I think that, by now, I should know the answer to this question, but I don’t. Rather than make a mistake, I thought I’d ask. I apologize if this is answered elsewhere that I missed, or otherwise…
My system is a relatively recent, EnOS standard install. It boots from the grub menu, but uses dracut during normal yay updates.
I notice that there is a new grub update that will install to my system when I update. My question: Is there still a need to run the old sudo grub-install … and sudo grub-mkconfig … commands post-update?
Thanks, @dalto. I simply didn’t know whether running those commands or not would adversely impact my system. I appreciate and certainly will take your guidance on this!
Edit to update result: I updated with yay and ran the above two commands. Everything went smoothly into this fresh and uneventful boot. Again, thanks!
I wrote this support note which will help you create a hook to automatically update the grub configuration, everytime the grub packages is updated. I think this might help you with your system maintenance:
Create a System Hook to update Grub
When the Grub Boot Manager package is updated, you are required to manually execute the “grub-install” and then update configuration “grub-mkconfig -o /boot/grub/grub.cfg” commands manually. By creating the below system hook, anytime the grub package is updated it will self update.
Create Hook in “/etc/pacman.d/hooks” called “update-grub-config.hook”.
The following paths are commented out with their default values listed.
If you wish to use different paths, uncomment and update the paths.
… #HookDir = /etc/pacman.d/hooks/
Unless you change the hooks directory from the default, ther is no need to uncomment the line.
