I was trying to install sayonara-player-git and it failed at the very end with 0% test passed out of 42.
I went to log file and the problem seems to be
anaconda3/lib/libstdc++.so.6: version `GLIBCXX_3.4.29’ not found
It seems I messed up with anaconda installation, because when I tried
strings /usr/lib/libstdc++.so.6 | grep GLIBCXX_3.4.29
I got
GLIBCXX_3.4.29
GLIBCXX_3.4.29
And nothing for anaconda folder.
strings /anaconda/lib/libstdc++.so.6 | grep GLIBCXX_3.4.29
How can I fix this? Should I reinstall anaconda? Should I somehow navigate the tests to usr/lib?
krakenbite:
sayonara-player-git
I’m trying to build it right now but i don’t have anaconda on my system.This takes quite a while it’s at 72% and still building?
Edit: I don’t know what file this is GLIBCXX_3.4.29
I was actually building sayonara-player, but I don’t think it matters.
Yes, it does take a while.
But it goes to the very end for me it’s just the tests that give the error, and I think it’s because of anaconda.
Why it uses the anaconda/lib/ folder and not usr/lib/ - IDK, I guess I messed up when I installed anaconda
The file is there on mine i just checked.
[ricklinux@eos-kde ~]$ strings /usr/lib/libstdc++.so.6 | grep GLIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBCXX_3.4.21
GLIBCXX_3.4.22
GLIBCXX_3.4.23
GLIBCXX_3.4.24
GLIBCXX_3.4.25
GLIBCXX_3.4.26
GLIBCXX_3.4.27
GLIBCXX_3.4.28
GLIBCXX_3.4.29
GLIBCXX_DEBUG_MESSAGE_LENGTH
_ZNKSt14basic_ifstreamIcSt11char_traitsIcEE7is_openEv@GLIBCXX_3.4
_ZNSt13basic_istreamIwSt11char_traitsIwEE6ignoreEv@@GLIBCXX_3.4.5
_ZNKSbIwSt11char_traitsIwESaIwEE11_M_disjunctEPKw@GLIBCXX_3.4
_ZNKSt14basic_ifstreamIwSt11char_traitsIwEE7is_openEv@@GLIBCXX_3.4.5
GLIBCXX_3.4.21
GLIBCXX_3.4.9
_ZSt10adopt_lock@@GLIBCXX_3.4.11
GLIBCXX_3.4.10
GLIBCXX_3.4.16
GLIBCXX_3.4.1
_ZNSt19istreambuf_iteratorIcSt11char_traitsIcEEppEv@GLIBCXX_3.4
GLIBCXX_3.4.28
_ZNSs7_M_copyEPcPKcm@GLIBCXX_3.4
GLIBCXX_3.4.25
_ZNSt19istreambuf_iteratorIcSt11char_traitsIcEEppEv@@GLIBCXX_3.4.5
_ZNSs7_M_moveEPcPKcm@@GLIBCXX_3.4.5
_ZNKSt13basic_fstreamIwSt11char_traitsIwEE7is_openEv@GLIBCXX_3.4
_ZNKSt13basic_fstreamIcSt11char_traitsIcEE7is_openEv@GLIBCXX_3.4
_ZNSbIwSt11char_traitsIwESaIwEE4_Rep26_M_set_length_and_sharableEm@@GLIBCXX_3.4.5
_ZNSs4_Rep26_M_set_length_and_sharableEm@GLIBCXX_3.4
_ZSt10defer_lock@@GLIBCXX_3.4.11
_ZN10__gnu_norm15_List_node_base4swapERS0_S1_@@GLIBCXX_3.4
_ZNSs9_M_assignEPcmc@@GLIBCXX_3.4.5
_ZNKSbIwSt11char_traitsIwESaIwEE15_M_check_lengthEmmPKc@@GLIBCXX_3.4.5
_ZNKSt14basic_ifstreamIcSt11char_traitsIcEE7is_openEv@@GLIBCXX_3.4.5
_ZNSbIwSt11char_traitsIwESaIwEE7_M_moveEPwPKwm@GLIBCXX_3.4
GLIBCXX_3.4.24
_ZNVSt9__atomic011atomic_flag12test_and_setESt12memory_order@@GLIBCXX_3.4.11
GLIBCXX_3.4.20
_ZNSt11char_traitsIwE2eqERKwS2_@@GLIBCXX_3.4.5
GLIBCXX_3.4.12
_ZNSi6ignoreEv@@GLIBCXX_3.4.5
GLIBCXX_3.4.2
_ZNSt11char_traitsIcE2eqERKcS2_@@GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.15
_ZNKSt13basic_fstreamIcSt11char_traitsIcEE7is_openEv@@GLIBCXX_3.4.5
_ZNSs9_M_assignEPcmc@GLIBCXX_3.4
GLIBCXX_3.4.19
_ZNKSt14basic_ofstreamIwSt11char_traitsIwEE7is_openEv@GLIBCXX_3.4
_ZNSt19istreambuf_iteratorIwSt11char_traitsIwEEppEv@GLIBCXX_3.4
GLIBCXX_3.4.27
_ZN10__gnu_norm15_List_node_base7reverseEv@@GLIBCXX_3.4
_ZN10__gnu_norm15_List_node_base4hookEPS0_@@GLIBCXX_3.4
_ZNSt11char_traitsIwE2eqERKwS2_@GLIBCXX_3.4
_ZNSbIwSt11char_traitsIwESaIwEE7_M_copyEPwPKwm@GLIBCXX_3.4
_ZNSbIwSt11char_traitsIwESaIwEE7_M_copyEPwPKwm@@GLIBCXX_3.4.5
GLIBCXX_3.4.23
GLIBCXX_3.4.3
GLIBCXX_3.4.7
_ZNSi6ignoreEl@@GLIBCXX_3.4.5
_ZNKSbIwSt11char_traitsIwESaIwEE11_M_disjunctEPKw@@GLIBCXX_3.4.5
_ZNSt13basic_istreamIwSt11char_traitsIwEE6ignoreEv@GLIBCXX_3.4
_ZNKSt13basic_fstreamIwSt11char_traitsIwEE7is_openEv@@GLIBCXX_3.4.5
_ZNSbIwSt11char_traitsIwESaIwEE7_M_moveEPwPKwm@@GLIBCXX_3.4.5
GLIBCXX_3.4.18
_ZNSbIwSt11char_traitsIwESaIwEE4_Rep26_M_set_length_and_sharableEm@GLIBCXX_3.4
_ZNSt13basic_istreamIwSt11char_traitsIwEE6ignoreEl@@GLIBCXX_3.4.5
_ZSt15future_category@@GLIBCXX_3.4.14
_ZNSi6ignoreEl@GLIBCXX_3.4
GLIBCXX_3.4.29
_ZNSt11char_traitsIcE2eqERKcS2_@GLIBCXX_3.4
_ZNKSs15_M_check_lengthEmmPKc@GLIBCXX_3.4
_ZN10__gnu_norm15_List_node_base8transferEPS0_S1_@@GLIBCXX_3.4
_ZNSbIwSt11char_traitsIwESaIwEE9_M_assignEPwmw@GLIBCXX_3.4
_ZNVSt9__atomic011atomic_flag5clearESt12memory_order@@GLIBCXX_3.4.11
_ZNKSt14basic_ofstreamIcSt11char_traitsIcEE7is_openEv@@GLIBCXX_3.4.5
_ZNKSt14basic_ofstreamIcSt11char_traitsIcEE7is_openEv@GLIBCXX_3.4
_ZNSs7_M_moveEPcPKcm@GLIBCXX_3.4
_ZNSt13basic_istreamIwSt11char_traitsIwEE6ignoreEl@GLIBCXX_3.4
_ZNSbIwSt11char_traitsIwESaIwEE9_M_assignEPwmw@@GLIBCXX_3.4.5
_ZNKSbIwSt11char_traitsIwESaIwEE15_M_check_lengthEmmPKc@GLIBCXX_3.4
_ZNKSs11_M_disjunctEPKc@@GLIBCXX_3.4.5
_ZN10__gnu_norm15_List_node_base6unhookEv@@GLIBCXX_3.4
GLIBCXX_3.4.22
_ZNSt19istreambuf_iteratorIwSt11char_traitsIwEEppEv@@GLIBCXX_3.4.5
_ZNSi6ignoreEv@GLIBCXX_3.4
_ZNSs7_M_copyEPcPKcm@@GLIBCXX_3.4.5
GLIBCXX_3.4.8
GLIBCXX_3.4.13
_ZSt11try_to_lock@@GLIBCXX_3.4.11
_ZNKSt14basic_ofstreamIwSt11char_traitsIwEE7is_openEv@@GLIBCXX_3.4.5
GLIBCXX_3.4.17
GLIBCXX_3.4.4
_ZNKSs15_M_check_lengthEmmPKc@@GLIBCXX_3.4.5
_ZNKSt14basic_ifstreamIwSt11char_traitsIwEE7is_openEv@GLIBCXX_3.4
_ZNSs4_Rep26_M_set_length_and_sharableEm@@GLIBCXX_3.4.5
GLIBCXX_3.4.26
_ZNKSs11_M_disjunctEPKc@GLIBCXX_3.4
I think you may be right that it’s picked up the path?
I have the same as you in /usr/lib and only up to .28 in the anaconda folder
strings libstdc++.so.6 | grep GLIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBCXX_3.4.21
GLIBCXX_3.4.22
GLIBCXX_3.4.23
GLIBCXX_3.4.24
GLIBCXX_3.4.25
GLIBCXX_3.4.26
GLIBCXX_3.4.27
GLIBCXX_3.4.28
I don’t know anything about anaconda but obviously it’s trying to build and looks to that path as opposed to /usr/lib/libstdc++.so.6
When you try to build it are you using yay?
I used yay and just press enter on every prompt? But as i say i don’t have anaconda installed.
I went to cmake-gui and checked PATH in Environment Editor and it goes to anaconda instead of /usr/lib… not sure how to properly change it now.
/home/qq/anaconda3/bin:/home/qq/anaconda3/condabin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
You can edit the package build and change it. I don’t do a lot of that but i don’t think it’s too difficult.
I don’t think it depends on packagebuild file, does it? I feel like I need to properly switch PATH in cmake gui froom anaconda3 folder to /usr/lib/…
That’s what i said? When you run the package build with cmake you should be able to edit the package build.
Edit: I was thinking more of using yay doing it?
no issue here with build and install on yay
So that file comes from libstdc++6 then. So it was only finding it in anaconda because it wasn’t in the other path?
Yeah, it’s just a redirection from usr/lib/ to the file that cmake uses.
I probably should have installed anaconda differently.
Or, build packages against the system libraries rather than polluting them with another package manager and software ecosystem.
https://wiki.archlinux.org/title/DeveloperWiki:Building_in_a_clean_chroot
I’m not that familiar with linux, so when installing anaconda I followed their instructions…
Do I need to make a clean chroot every time I install a package?
I don’t think that is what was meant. @jonathon can correct me if I’m wrong.
