Forced to reload sites to view also problem terminal connection
Hello,
I am so sorry I think I missed some threads like this one:
The below can probably be ignored I will start digging in these threads instead!
Since an update a few weeks ago I have this strange issue where when I first enter a website on either Chrome on Waterfox I get: “Unable to connect” but the solution is simple I just need to reload a page with F5 anywhere between 3-5 times and then it works perfectly for the rest of the computer session, the problem for that particular site sometimes comes back same session but often it happens after the shutdown and power on the next morning.
Sometimes the CSS breaks independently but I assume that happens when the CSS is located on a different server somewhere.
I have the same problem in the terminal where ‘yay’ command cant find certain packages but if I rerun ‘yay’ it ends up being able to grab it no problem all of a sudden and once it gets going it never fails it downloads the whole package with the expected usual speed.
I have been searching the net but I cannot for the life of me find anyone with same problem.
Closest to my problem I got was someone who had something slightly similar and the tip was to flushing the DNS on the related systemd service, which I did, but that did not solve it either. (If I recall correctly that service was not even running at the time so I just had to start it and then flush it LOL)
Any idea of where to start what logs and where to find the logs I should be looking at?
There is this topic
About internet problems, the solution given is to update the kernel(s), so maybe this might help.
Been testing (manually just spamming the address window in Waterfox Haha very basic) for a few minutes after yay -Syu and it seems to load it all.
I will mark as solved!
