First development test ISO for Sway Community Edition installs
touchpad works on my T420
error: target not found: lxapperance
not the mouse error but a typo inside netinstall.yaml:
community/lxappearance 0.6.3-4 (90.3 KiB 395.3 KiB) [lxde]
    Feature-rich GTK+ theme switcher of the LXDE Desktop
So I like a tidy journal. Saw a few errors.
Feb 23 06:53:11 elloquin systemd[853]: Failed to start Portal service (wlroots implementation).
β–‘β–‘ Subject: A start job for unit UNIT has failed
β–‘β–‘ Defined-By: systemd
β–‘β–‘ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
β–‘β–‘
β–‘β–‘ A start job for unit UNIT has finished with a failure.
β–‘β–‘
β–‘β–‘ The job identifier is 279 and the job result is failed.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 296 and the job result is failed.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 313 and the job result is failed.
Feb 23 06:53:12 elloquin systemd[853]: Failed to start Portal service (wlroots implementation).
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 330 and the job result is failed.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 347 and the job result is failed.
β–‘β–‘
A little searching later and apparently a pipewire error. Decided to try and resolve by installing pipewire-pulse and pipewire-alsa.
Now:
Feb 23 10:24:43 elloquin pipewire-media-session[989]: GetManagedObjects() failed: org.freedesktop.DBus.Error.ServiceUnknown
Sound works normally. Despite the errors. Pipewire is relatively new so :man_shrugging:
this errors mostly do not harm it says (most cases)
But pipewire is not installed?
No it is there. The first journal output is with pipewire only. Second is after pipewire-pulse and pipewire-alsa were added. Not really a thing and harmless as everything works. Just digging into things.
edit sorry it was there I replaced it with pipewire-pulse.
You mean it came default? Like with the iso
Yes pipewire was there. I did not add it.
Am I doing this right?
20210223_180438
I do believe you are! Do you mind running pactl info and see what sound engine you are running. It should be PulseAudio…I think pipewire might’ve been installed as a dependency…
pulsaudio
Not trying on the laptop right now but the touchpad worked on it before it was just the usb mouse. Now on qemu the usb mouse doesn’t work.
So what does this mean? It’s fixed now if i try again? I’m assuming this it’s what’s pulled in on the install?
Thank You! My WM died sorry about asking all you guys! Can you check if pipewire is installed…
Not enough purple. :laughing:
pipewire is installed here
Yep! It would be fixed
I blame American English for spelling apperance wrong. :innocent: :laughing:
Purple Bonsai tree… that would be the finishing touch
Got It! It’s because xdg-desktop-portal-wlr has pipewire as a dependency! Phew I thought I was going crazy!
https://archlinux.org/packages/community/x86_64/xdg-desktop-portal-wlr/
Now your talking! I like Bonsai tree and i like purple. :wink:
Edit: Is the new eos tree!
