kwg
December 25, 2020, 11:05pm
21
anon37112038:
one ugly battery icon
Lemon:
huge battery icon
To make the battery icon smaller, open this file in a text editor:
~/.config/gtk-3.0/gtk.css
Then add this code:
#xfce4-power-manager-plugin image {
-gtk-icon-transform: scale(0.75);
Finally, save the file and redraw the panel:
xfce4-panel -r
Edit: It’s possible to transform the other tray icons, as well. For example,
#xfce4-notification-plugin image {
-gtk-icon-transform: scale(0.85) translateY(3px);
#pulseaudio-button image {
-gtk-icon-transform: scale(0.9);
Many thanks but I will replace it with something more my style.
mbod
December 26, 2020, 8:40am
23
It happens here also with with Adapta, Materia or Matcha theme.
ed0
December 26, 2020, 9:38am
24
Thank you very much, this fixes it in such a graceful way!!
Lemon
December 26, 2020, 9:58am
25
Thanks, this worked, I had to make this file since it didn’t exist.
(Quite annoying that I wasn’t able to find this solution myself… )
You can alter the button position by turning off DialogsUseHeader in XFCE settings
what would it be for the BT icon?
would be nice to re-setup our XFCE4 theming to include this enhancements, if you have time join me to do so!
It seems that mileage may vary. My battery icon on Xfce 4.16 is of normal size and i’ve no visual glitches on Thunar. But i do not use Arc Theme, i use Greybird Theme with Adwaita icons.
Visual Glitch exists here with Thunar/xfce 4.16 using Adapta-Maia Theme and Papirus-Maia icons. It is only in Thunar, so not a big deal for me.
kwg
December 27, 2020, 12:12am
30
Unfortunately, my EndeavourOS computer doesn’t support Bluetooth, so a Bluetooth icon doesn’t appear on my Xfce panel. In particular, I don’t know the name of the Bluetooth icon, so I can’t reference it in a GTK+/CSS selector.
I’m a bit overwhelmed with work and other obligations at the moment, but I did find the time today to write a tutorial that explains the approach I use when I want to resize, reposition or otherwise transform an Xfce panel icon:
Online documentation for transforming icons (and other objects) on the Xfce panel is a bit hard to find. In this post, I’ll demonstrate an approach to this task with an example: We’ll transform the power manager (“battery”) icon in the system tray. The end result won’t be pretty, but we’ll have explored some of the GTK+ transforms available to us.
First, let’s quit the panel and restart it in GTK interactive debug mode:
xfce4-panel -q && GTK_DEBUG=interactive xfce4-panel
(Ignore any errors an…
Back to topic: What about the graphic glitch? Downgrade Thunar cannot be the only solution.
Has anyone reported it to the Xfce devs?
how does it work?
I don’t have it installed anymore at the moment, and I don’t have a screenshot of it.
I can’t duplicate the problem so far, so a report from me would be rather useless!
Is that because you got some fancy conkies going on?
I doubt that’s it The only glitch I have is reverse scaling still. Must be the themes or icon sets messing up for others…
kwg
December 27, 2020, 1:52am
37
The bug has already been reported here:
anon59358842:
how does it work?
You can check for open issues here:
https://docs.xfce.org/xfce/thunar/bugs
You can create an Xfce Gitlab account here:
Signing in with your new account, you’ll have new-user permissions, which are sufficient to submit a bug report.
Welcome to Xfce's Gitlab
Your original post above includes a screenshot.
From what i just read it’s going to be fixed in the next release if i read this right?
kwg
December 27, 2020, 4:36am
39
Yes, that’s my interpretation, too.
Fixed for master and 4.16 branch, to be released in 4.16.1 and 4.17.0.
I doesn’t look too bad if you can hide it.
