HELP PLEASE! im on i3 and i cant boot into bios! [ NOT SOLVED ]
Okay it’s updated.
Mobo: ASUSTeK model: ROG STRIX Z590-A GAMING WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1701
    date: 12/12/2022
So shut it down and unplug again and then put the Gpu card back in. Make sure to ground yourself. And then try booting it with the Gpu in it and the monitor plugged into the Gpu.
Edit: Make sure the Gpu is seated firmly and the back hold down snaps into place when you insert the card.
Booted to desktop with gpu, should I reboot to see if it works? It booted to desktop last time and it worked till i restarted
Yes give it another reboot.
It booted to desktop. But im getting vga? Do we leave it alone?
Can you post
inxi -Ga
~> inxi -Ga
  Device-1: NVIDIA GA104 [GeForce RTX 3070] driver: nvidia v: 530.41.03
    alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
    off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2484
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a
    driver: X: loaded: nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 91 s-size: 1072x301mm (42.20x11.85")
    s-diag: 1113mm (43.84")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: 44C1G
    serial: 0000000000000 built: 2022 res: 3840x1080 hz: 60 dpi: 91 gamma: 1.2
    size: 1071x301mm (42.17x11.85") diag: 1112mm (43.8") modes: max: 3840x1080
    min: 640x480
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
    3070/PCIe/SSE2 direct-render: Yes
Looks good. I’m not sure if there is a problem when you see vga light. I’m sure it should light to show something. As long as it is working and you can get into Bios now and it’s updated i would just see what happens.
Run an update now also.
yay
~> yay
[sudo] password for exorsus:
 endeavouros        29.3 KiB   133 KiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
 core        132.2 KiB  1271 KiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
 extra        8.3 MiB  22.6 MiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
 community        45.0   B   432   B/s 00:00 [--------------------------------------------------------------------------------------] 100%
 multilib        141.3 KiB  1239 KiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
:: Searching AUR for updates...
:: Searching databases for updates...
 -> Packages not in AUR: libsidplay
:: 3 packages to upgrade/install.
3  endeavouros/endeavouros-skel-i3wm  4.9-1 -> 4.10-1
2  core/ncurses                       6.4-1 -> 6.4_20230520-1
1  multilib/lib32-ncurses             6.4-1 -> 6.4_20230520-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
 -> Excluding packages may cause partial upgrades and break systems
do i need to pick anything?
Just press enter.
should i try to boot into bios with the gpu?
Not sure but if it doesn’t work I’ll cry. :rofl:
Edit :Did you finish the update?
do i take that as a yes
yeah i did
Sure why not it’s only tears.
Sadly, it wont boot bios, seems like just how we were when we started
Should i try the bios force boot cmd
Sure why not. It didn’t work before.
Nope just booted back into desktop
Is this just a sign for me to get a new pc or something lmao
