Failed to start kernel (lts) modules
My PC has the problem that it doesnt poweroff properly most of the time. I never have found out whats the issue. Most likley it has something to do with systemd.
The last 1-2 years I have had the workaround to use lts-kernels and shut it down with sudo shutdown -h now
Therefore I have installed the linux-lts kernel with sudo pacman -S linux-lts. It seems to work fine but nevertheless I get an error during boot.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
Starting Load Kernel Modules…
[mak@mak-pc ~]$ systemctl
systemctl
  UNIT                        LOAD   ACTIVE SUB       DESCRIPTION
  proc-sys-fs-binfmt_misc.automount loaded active waiting   Arbitrary Executabl>
  sys-devices-pci0000:00-0000:00:03.1-0000:01:00.1-sound-card1.device loaded ac>
  sys-devices-pci0000:00-0000:00:11.0-ata1-host0-target0:0:0-0:0:0:0-block-sda->
  sys-devices-pci0000:00-0000:00:11.0-ata1-host0-target0:0:0-0:0:0:0-block-sda.>
  sys-devices-pci0000:00-0000:00:11.0-ata4-host3-target3:0:0-3:0:0:0-block-sr0.>
  sys-devices-pci0000:00-0000:00:14.2-sound-card0.device loaded active plugged >
  sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-net-wlp3s0.device loaded act>
  sys-devices-pci0000:00-0000:00:15.1-0000:04:00.0-net-enp4s0.device loaded act>
  sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged   /sys>
  sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged   /sys>
  sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged   /sys>
  sys-devices-pnp0-00:08-tty-ttyS0.device loaded active plugged   /sys/devices/>
  sys-devices-virtual-misc-rfkill.device loaded active plugged   /sys/devices/v>
  sys-module-configfs.device  loaded active plugged   /sys/module/configfs
  sys-module-fuse.device      loaded active plugged   /sys/module/fuse
  sys-subsystem-net-devices-enp4s0.device loaded active plugged   QCA8171 Gigab>
  sys-subsystem-net-devices-wlp3s0.device loaded active plugged   AR9287 Wirele>
 ESCOC
IVE SUB       DESCRIPTION
ed active waiting   Arbitrary Executable File
00:01:00.1-sound-card1.device loaded active plugged   Baffin HDMI/DP Audio [Rad
a1-host0-target0:0:0-0:0:0:0-block-sda-sda1.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda-sda2.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda-sda3.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda-sda4.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda-sda5.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda-sda6.device loaded active plugged   Cruc>
a1-host0-target0:0:0-0:0:0:0-block-sda.device loaded active plugged   Crucial_C>
a4-host3-target3:0:0-3:0:0:0-block-sr0.device loaded active plugged   HL-DT-ST_>
und-card0.device loaded active plugged   FCH Azalia Controller
00:03:00.0-net-wlp3s0.device loaded active plugged   AR9287 Wireless Network A
00:04:00.0-net-enp4s0.device loaded active plugged   QCA8171 Gigabit Ethernet
yS1.device loaded active plugged   /sys/devices/platform/ser
yS2.device loaded active plugged   /sys/devices/platform/ser
yS3.device loaded active plugged   /sys/devices/platform/ser
e loaded active plugged   /sys/devices/pnp0/00:08/t
 loaded active plugged   /sys/devices/virtual/misc
 ESCOD
 ESCOD
  -.mount                     loaded active mounted   /
  dev-hugepages.mount         loaded active mounted   Huge Pages File System
  dev-mqueue.mount            loaded active mounted   POSIX Message Queue File
  run-media-mak-mak\x2ddisk.mount loaded active mounted   /run/media/mak/mak-di>
  run-user-1001-gvfs.mount    loaded active mounted   /run/user/1001/gvfs
  run-user-1001.mount         loaded active mounted   /run/user/1001
  sys-fs-fuse-connections.mount loaded active mounted   FUSE Control File Syste>
  sys-kernel-config.mount     loaded active mounted   Kernel Configuration File
  sys-kernel-debug.mount      loaded active mounted   Kernel Debug File System
  tmp.mount                   loaded active mounted   /tmp
  systemd-ask-password-console.path loaded active waiting   Dispatch Password R>
  systemd-ask-password-wall.path loaded active waiting   Forward Password Reque>
  init.scope                  loaded active running   System and Service Manage
  session-1.scope             loaded active running   Session 1 of user mak
  accounts-daemon.service     loaded active running   Accounts Service
  avahi-daemon.service        loaded active running   Avahi mDNS/DNS-SD Stack
  colord.service              loaded active running   Manage, Install and Gener
  dbus.service                loaded active running   D-Bus System Message Bus
  gdm.service                 loaded active running   GNOME Display Manager
  kmod-static-nodes.service   loaded active exited    Create list of required s
  lvm2-lvmetad.service        loaded active running   LVM2 metadata daemon
  lvm2-monitor.service        loaded active exited    Monitoring of LVM2 mirror
  NetworkManager.service      loaded active running   Network Manager
  polkit.service              loaded active running   Authorization Manager
  rtkit-daemon.service        loaded active running   RealtimeKit Scheduling Po
  systemd-fsck@dev-disk-by\x2duuid-7A06\x2dD85D.service loaded active exited   >
  systemd-journal-flush.service loaded active exited    Flush Journal to Persis>
  systemd-journald.service    loaded active running   Journal Service
  systemd-logind.service      loaded active running   Login Service
● systemd-modules-load.service loaded failed failed    Load Kernel Modules
  systemd-random-seed.service loaded active exited    Load/Save Random Seed
  systemd-remount-fs.service  loaded active exited    Remount Root and Kernel F
  systemd-sysctl.service      loaded active exited    Apply Kernel Variables
  systemd-tmpfiles-setup-dev.service loaded active exited    Create Static Devi>
  systemd-tmpfiles-setup.service loaded active exited    Create Volatile Files >
  systemd-udev-trigger.service loaded active exited    udev Coldplug all Devices
  systemd-udevd.service       loaded active running   udev Kernel Device Manage
  systemd-update-utmp.service loaded active exited    Update UTMP about System
  systemd-user-sessions.service loaded active exited    Permit User Sessions   >
  udisks2.service             loaded active running   Disk Manager
  upower.service              loaded active running   Daemon for power manageme
  user-runtime-dir@1001.service loaded active exited    User Runtime Directory >
  user@1001.service           loaded active running   User Manager for UID 1001
  wpa_supplicant.service      loaded active running   WPA supplicant
  -.slice                     loaded active active    Root Slice
  system-getty.slice          loaded active active    system-getty.slice
  system-systemd\x2dfsck.slice loaded active active    system-systemd\x2dfsck.sl
  system.slice                loaded active active    System Slice
  user-1001.slice             loaded active active    User Slice of UID 1001
  user.slice                  loaded active active    User and Session Slice
  avahi-daemon.socket         loaded active running   Avahi mDNS/DNS-SD Stack A
  dbus.socket                 loaded active running   D-Bus System Message Bus
  dm-event.socket             loaded active listening Device-mapper event daemo
  lvm2-lvmetad.socket         loaded active running   LVM2 metadata daemon sock
  lvm2-lvmpolld.socket        loaded active listening LVM2 poll daemon socket
  systemd-coredump.socket     loaded active listening Process Core Dump Socket
  systemd-initctl.socket      loaded active listening initctl Compatibility Nam
  systemd-journald-dev-log.socket loaded active running   Journal Socket (/dev/>
  systemd-journald.socket     loaded active running   Journal Socket
  systemd-rfkill.socket       loaded active listening Load/Save RF Kill Switch
  systemd-udevd-control.socket loaded active running   udev Control Socket
  systemd-udevd-kernel.socket loaded active running   udev Kernel Socket
  basic.target                loaded active active    Basic System
  cryptsetup.target           loaded active active    Local Encrypted Volumes
  getty.target                loaded active active    Login Prompts
  graphical.target            loaded active active    Graphical Interface
  local-fs-pre.target         loaded active active    Local File Systems (Pre)
  local-fs.target             loaded active active    Local File Systems
  multi-user.target           loaded active active    Multi-User System
  network.target              loaded active active    Network
  nss-user-lookup.target      loaded active active    User and Group Name Looku
  paths.target                loaded active active    Paths
  remote-fs.target            loaded active active    Remote File Systems
  slices.target               loaded active active    Slices
  sockets.target              loaded active active    Sockets
  sound.target                loaded active active    Sound Card
  swap.target                 loaded active active    Swap
  sysinit.target              loaded active active    System Initialization
  timers.target               loaded active active    Timers
  logrotate.timer             loaded active waiting   Daily rotation of log fil
  man-db.timer                loaded active waiting   Daily man-db regeneration
  pamac-cleancache.timer      loaded active waiting   Monthly clean packages ca
  shadow.timer                loaded active waiting   Daily verification of pas
  systemd-tmpfiles-clean.timer loaded active waiting   Daily Cleanup of Temporar
  updatedb.timer              loaded active waiting   Daily locate database upd
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
107 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
I dont understand this stuff, therefore I wanted to ask if I have to worry about something?
you did pacman -S linux-lts, i do gues you updated the grub and mkinitcpio -P. i think there is some drivers installed in your system that you dont need. if you not have a broadcom probably that gives there error if you have something as virtualbox modules installled but it doesnt have the lts modules you can get some error. does not say systemd brake or kernel. just you dont have lts compiled package or not using dkms package in combination to use with the kernels headers files…to generate the kernel compatible modules. is just like that i gues. you have to see what you have. i cant tel , also looked half of the errer list :slight_smile:
its just modules that already is installed dont fit with the lts module or its not a dkms with no linux-lts-headers. if you have two kernels or 3 installed i would pick the dkms modules also the kernels headers.
i think broadcom-wl driver is installed standard, its only for the ‘linux’ kernel i guess you have to review, also virtualbox related package eventually ?
Check output and see what it is showing. Try lts headers.
sudo pacman -S linux-lts-headers
:vulcan_salute:
Sorry, I missed that. :disappointed:
Same thing happened to me but i have installed LTS headers
I have installed the headers but that didnt change anything.
Thank you!
This time I updated everything. :blush:
I have removed the broadcom driver. That didnt help.
I had an error about a virtualbox from the start, which I wanted to encounter after this issue. Now I have removed the virtualbox-guest-modules-arch and virtualbox-guest-utils packages and its gone. :ok_hand:t3:
Same thing here. How you remove all that?
I removed the packages with pamac
Bildschirmfoto%20vom%202019-07-26%2008-15-13 Bildschirmfoto%20vom%202019-07-26%2008-14-45
Thank you my friend. I dont understand why there is that virtual box things? As long i am hone i am going to try it
no problem, my friend.
if you are not inside a virtualboc installation :wink:
sudo pacman -R virtualbox-guest-utils virtualbox-guest-modules-arch
they should not be there but the detection of if you run inside vm or not was not working 100%, we do already solved this for the next release…
Still nothing. It wont boot
Nvidia drivers installed?
I dont have Nvidia card. Intel i have
@AndreasDimo So i ask what exactly is the problem you are having now? Your previous post said:
Do you have Endeavour installed? Is it no longer working? Can you give some detail? What is your hardware?
@makeixo Could you post some info on your system? Do you have inxi installed? If so can you post the output of your hardware.
inxi -Fxxc0
@makeixo !
Can you publish what you have in these folders?
ls -l /etc/modules-load.d/
ls -l /run/modules-load.d/
ls -l /usr/lib/modules-load.d/
[mak@mak-pc ~]$ ls -l /etc/modules-load.d/
insgesamt 0
[mak@mak-pc ~]$ ls -l /run/modules-load.d/
ls: Zugriff auf ‘/run/modules-load.d/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
[mak@mak-pc ~]$ ls -l /usr/lib/modules-load.d/
insgesamt 12
-rw-r–r-- 1 root root 12 14. Jan 2019 bluez.conf
-rw-r–r-- 1 root root 3 29. Dez 2017 cdrecord.conf
-rw-r–r-- 1 root root 307 13. Mai 00:23 pkcs8.conf
