Okay, hi everyone, I’m here with a new sound issue, I tried to fix it on my own so I’ll just tell my story.
Went for an endeavour os install on a windows laptop, all was working okay on Windows 10. When endeavour launched, no sound (and no trackpad either but one thing at the time).
I checked on pulseaudio control, was having only dummy output and no soundcard whatever. I then installed sof-firmware and added in
/etc/modprobe.d/audio-fix.conf
blacklist snd-sof-pci
options snd-intel-dspcfg dsp_driver = 1
/etc/modprobe.d/alsa-base.conf
options snd-hda-intel model = mobile
After that, the soundcard was detected, and all but I only have HDMI outputs and no analogue ouput:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
Also, inxi -A
Device-1: Intel Jasper Lake HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.5-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.51 running: yes
I you have an idea, that would be awesome thanks a lot !!
Did you try editing those files one at a time and see.
Please post the link
inxi -Faz | eos-sendlog
I did edit those files but nothing, the link : https://clbin.com/07S5o
Okay remove all of those so you are not blacklisting snd-sof-pci and remove both other options.
Reboot and see if audio hardware is still listed.
Did and rebooted and nothing on aplay -l, inxi still gives me the same>
Try adding this instead to /etc/modprobe.d/alsa-base.conf and reboot see if any different.
options snd_hda_intel model=auto
Still nothing unfortunately on aplay -l , same on inxi .
What shows on aplay -l
Edit: Nothing at all? No devices or just no intel device?
Okay remove that and try this. Edit the default grub command line with nano and add this kernel parameter in
/etc/default/grub
add
snd_intel_dspcfg.dsp_driver=1
Then update grub with
reboot
Just got back to the only HDMI output on aply -l
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
inxi hasnt changed.
(BTW thanks for your time helping me )
What happens if you change the above to
snd_intel_dspcfg.dsp_driver=0
Update grub and reboot to see if any difference.
I have the no soundcards again on aplay -l
aplay: device_list:274: no soundcards found...
Okay well you can change it back i guess for now. So you also removed the blacklisting of snd-sof-pci
Yes removed the snd-sof-pci , I can add it back I guess.
Do you have sof-firmware installed?
Yeah I installed it, as well as alsa-ucm-conf .
Did you try this as a kernel parameter and update grub?
snd_hda_intel.dmic_detect=0
You can also try it this way.
snd-intel-dspcfg.dsp_driver=1
Edit : This should be done in
/etc/modprobe.d/alsa.conf
I did it in
Changed nothing, still have only hdmi output on aplay -l
