client Systems product: NUC8i7HVK v: J71485-504
serial: <filter> Chassis: Intel Corporation type: 3 v: 2.0 serial: <filter>
Mobo: Intel model: NUC8i7HVB v: J68196-504 serial: <filter> UEFI: Intel
v: HNKBLi70.86A.0066.2021.0310.1823 date: 03/10/2021
Battery:
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Memory:
RAM: total: 31.27 GiB used: 4.77 GiB (15.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: Quad Core model: Intel Core i7-8809G bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
cache: L2: 8 MiB bogomips: 49599
Speed: 812 MHz min/max: 800/8300 MHz Core speeds (MHz): 1: 812 2: 900 3: 901
4: 885 5: 900 6: 852 7: 867 8: 808
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0380
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:694c class-ID: 0300
Device-3: Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 6-1:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: amdgpu,ati,intel unloaded: fbdev,modesetting,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DisplayPort-3 res: 1920x1080 hz: 60 dpi: 93
OpenGL: renderer: AMD VEGAM (DRM 3.42.0 5.14.14-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.4 direct render: Yes
Device-1: Intel CM238 HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: AMD Polaris 22 HDMI Audio vendor: Intel driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 1002:ab08 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ethernet I219-LM driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Intel I210 Gigabit Network driver: igb v: kernel port: b000
bus-ID: 05:00.0 chip-ID: 8086:157b class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 06:00.0 chip-ID: 8086:24fd class-ID: 0280
WAN IP: <filter>
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-9:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Logical:
Message: No logical block device data found.
Device-1: data maj-min: 254:1 type: LUKS dm: dm-1 size: 953.85 GiB
Components:
p-1: nvme1n1 maj-min: 259:0 size: 953.87 GiB
Device-2: root maj-min: 254:0 type: LUKS dm: dm-0 size: 953.36 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:3 size: 953.36 GiB
RAID:
Message: No RAID data found.
Local Storage: total: 1.86 TiB used: 416.59 GiB (21.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: SS0411B temp: 39.9 C
Message: No optical or floppy data found.
ID-1: / raw-size: 953.36 GiB size: 937.32 GiB (98.32%)
used: 161.26 GiB (17.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0 mapped: root
label: N/A uuid: N/A
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
label: NO_LABEL uuid: 5357-2CB5
ID-3: /data raw-size: 953.85 GiB size: 937.81 GiB (98.32%)
used: 255.32 GiB (27.2%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: data
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Unmounted:
Message: No unmounted partitions found.
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-9:2 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-2: 1-10:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-11:4 info: Dell Dell Laser Mouse MS3220 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 413c:250e class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:3 info: Garmin type: <vendor specific> driver: usbfs
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 091e:4cda
class-ID: 0000 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 6-1:2 info: Logitech StreamCam type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.2
speed: 5 Gb/s power: 896mA chip-ID: 046d:0893 class-ID: 0300
serial: <filter>
System Temperatures: cpu: 62.5 C mobo: 29.8 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A
Processes: 312 Uptime: 1h 1m wakeups: 17 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1218
lib: 319 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.07
