I did a lot of research and tried many things the last hours but I did not get any solution. Every time I want to start the OS I get the following message:
Hello @derbusfahrer
I just wanted to ask how you created the live usb?
Edit: Iâm also curious which model of acer aspire it is? There are a couple of things i would check. I would suggest checking the UEFI Bios and see it it is set to AHCI mode for the drives or not? I would also clear the Secure Boot keys. You probably have to enable it first and then remove the keys and then disable secure boot again.
I created the live usb like described in the official wiki.
This the Aspire 5 A514-54. I did not find an option that concernd AHCI and I just disabled secure boot without clearing the keys because at this point I wasnt sure if I could break something.
@derbusfahrer
If you are able to boot on the live ISO and post the link to this command. I can look at the hardware to start.
inxi -Faz --no-host | eos-sendlog
You said you currently have Windows installed and you just tried again to install EOS. Are you using the existing efi partition on Windows or manually creating one for the EOS install with other partitions or letting the installer do it?
Ok forgive me if I have overlooked it but what are you using for install media? Maybe try something else or a different distro just for testing to see if you have a bad image?
When I first tried to install EOS besides Windows I used default options. At the second attempt I partioned it manually.
I also checked fstab and the UUID was allways correct.
And now I am not even able to enter the BIOS menu because only the acer logo shows up. I probably have to reset CMOS first. Never thought this would be so difficult.
@derbusfahrer
If the above doesnât work then you will have to disable Intel VMD in the Bios somewhere. But, this has been done before on lots of distros so it should work fine.
Edit: I think if you have it installed and make the changes it should boot.
