Hello. I’ve been using EnOS for a month. Last time, due to some ridiculous configuration setting I decided to use the timeshift feature for the first time. The OS didn’t load, (failed to mount /efi) yeah… quite the same as the person’s posted there:
Except I use ext4 file format. So I wanted to ask here and double check if the guide is still up to date / valid I have seen in the forums.
I had divided my 1TB disk into two parts when installing EnOs. (EFI partition, only 2GB) the rest is already the space I use (951,3GB)
To clarify the issued lines here:
[FAILED] Failed to mount /efi.
[DEPEND] Dependency failed for Local File Systems.
And the last lines:
You are in emergency mode. After logging in, type "journal -xb" to view system logs, "systemctl reboot" to reboot, or "exit" to continue to bootup.
Enter root password for system maintance (Or press Control-D to continue)
I usually solve Linux problems with ai but I only implement 20% of what it suggests. It just helps me to figure out what the issue is. I just brainstorm and come up with the right solution myself by considering forums + ai suggestions.
But … ahemm… it’s hard for me to be braining when I’m so stressed…
First, I have checked this guide:
https://discovery.endeavouros.com/system-rescue/arch-chroot/2022/12/
I’m curious. Can’t we do it via emergency mode? Wouldn’t it be sufficient for this or live usb is still required?
