This has happened before when i was using arch, now happened again.
I think this has happened twice in arch with me and now on endeavour.
Can someone please help me fix this and tell me the reason why it happens with me?
I dont think i do anything else than a normal user.
Thank you!
Thank you for such a quick reply. The only thing I can do is login as root. Do I just have to enter that command?
Also what is the reason for this error which keeps happening? I don’t think I mess with my system in any way.
When i try to mount root partition/sdb3 (second command),i get mount: /mnt wrong fs type, bad option, bad superblock on /dev/sdb3, missing codegape or helper program, or other error.
In case someone else will chime in with other suggestions, mine would be (if this is a new install) to re-install the system, using the automatic mode if you don’t absolutely need a separate home partition.
I cant, data in home partition is important, and i have spent a lot of time configuring stuff… the reason why i left arch was unstability and the community was very rude for no reason. I was trying out different OSes, thats why I have no backup. But I really like Endeavouros and want this as my os.
Model: ATA ST500DM002-1BD14 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 500GB 500GB ext4
Model: ATA ADATA SU650 (scsi)
Disk /dev/sdb: 960GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17.4kB 578MB 578MB fat32 boot, esp
2 578MB 4873MB 4295MB linux-swap(v1) swap
3 4873MB 112GB 107GB ext4
4 112GB 960GB 848GB ext4
Model: (scsi)
Disk /dev/sdc: 8017MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 1916MB 2023MB 107MB primary fat16 esp
----------------------------END---------------------------
sda is hard disk that I dont use, but will use after a few days. sdb is my main drive. sdc is the live iso thumb drive/ pen drive.
