This is a sequel to Xrandr: Failed to get size of gamma for output default Apologies to @linesma for taking up his time, as I failed to really figure out what is the problem before asking.
Sometimes booting up into my system starts up the GPU (1060 6GB) just fine, sometimes it doesn’t, hence why the odd, regular restart did the trick. I’ve tried reinstalling the drivers many times, tried reseating the GPU and whatever else I thought of in the last two days. I don’t have a second Nvidia GPU to check if it’s an issue with my motherboard or another motherboard to see if it’s an issue with my GPU.
I can’t manually uninstall the drivers on the main installation, because they’re a dependency for Steam and things, which are dependencies for a bunch of other things…
I can’t even install a second, clean instance of Endeavour on a separate drive, to check if it’s an issue with the operating system, because Grub doesn’t want to work. This is what I get:
Installation Failed
Boost.Python error in job "bootloader"
Command 'grub-install --target=i386-pc --recheck --force /dev/nvme0n1' returned non-zero exit status 1.
Installing for i386-pc platform. grub-install: warning: this GPT partition label contains no BIOS Boot Partition; embedding won't be possible. grub-install: error: embedding is not possible, but this is required for cross-disk install.
Traceback:
File "/usr/lib/calamares/modules/bootloader/main.py", line 485, in run prepare_bootloader(fw_type)
File "/usr/lib/calamares/modules/bootloader.main.py", line 457, in prepare_bootloader install_grub(efi_directory, fw_type)
File "/usr/lib/calamares/modules/bootloader.main.py", line 362, in install_grub check_target_env_call(libcalamares.job.configuration["grubInstall"],
File "<string>", line 6, in <module>
Manually updating Grub on the main install and booting into it throws me into a CLI, that I can log into and do whatever.
Installing the bootloader onto the same drive, again manually updating Grub from my main installation, then booting into it just throws me into the same CLI. I did install Nvidia drivers through Calamares both times, though doubt that’s relevant with this.
I honestly don’t know what to do or how to even begin fixing it. I’m just about ready to chuck the damn thing out the window and forget about technology all together. I’m not good at it.
Fixing Grub would be my first priority, any steps to troubleshoot this and get the system stable would be greatly appreciated.
Cheers
