Ethernet connection
My Ethernet connection was working but it stopped recently. I’ve checked the hardware and it shows the orange light by the cable and everything is plugged in correctly. I also looked at https://discovery.endeavouros.com/network/r8168-workaround/2021/03/ and Network not detecting wired ethernet And when I use r8168 it sends back bytes when I do “ping www.google.com” but not if I do it again and it it will not load anything in a web browser. Sorry if this is a poor explanation.
Can you share the output from ping google.com when it fails?
Can you also test if ping 8.8.8.8 works in that situation?
Can you also share ip a
The response from ping www.google.com is
The ping command appears to work well except for when I retry it without changing anything or let the system use r1869. And the response of ip a was
looks like the google ping works, but you’re using the ipv6 address for some reason, shouldn’t be a problem though. Maybe your ISP changed something.
can you test your internet with a live system?
Unless I misunderstood what you meant (not unlikely) I would say that I can’t load anything in a web browser to test. Also It was working for a while but just recently broke and It broke just after I installed rust if that helps.
You are misunderstanding what @mihalycsaba is asking you. You are being asked if you boot in to a live usb do you still have internet problems in the live environment?
The Ethernet works in a live boot wether I use r8168 or r8169.
After I booted into the usb it just works now, I didn’t install a new one and it works well after multiple reboots I don’t know how or why.
