Etcher not working for latest release
Yes, Ventoy is pretty much the only way I boot ISO images. When it works, it works great. It’s very nice to have multiple ISO on one thumb drive and it’s very easy to keep them up to date, by just copying the files. Also, it is very nice to be able to use the drive for other files.
I never used Etcher and never will. If an ISO does not work with Ventoy, I burn it using dd.
Have you tested with EndeavourOS?
Yes, that’s how I installed EndeavourOS some two months ago. I have not tested it with the latest ISO, but it should work, I assume.
EndeavourOS is listed on the Ventoy website as tested:
Thanks! Will test a little later!
Might want to search the forum next time. Plenty of post on Ventoy, including one by me that says bot the last EOS build and the current EOS build wirk with it.
Yep, but I thought the question fit in here as well. But will think about it next time!
I have just installed Ventoy on a 256 Gb USB.
I have reformatted the “images partition” from ExFat to Ext4 and copied 4 different ISO inside. It works really nicely, and it’s a splendid option to have multiples images in one only USB. Thanks for the tip !
Then ventoy seems to be a magical software :wink:
Right :innocent:…Gb it is. I would prefer to find Magic but it’s just a simple error… too bad :wink:
Hehe, Gb or GB? :wink:
I tried it and it didn’t work. I must have done something wrong. What is the process to put ventoy on the usb. Does it take up the whole usb size or just uses a portion or a partition and the rest is formatted to accept files?
This.
Just download the file, extract it and in the Ventoy folder there is a README file with instructions.
You just need to run sudo sh Ventoy2Disk.sh -i /dev/sdx to install it the first time.
After you can reformat the partition on the USB, copy ISO’s, etc… instructions on the website:
Well i tried again and it didn’t work again. It say’s bash -i and bash -I don’t exist? What am i doing wrong?
I downloaded the file and extracted it. Then in the terminal i went to the folder it extracted and ran the command.
Edit: Do i need this extracted onto the USB drive?
I’ve moved the thread from bug report to Applications because it isn’t a bug on the general system.
this should be ( -g GPT )
sudo ventoy -i -g /dev/sdX
It keeps saying i need root privileges even if i use root. I have a triple boot with Btrfs setup and one is encrypted but i’m not in the encrypted version and that should matter? The command shows different in their website and also what i have looked up so i will try this one.
Thanks.
Edit: Now it say’s command not found? I think is missing something?
This is what it shows on their website and it doesn’t work!
[ricklinux@eos-plasma ventoy-1.0.21]$ sh Ventoy2Disk.sh { -i | -I | -u } /dev/sdc
bash: -I: command not found
bash: -u: command not found
Thanks for the tip. I’m using Etcher now, and that’s not optimal.
Will try it later today.
I typically just redo my key when there is a new version. My downloads folder for everything is my torrents folder. Once I download the new version of Ventoy I extract it there, open it’s newly created folder, open terminal there and just follow the instructions I saved to my ISO folder on my downloads drive.
Download latest Ventoy
 Extract it to it's own folder
 Open it's folder
 Open Konsole there
 Enter the below command replacing X in sdX with the actual letter of your drive
 sudo sh Ventoy2Disk.sh -I /dev/sdX
 follow the onscreen instructions and install Ventoy to your flashdrive
Now just add the ISO's you want
