HELP PLEASE! im on i3 and i cant boot into bios! [ NOT SOLVED ]
update failed every time i tried
First time ive used what? The os?
Or the pc
Computer. Maybe you have a faulty new part.
Ive had this for a bit and it worked fine on every distro and windows so I dont think I could a bad part
( every distro that ive been on )
I really couldn’t tell you then. I’ve never had a working computer personally I couldn’t get into the firmware of.
And I guess while anything is possible,I just can’t imagine the OS being the culprit. I really think it’s hardware related. Keyboard, something… .
Kind of with you on this. Updating the BIOS could help too.
To enter the bios settings should be F2 or del key. Maybe shutdown your system. Unplug from power and hold down the power button for 30 seconds. Then plug it back in and start it up pressing f2 key repeatedly.
Is updating bios a command or do i need to read a tut online for it
ill try this
It’s an origin PC so I don’t know what board it has to look it up.
Edit: Sorry I see it has the Rog Strix 590-A
Something happened… It showed my boot thingy for like a half second ( where it shows the keys to boot bios ) and then went away and im stuck at blackscreen
There are 9 bios updates newer so you should update the UEFI Bios to the latest.
Atleast i think it was that screen
Alright ill look for a tutorial on that
Are you able to press alt F1 or alt F2 and get into a TTY screen and then run the update command.
When im booting up?
Yes when it gets to a black screen.
Ill check rq
