DVD drive constantly throw errors on idle state
I have a bit of a weird errors here, perhaps someone more experienced in Kernel / devices will be able to help or debug :slight_smile:
So since about Manjaro Stable Kernel: 5.6.16-1-MANJARO x86_64 it started, sadly happens on EndeavourOS as well :frowning:
I got journal full of those 2 type of errors, while my drive is idle, i don’t touch or interact with it manually (physically or software), nothing changed over time except updates…
journalctl -p3 -xb
jul 01 00:22:16 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 01 00:22:16 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Additional info:
  1. My drive is NEC Optiarc BD RW BD-5300S
  2. It’s intact and works perfectly (haven’t tested writing though, but reading is perfectly good as it was before)
  3. Tried to reconnect SATA / power cables just in case
  4. In both cases i am on KDE and use TLP for power management
Any help is appreciated, i hate unwanted errors! :robot:
Hmm… have you tried with TLP disabled? It has a few settings related to disk drives.
Any other errors for sr0 in your logs?
I’ve tried to disable those settings specifically, like bay device power-off, will try to completely disable TLP and see if it helps!
No, just variations of those 2:
jul 28 21:50:06 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
jul 28 21:50:06 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 28 21:50:06 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 01:16:30 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
jul 29 01:16:30 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 01:16:30 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 10:16:32 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
jul 29 10:16:32 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 10:16:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 10:21:32 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
jul 29 10:21:32 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 10:21:32 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
I notice an exact 5 minutes gap in the last part of your log.
Like something is polling the drive…
Might sound stupid, but do these errors also appear with a disk in the drive (but without mounting or otherwise doing something with it)?
I believe it’s same, as long as it’s idle - but i’ll double-check later too.
You think it might be some failed auto-mounting attempts by KDE or something like that?
Yeah that’s weird indeed…I definitely haven’t used this drive manually at that time (i’ve used Dolphin, some Wine maybe…otherwise just Firefox)
Using the LTS kernel might help.
Certainly will, since it’s started about ~5.6, but ideally i’d like to fix it and prevent from happening in future for myself and others :slight_smile:
journalctl -xb | grep "sr0"
jul 28 21:34:06 x133-PC kernel: sr 5:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
jul 28 21:34:06 x133-PC kernel: sr 5:0:0:0: Attached scsi CD-ROM sr0
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Sense Key : Not Ready [current]
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Add. Sense: Medium not present - tray closed
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#24 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#24 Sense Key : Not Ready [current]
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#24 Add. Sense: Medium not present - tray closed
jul 28 21:50:06 x133-PC kernel: sr 5:0:0:0: [sr0] tag#24 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 Sense Key : Not Ready [current]
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 Add. Sense: Medium not present - tray closed
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 Sense Key : Not Ready [current]
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 Add. Sense: Medium not present - tray closed
jul 29 01:16:30 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 Sense Key : Not Ready [current]
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 Add. Sense: Medium not present - tray closed
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Sense Key : Not Ready [current]
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Add. Sense: Medium not present - tray closed
jul 29 10:16:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#12 Sense Key : Not Ready [current]
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#12 Add. Sense: Medium not present - tray closed
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#12 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Sense Key : Not Ready [current]
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Add. Sense: Medium not present - tray closed
jul 29 10:21:32 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Sense Key : Not Ready [current]
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Add. Sense: Medium not present - tray closed
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#14 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#15 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#16 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#17 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#18 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#19 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#20 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 unaligned transfer
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Sense Key : Not Ready [current]
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 Add. Sense: Medium not present - tray closed
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:21:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#27 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#28 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#29 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#30 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#3 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#4 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#5 unaligned transfer
jul 29 10:21:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#6 unaligned transfer
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#8 Sense Key : Not Ready [current]
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#8 Add. Sense: Medium not present - tray closed
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#8 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:23:13 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#9 Sense Key : Not Ready [current]
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#9 Add. Sense: Medium not present - tray closed
jul 29 10:23:13 x133-PC kernel: sr 5:0:0:0: [sr0] tag#9 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 10:23:13 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 10:23:13 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#2 Sense Key : Not Ready [current]
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#2 Add. Sense: Medium not present - tray closed
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#2 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#3 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#4 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#5 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#6 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#7 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#11 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#12 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 10:45:22 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 unaligned transfer
jul 29 10:45:22 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 10:45:22 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Sense Key : Not Ready [current]
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 Add. Sense: Medium not present - tray closed
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#13 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 15:38:56 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#14 Sense Key : Not Ready [current]
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#14 Add. Sense: Medium not present - tray closed
jul 29 15:38:56 x133-PC kernel: sr 5:0:0:0: [sr0] tag#14 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00
jul 29 15:38:56 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 15:38:56 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 Sense Key : Not Ready [current]
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 Add. Sense: Medium not present - tray closed
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#21 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#22 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 0, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#23 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 1, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#26 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 2, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#27 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 3, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#28 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 4, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#29 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 5, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#30 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 6, async page read
jul 29 15:39:41 x133-PC kernel: sr 5:0:0:0: [sr0] tag#0 unaligned transfer
jul 29 15:39:41 x133-PC kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
jul 29 15:39:41 x133-PC kernel: Buffer I/O error on dev sr0, logical block 7, async page read
@anon31687413
Hmmm…Check out extended log, there’s some attempts to poll drive indeed:
Is there any way to find out what polls it?
Got it!
It got triggered each time when launching Wine :exploding_head:
I’m pretty sure there must be some other tiggers coz when i left PC on night without Wine programs launched - in the morning i still get those, but now at least we got some trigger to debug that
Maybe wineserver was still running in the background?
I do not know much about wine, but starting it with WINEDEBUG=warn+all wine might give more info.
100% not, i’m actually super paranoid about it and kill them all, unless i use it :slight_smile:
  • When disc is inside drive (but not mounted) - it doesn’t got triggered by Wine!
  • In Dolphin when disc inside - it got added to removable drives category
  • When you eject disk - i can trigger this error by Wine again :woozy_face:
So…Looks like my system just doesn’t know somehow that there is a drive anymore, without media inside :neutral_face:
That wasn’t the case on LTS Kernel (at least around the time it came out, maybe it’s some other packages at play) :\
Ideas?
Unfortunately, no…
There are few sysctl settings related to cdrom, maybe you can try experimenting with these. I don’t know what they actually do, only guessing by their name:
# ls /proc/sys/dev/cdrom/
autoclose  autoeject  check_media  debug  info  lock
check_media perhaps? No seriously, no clue…
Thx, i’ll check different possibilities and keep you posted if something comes up! :+1:
Yep, that’s right…A lot of log to read, nothing relevant so far! :upside_down_face:
So, ls /proc/sys/dev/cdrom/ …
cat /proc/sys/dev/cdrom/check_media
0
cat /proc/sys/dev/cdrom/debug
0
cat /proc/sys/dev/cdrom/info
CD-ROM information, Id: cdrom.c 3.20 2003/12/17
drive name:             sr0
drive speed:            48
drive # of slots:       1
Can close tray:         1
Can open tray:          1
Can lock tray:          1
Can change speed:       1
Can select disk:        0
Can read multisession:  1
Can read MCN:           1
Reports media changed:  1
Can play audio:         1
Can write CD-R:         1
Can write CD-RW:        1
Can read DVD:           1
Can write DVD-R:        1
Can write DVD-RAM:      1
Can read MRW:           1
Can write MRW:          1
Can write RAM:          1
Wine errors i was able to get through logs which may be something (doesn’t seem connected, but i just don’t know those ones, maybe someone knows):
0070:err:heap:HEAP_GetPtr Invalid heap (nil)!
0078:err:ntoskrnl:ZwLoadDriver failed to create driver
@felixonmars
Since you’re maintainer of Wine on Arch, perhaps you know what could cause it?
Seems it’s only Wine after all, doesn’t matter wine or wine-staging, default wineprefix or non-system - it’s always those errors for me :frowning:
