Failed to start kernel (lts) modules
Now I do.
If you click on my avatar, you see my hardware information as well.
Host: mak-pc Kernel: 4.19.60-1-lts x86_64 bits: 64 compiler: gcc v: 9.1.0
Desktop: Gnome 3.32.2 wm: gnome-shell dm: GDM, LightDM Distro: EndeavourOS
Type: Desktop Mobo: ASRock model: FM2A78M Pro4+ serial:
UEFI [Legacy]: American Megatrends v: P2.40 date: 02/05/2016
Topology: Quad Core model: AMD Athlon X4 880K bits: 64 type: MCP
arch: Steamroller rev: 1 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 33539
Speed: 1799 MHz min/max: 1700/4200 MHz Core speeds (MHz): 1: 2070 2: 1924
3: 1697 4: 1792
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Hightech Information System driver: amdgpu v: kernel
bus ID: 01:00.0 chip ID: 1002:67ef
Display: x11 server: X.org 1.20.5 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa compositor: gnome-shell
resolution:
Device-1: AMD FCH Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: Hightech Information System driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 1002:aae0
Sound Server: ALSA v: k4.19.60-1-lts
Device-1: Qualcomm Atheros AR9287 Wireless Network Adapter driver: ath9k
v: kernel port: e000 bus ID: 03:00.0 chip ID: 168c:002e
IF: wlp3s0 state: up mac: 84:16:f9:3f:09:1a
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASRock
driver: alx v: kernel port: d000 bus ID: 04:00.0 chip ID: 1969:10a1
IF: enp4s0 state: down mac: d0:50:99:07:f7:37
Local Storage: total: 256.17 GiB used: 157.08 GiB (61.3%)
ID-1: /dev/sda vendor: Crucial model: CT275MX300SSD1 size: 256.17 GiB
speed: 6.0 Gb/s serial: 1639140D1CED
ID-1: / size: 24.21 GiB used: 10.60 GiB (43.8%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 18.5 C mobo: N/A gpu: amdgpu temp: 33 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1522
Processes: 192 Uptime: 8m Memory: 15.60 GiB used: 1.35 GiB (8.7%)
Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7
running in: gnome-terminal inxi: 3.0.35
@makeixo Can you run…
systemctl --failed
I also wanted to ask are you running a dual boot system with Windows 10?
It occurs to me that these files are the ones that are giving problems when loading kernel modules:
sudo rm /usr/lib/modules-load.d/bluez.conf
sudo rm /usr/lib/modules-load.d/cdrecord.conf
sudo rm /usr/lib/modules-load.d/pkcs8.conf
After deleting them, restart the system and please comment on how it went.
[mak@mak-pc ~]$ systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
ā— systemd-modules-load.service loaded failed failed Load Kernel Modules
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
Yes, I do …
It acually doesnt show any list (ok/failed) anymore.
therefore it seems to be ok. Thank you!
I’m just wondering if the shutdown issue is related to hiberfile in Windows 10? So in UEFI there is fast boot and normally you would have this turned off and also secure boot would normally be turned off or disabled. So in Windows 10 there is a feature under power management that is called Windows 10 fast startup. This needs to be turned off in order for hibernation setting to be off. Maybe this is causing the issue?
I have no I idea if thats possible, but I will try it out tomorrow.
It would be terrific getting this issue finally solved!
If thats the case I will propose you for men of the year, my friend!
@Resiliencia Thanks for your help.
@ricklinux
You’re welcome, as long as you can help, count on me !!!
I try! I don’t know everything…there is so much. I really like Arch based Linux so i learn something everyday with a little help from my friends. :wink:
I have work to do, so i installed another distro. The problem was that it still wont boot with LTS kernel
@AndreasDimo I hope you come back and try again sometime. Endeavour is awesome and I’m not sure what trouble you were having but I’m sure it is some hardware issue that could be resolved.
I am sure of that. But i am tired of reinstalling thats why
I only saw the tail end of your posts so i didn’t understand what the problem was you were having. I’m not sure if you ever got Endeavour installed or you had run into an issue later on and it wouldn’t boot up anymore? I hope you’ll be back and give it another go at some point. Endeavour is shaping up to be a very good distro. I am really waiting for the online version of their installer where i can install a desktop of choice. Hope to see you back.
I have installed just fine and boot it fine but after I have installed LTS kernel and remove some virtual box modules like they suggested here in the forum but after that it is not boot
That is really strange because installing lts kernel would not likely be the problem. As far as the virtualbox stuff goes. When you install Endeavour it gives a message when it boots about virtual box. I just went into startup applications and removed the virtualbox just so i didn’t get any message on boot.
I know and you have right. But it wont boot, and i have only one pc so i dont have time to search for a solution. To bad because i am following the project from the start and i feel it like my own distro (sorry from my English)
hello, I’m using linux kernel and not lts and it works very well
