linesma
December 8, 2020, 12:28pm
41
I am reaching the limits of my knowledge. At this point, I wonder if your GPU is having issues. I am thinking one of two things.
First, I would add a kernel parameter and seeing if that helps.
You can do this by:
Press “E” on the grub screen and find the line with the “quiet” parameter.
Replace the word “quiet” with acpi_osi='Windows 2018' you need.
Press F-10 to boot your computer.
Notice that the quotation marks around Windows 2018 are single ticks.
The second thing I would try is removing any nVidia config files, remove any blacklisting, turning your PC off, removing your nVidia GPU and doing a reboot.
Maybe try just disconnect everything from GPU and it from motherboard, then connect again, just in case…
Oven though…
@Oziach sorry, missed it
Oziach
December 8, 2020, 12:37pm
43
Nope, booted into this rn, same thing, except the performance of the whole system is abysmal.
@keybreak I did mention I tried reseating. I do have the time right now to completely take apart and put together the whole system – would do it good to replace the thermal paste on the CPU, as it has been roughly a year for it.
linesma
December 8, 2020, 12:45pm
44
Oziach:
booted into this rn
I do not understand. Did you boot into the system without the nVidia GPU installed? Despite the performance being low, was it stable? What did inxi -G say? I am trying to see if it is the nVidia GPU.
It could not hurt, but I do not think thermal paste is your issue.
Well, I am sorry. At this point we are out of my knowledge zone.
Oziach
December 8, 2020, 12:47pm
45
Sorry, with the acpi_osi='Windows 2018' is what I meant and that inxi -G says the same exact thing.
I know it’s not, but I’m just trying to hype myself up to do it.
Can you return inxi -Fxxxza --no-host?
Oziach
December 8, 2020, 12:49pm
47
$ inxi -Fxxxza --no-host
Kernel: 5.9.12-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=db231805-d44a-4176-9e12-2531ea10f116 rw "acpi_osi=Windows 2018"
loglevel=3 nowatchdog
Desktop: Budgie 10.5.1 info: budgie-panel wm: budgie-wm
dm: GDM 3.38.2, LightDM 1.30.0 Distro: EndeavourOS
Type: Desktop Mobo: ASRock model: AB350M Pro4 serial: <filter>
UEFI: American Megatrends v: P4.90 date: 07/06/2018
Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
bits: 64 type: MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: N/A microcode: 810100B L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 27956
Speed: 1515 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz):
1: 2205 2: 1680 3: 1492 4: 1530
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 10:00.0
chip ID: 10de:1c03
Display: x11 server: X.org 1.20.10 compositor: budgie-wm
driver: modesetting FAILED: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.3.0
compat-v: 3.1 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 10:00.1 chip ID: 10de:10f1
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 38:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.12-arch1-1
vendor: ASRock driver: r8169 v: kernel modules: r8168 port: e000
bus ID: 1f:00.0 chip ID: 10ec:8168
IF: enp31s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.27 TiB used: 8.26 GiB (0.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 211070WD scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw size: 465.21 GiB size: 456.91 GiB (98.22%)
used: 8.26 GiB (1.8%) fs: ext4 dev: /dev/sda2
Alert: No Swap data was found.
System Temperatures: cpu: 55.9 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 9%
Processes: 210 Uptime: 15m wakeups: 0 Memory: 15.63 GiB
used: 2.02 GiB (12.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 975 lib: 285 Shell: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.09
I did it in Grub exactly like posted though.
**This is disabled in BIOS yes? I have a feeling your integrated GPU is not playing nice with the Nvidia card.
linesma
December 8, 2020, 12:57pm
49
No The acpi parameter should look like acpi_='Windows 2018' Single ticks not quotation marks.
Oziach
December 8, 2020, 12:58pm
50
Yes, that’s what I did. Not sure why it went to quotation marks.
@anon53396576 It was playing nice for ages though. Let me figure out how to disable it and boot into that.
linesma
December 8, 2020, 1:00pm
51
Double check. It is highlighted in red because it is not being applied. the single ticks are only around the Windows 2018.
Oziach
December 8, 2020, 1:04pm
52
Yes, that is exactly how I did it. acpi_osi='Windows 2018'
Little off-topic, but still since it was asked about UEFI i have re-read some stuff …Jeez
Oziach
December 8, 2020, 1:08pm
54
Shameless of me to tag my post as a solution, but I can summarize the topic. Every person in this thread was a big help!!!
GPU:
It WAS set to Disabled.
http://forum.asrock.com/forum_posts.asp?TID=8503&title=disabling-integrated-graphics-card
^^^ Followed the instructions on this thread:
BIOS Path: Advanced > AMD CBS > NBIO Common Options > GFX Configuration
1. Set the Integrated Graphics Controller to Forces.
2. Set the UMA Mode to UMA_SPECIFIED.
3. Set the UMA Frame Buffer Size to 64M.
4. Press [F10] save and exit.
These BIOS parameters for my specific motherboard fixed the drivers issue I was having.
$ inxi -G
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 455.45.01
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
driver: amdgpu v: kernel
Display: x11 server: X.org 1.20.10 driver: nvidia
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
Grub:
I’m just a dingdong and messed something up down the road of me using the system. Manual partitioning on a empty drive fixes the issue flawlessly.
@all,
Please review the following. Here is how I would do it:
Go into firmware settings and disable CSM. Like that the USB will boot automatically in UEFI mode.
In the live session, launch Gparted and create a new partition table on the /dev/sda >> GPT
Either let the installer (Calamares) do an automatic install on the /dev/sda
or
use Gparted to pre-partition the disk: one 512 Mib FAT32 at the beginning of the the disk, flagged as esp,boot, the rest EXT4 for the / (root partition).…
linesma
December 8, 2020, 1:10pm
55
I was just making sure.
It looks like it is now using the Geforce card. How is the performance?
Oziach
December 8, 2020, 1:11pm
56
I don’t know, I’m going to attempt to boot into my main system and play a game.
Oziach
December 8, 2020, 1:34pm
57
Better than it has been in months, wtf
Let me reboot like 10 times to see if it persists.
$ inxi -G
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 455.45.01
Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia
resolution: 1920x1080~60Hz
btw
So what exactly have you done in the end to fix?
Oziach
December 8, 2020, 1:43pm
60
Oziach:
It WAS Disabled. I don’t even remember doing it.
ASRock Forums
Followed the instructions on this thread, just so it’d be something different. Now it boots into:
$ inxi -G
I honestly don’t even know what it’s using now.
What @anon53396576 suggested, just backwards. Essentially, reenabled the iGPU, which was disabled for many many months for whatever reason.
It could’ve gotten disabled by default, or got disabled when I was reflashing my BIOS many times. I’m honestly not sure.
