Having a problem with calamares
I’ve tried to install EOS 3 times but every time, it shows an error:
Main script file /usr/lib/calamares/modules/bootloader/main.py for python job bootloader raised an exception.
Could anyone help me?
Not really sure from this, can you get a proper log? (there are instructuons/guides top left)
Do you mean this:
https://termbin.com/zfxl
Aren’t there any who can help me?
the log is cut of…
is all prepared properly?
  • secure boot = off
  • fastboot on possible Windows install disabled
  • Firmware/Bios set to EFI mode + disable CSM mode for drives and USB
  • Any RAID is set to off and it uses AHCI mode
  • installation Media properly created and fully synced to the USB
https://discovery.endeavouros.com/installation/live-iso-tricks-tips/2021/03/
https://discovery.endeavouros.com/installation/create-install-media-usb-key/2021/03/
show:
lsblk -f
sudo fdisk -l (corrected ;))
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/archiso/airootfs
sda
├─sda1 ntfs 3-DATA A82A04A92A04771A
├─sda2 ext4 1.0 endeavouros 2af269de-dcf4-4e87-a500-a724b43224c8
└─sda3 ntfs 4-Drive-C-Exp CA446A2C446A1C07
sdb iso9660 Joliet Exte EOS_202409 2024-09-22-10-45-49-00
├─sdb1 iso9660 Joliet Exte EOS_202409 2024-09-22-10-45-49-00 0 100% /run/archiso/bootmnt
└─sdb2 vfat FAT32 ARCHISO_EFI 66EF-F55D
nvme0n1
├─nvme0n1p1
│ ntfs A 3C9AC0859AC03D60
├─nvme0n1p2
│ ntfs B 8C24AA4924AA365C
├─nvme0n1p3
│ ntfs C 1C807B95807B73DC
└─nvme0n1p4
ntfs D 9A146B2D146B0B97
As far as I know, it must be fdisk; so this is the result:
sudo fdisk -l
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000LM035-1RK1
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x03921640
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 528297983 528295936 251.9G 7 HPFS/NTFS/exFAT
/dev/sda2 528297984 1282422783 754124800 359.6G 83 Linux
/dev/sda3 1282424832 1953521663 671096832 320G 7 HPFS/NTFS/exFAT
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: MSI M371 1TB
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xbd6cbd6c
/dev/nvme0n1p1 * 2048 8388607 8386560 4G 7 HPFS/NTFS/exFAT
/dev/nvme0n1p2 988823552 1492140031 503316480 240G 7 HPFS/NTFS/exFAT
/dev/nvme0n1p3 1492144128 1953517567 461373440 220G 7 HPFS/NTFS/exFAT
/dev/nvme0n1p4 8388608 988823551 980434944 467.5G 7 HPFS/NTFS/exFAT
Partition table entries are not in disk order.
Disk /dev/sdb: 7.5 GiB, 8054112256 bytes, 15730688 sectors
Disk model: Silicon-Power8G
Disklabel type: dos
Disk identifier: 0x4a514722
/dev/sdb1 * 64 5466911 5466848 2.6G 0 Empty
/dev/sdb2 5466912 5798687 331776 162M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 2.45 GiB, 2635329536 bytes, 5147128 sectors
Why are there 41 views but no one helps me?
This is very annoying!
This error doesn’t seem to match the log you shared. The log appears partial.
We need a full log that includes the error to actually help you.
Please try to be patient. There are lot of people who read the topic but that doesn’t mean they know how to help with your specific issue.
Also, keep in mind that we don’t have paid support staff. Everyone here who helps does it solely because they want to and manages it between things like sleep and work.
:sweat_smile:
Thanks a lot for your message.
I shared everything that I thought might be useful and you wanted. If you want some more detail, please mention it.
For that message, I could look offensive because I have a laptop that I have to open every time in live boot. So forgive me if it looks a little bit impolite and excessive.
But please note that every time I send those like messages, you answer.
all harddrives are using msdos partition scheme not gpt so seems windows is installed in legacy mode using CSM settings in the Bios.
This is where you installed Linux ? Was there another distribution installed before already?
Moderators will answer in this case to … moderate and reminding you on the rules.
People will most likely help more if you stay calm and friendly.
Actually I haven’t installed any kind of linux in this machine. Every time I tried to install EOS, I failed.
No
I could emphasized very much.
Forgive me for that.
Please read what @joekamprad posted in his first response.
it installed the OS but failed on bootloader setup…
There is no BUG free software so it can happen something bails out in cases… but in general It is strongly recommended to install EndeavourOS in EFI mode if the system is supporting this. in Your case it could be the issue that the liveISO boots in EFI mode but the drive you want to use is in dos scheme not gpt.
You can check the booted mode on live session by running efibootmgr in terminal it will show an error if its booted in legacy (BIOS) mode.
no problem you are welcome.
As far as I know it’s not installed because every time it raised an error. It just renames the partition.
$ efibootmgr
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 2001,2002,2003
Boot0000* EFI USB Device (UFD 2.0 Silicon-Power8G) PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/HD(1,MBR,0x4a514722,0x536b20,0x51000)RC
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
Hey, I just wanted to throw in my 50 cent. I had the same problem. I double checked fast boot, secure boot etc. It was all correct set. What helped me finish the task was to use Grub as a bootloader. The screen prior to manage the disc, you have three options.
Systemd
Grub
Or non bootloader.
There I picked the grub one and it worked.
