I am stuck on reboot after upgrading nvidia drivers. I’ve tried uninstall and reinstall but it doesn’t work. Here are some logs
Did you see this? Nvidia driver update issue
@mushrooms
If you can boot into a TTY from the failed boot?
ctrl + alt + f2
log in as root and run
mkinitcpio -P
sorry I just logged in with my phone otherwise I would have seen it. Thank you
Hopefully it works for you. I have also added a new hook to go along with the optional enhancements to have mkinitcpio -P run when updating, upgrading or removing.
yes its working. I appreciate your efforts
