Harddrive mounting issues
Hi,
I’ve gotten a new hard drive I followed this guide: https://discovery.endeavouros.com/storage-and-partitions/how-to-permanently-mount-external-internal-drives-in-linux/2022/02/
Evidently I’ve done something wrong and I don’t know what which is annoying as I’ve mounted a drive before but retain zero recollection much to my dismay. Alternatively is there a way to just set up the drives to auto mount themselves whenever I add them as that would be extremely helpful for the future.
Thanks in advance
Edit: I found the outstation the guide states this: sudo chown -R : /mnt/
Whereas entering this instead: sudo chown -R /mnt/
The whole user group thing just confused maybe my way is wrong but works for me so… But thanks for the responses.
I don’t know how it can be explained any different or better than the wiki? Maybe you didn’t follow it correctly and made a mistake along the way. It happens. :wink:
You could show some info about what you have done already:
cat /etc/fstab > /tmp/info
lsblk -fm >> /tmp/info
cat /tmp/info | eos-sendlog
and show the returned address here.
By the way, is the new hard drive properly formatted?
If it contains nothing worth keeping yet, you can re-partition it (if needed) and reformat the partition(s) with gparted or another similar tool.
There is actually a command for that. It’s called cp :rofl:
Ironically, the intended purpose of cat is not to print or copy files, but to concatenate them. This concatenating power helps us avoid using temporary files:
lsblk -fm | cat /etc/fstab - | eos-sendlog
Yeah, as usual there are many ways of doing stuff.
Yet another is:
eos-sendlog "cat /etc/fstab; lsblk -fm"
Stop abusing cat !111
cat2_b9892408
We love cats over here…
WOOF
:dog:
Thanks for the response but I figured it out view my edit if you are interested
Thanks
Found the solution removed the user group
And that did the trick
