It’s not that you need to supervise it, it’s that you should be there if you should need to reenter your password.
There is a plugin called “scale”. Then use “ctrl + mouse wheel”.
Entering the password is done at the beginning before I go make myself a drink. I shouldn’t have to enter it twice.
I just turn the sudo password off
My computer, my rules.
Then change you timeout, that simple.
Short of .pacnew files not much. If you are diligent in keeping up on them it shouldn’t be a problem. It could also be said that since what decides to “pacnew” and it could cause log in issues not a bad idea to pay attention. my 2c.
Interesting. I don’t think I’ve ever done that before. I may do that anyway.
I mean, I guess? In my mind I guess if you make something like this that then requires me to make more modifications. Like, in my head it’s hardly a feature at that point. If it’s a problem (it is) then why not just write into the program to extend the time out?
Thanks for this! I’ve installed it but… how do you get it running? Just running systray-x doesn’t do anything for me. Doesn’t show me any errors or anything. Not in my TB add-ons either.
Edit:
Nvm, adding their repo and installing from there fixed it for me.
With pacman and yay, don’t forget you can use the --sudoloop option, which continually polls for your password until you get back to the keyboard and can enter it. Works like a champ.
I still stand by not walking away from the computer while it’s being updated.
And not updating a desktop system without a UPS attached …
Then 97% can NEVER update.
It is actually installed as an add-on to Thunderbird, not as a stand-alone app. So, when you start up Thunderbird after installing, it should automatically reside in the system tray. If not, you may need to go into Thunderbird under ‘add-ons’, find the systray-x extension and click on its properties to get to the settings to enable accordingly.
97% should be looking to invest in a UPS then, particularly running a distro like Arch.
Has saved my bacon on a couple of occasions.
To each their own. There’s no wrong way. I’ll keep multitasking making a drink instead if staring at cascading lines in a TTY waiting to enter my password (again).
What does your Latex setup look like? Also could you explain why it’s a necessity for a physicist to write latex code in a text editor?
My LATEX setup is simply having texlive-most installed (from the repos) and tllocalmgr-git from the AUR to manage CTAN packages. That’s it.
I use Kate (KDE’s Advanced Text Editor) to write LATEX code and I compile it from the command line, typically using either pdflatex or xelatex commands, occasionally context.
It is necessary to write LATEX code in a text editor if you want to do anything remotely complex. You simply cannot do fancy stuff otherwise.
“Bring out the gimp” (c)
