Nothing bad with Grub .. if systemd-boot is not working for you Grub is just fine to be used, also still more stable in case using Dualboot with WinBloat, you anly need to keep in mind that bit will not automatically update grub sytsemfiles in case of updates, and you also need to manually run grub.cfg regeneration on changes like adding Kernels or removing them and if you want to change kernel boot options in cases.. sudo grub-mkconfig -o /boot/grub/grub.cfg and if grub package updates you need to reinstall grub systemfiles sudo grub-install
