I installed EndeavuorOS, and I do not want any delay in Grub at boot. I changed the GRUB_TIMEOUT=“0” and updated with sudo grub-mkconfig -o /boot/grub/grub.cfg, but there is still a delay. I am not dual booting with Windows. Please advise. Thanks.
Try this as well and see if that helps:
GRUB_TIMEOUT_STYLE=hidden
Regenerate grub.cfg as before.
where you changed it?
/etc/default/grub ?
GRUB_TIMEOUT=0
You could also install the very small package grub-customizer and use that to edit the timeout or anything else about the grub(2) menu, it is in the community repos.
It is by far the easiest option, you can always uninstall the program when done.
Yes in /etc/default/grub
Please, please, please don’t do this. Almost everyone who uses grub-customrizer eventually comes here with help for a broken grub.
Can we see the contents of /boot/grub/grub.cfg?
I must have been very lucky then, I wasn’t aware that it broke grub, worked ok for the one thing I needed to change.
I tried your suggestion, no change. Is it possible it is located somewhere else since I am not dual booting with Windows?
grub.cfg:
# # DO NOT EDIT THIS FILE # # It is automatically generated by grub-mkconfig using templates # from /etc/grub.d and settings from /etc/default/grub # ### BEGIN /etc/grub.d/00_header ### if [ -s $prefix/grubenv ]; then load_env fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= save_env next_entry set boot_once=true else set default="0" fi if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi export menuentry_id_option if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" save_env saved_entry fi } function load_video { if [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod efi_uga insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi } if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 2e55b550-43ba-4420-a18b-210a0904e0a2 font="/usr/share/grub/unicode.pf2" fi if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_US insmod gettext fi terminal_output gfxterm insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 2e55b550-43ba-4420-a18b-210a0904e0a2 insmod png background_image -m stretch /usr/share/endeavouros/splash.png if [ x$feature_timeout_style = xy ] ; then set timeout_style=menu set timeout=hidden # Fallback normal timeout code in case the timeout_style feature is # unavailable. else set timeout=hidden fi ### END /etc/grub.d/00_header ### ### BEGIN /etc/grub.d/10_linux ### ### END /etc/grub.d/10_linux ### ### BEGIN /etc/grub.d/20_linux_xen ### ### END /etc/grub.d/20_linux_xen ### ### BEGIN /etc/grub.d/30_os-prober ### ### END /etc/grub.d/30_os-prober ### ### BEGIN /etc/grub.d/30_uefi-firmware ### if [ "$grub_platform" = "efi" ]; then fwsetup --is-supported if [ "$?" = 0 ]; then menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' { fwsetup } fi fi ### END /etc/grub.d/30_uefi-firmware ### ### BEGIN /etc/grub.d/35_fwupd ### ### END /etc/grub.d/35_fwupd ### ### BEGIN /etc/grub.d/40_custom ### # This file provides an easy way to add custom menu entries. Simply type the # menu entries you want to add after this comment. Be careful not to change # the 'exec tail' line above. ### END /etc/grub.d/40_custom ### ### BEGIN /etc/grub.d/41_custom ### if [ -f ${config_directory}/custom.cfg ]; then source ${config_directory}/custom.cfg elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then source $prefix/custom.cfg fi ### END /etc/grub.d/41_custom ###
Can we see what you currently have in /etc/default/grub?
Did you update grub afterwords.
I have set these following values
GRUB_TIMEOUT=“0”
GRUB_TIMEOUT_STYLE=“hidden”
in /etc/default/grub.
You would need to run sudo grub-mkconfig -o /boot/grub/grub.cfg after editing this file.
For me, this hides effectively the Grub boot menu and starts the boot process without any delay.
I followed your suggestions, no change. I am running in Legacy mode is this a factor?
I don’t think the boot mode should make any difference… not sure why it is not working for you.
Could you post this?
Better to use this and post the url link. ![]()
cat /etc/default/grub | eos-sendlog
This is the only way we’ll really know. . . as long as they updated grub after.
RUB_BACKGROUND="/usr/share/endeavouros/splash.png"
GRUB_DEFAULT="0"
GRUB_DISABLE_RECOVERY="true"
GRUB_DISABLE_SUBMENU="false"
GRUB_TIMEOUT="hidden"
GRUB_CMDLINE_LINUX_DEFAULT="quiet nowatchdog nvme_load=YES"
GRUB_DISTRIBUTOR="EndeavourOS"
This not exactly what I suggested ![]()
Is this a new install? You are probably using systemd-boot, not grub.
Have you tried changing the timeout in /efi/loader/loader.conf to 0?
