GNOME will not change to dark theme
Hello all.
I just installed EOS with GNOME, so this is a clean install. When switching between light and dark theme from settings, there is no change.
I went into special settings and set older programs to Adwita-dark, and this is what I get
I am still researching this topic, but one of the solution is to try to force dark theme:
gsettings set org.gnome.desktop.interface color-scheme 'prefer-dark'
which didn’t do anything.
I am not big on light theme, and prefer dark, so if someone has an idea of what to do or where to look, please let me know. I am totally fine with default GNOME dark theme :slight_smile:
OK, little progress, it seems that user theme for GNOME shell is not installed or not running.
I have not been able to find user theme for GNOME shell in AUR, and I have not been able to install it directly from browser. I have never been able to enable extension by downloading it from GNOME extensions.
Take a look at itsfoss.
I don’t use gnome but i found this on the fly. May it help you with your installation
It seems to be identical to this problem:
then install this:
sudo pacman -S xdg-desktop-portal-gnome xdg-desktop-portal
That’s it!!! :partying_face: Thanky very much :slight_smile:
