However, when I cold booted and the GUI would not work at all so I was unable to log in. I then added the quiet 3 kernel parameter to load Endeavour OS without GUI and logged in and deleted the 70-synaptics.conf file I created earlier. I cold booted and was then able to log in as before the changes. The touchpad still doesn’t work.
Remove the three dots from the bottom “…” I wonder which genius put those there Everybody copies and pastes
I removed the three dots and tried it again. It still didn’t work. Like last time, it says"
Starting version 245.6-8-arch
/dev/sda2 clean _____ files ______ blocks
where “___” is an actual number.
and afterward is the eternally blinking underscore cursor.
It never gets to the login screen and like last time I booted it with quiet 3 kernel parameters for use without the GUI and deleted the file. I was then able to cold boot and login as normal. The trackpad still doesn’t work after a cold boot. The trackpad only works with the power cord plugged in after very long periods of inactivity (overnight) with cold boot.
So having said that about the power cord. What i would do is unplug it. Take the battery out and hold down the power button and drain all the power from the laptop. Hold it down for a while. Then put the battery back in and plug it in and after a few minutes start it.
I have tried all the parameters at once and then each individually. They didn’t solve the issue.
modprobe -r psmouse
modprobe psmouse proto=imps
I tried this next and it didn’t fix the issue either.
You could also try create these files. Try each separate.
/etc/modprobe.d/ psmouse.conf
Add the following and save the file.
“options psmouse proto=imps”
Here is another.
/etc/modprobe.d/elan.conf
I created files then tested the touchpad again and it doesn’t work after a cold boot. After each attempt I shutdown the computer with the shutdown command and start it up with the power cord plugged in.
I then tried the above, but this didn’t work either.
