Hi all,
I have been using EOS for about 6 months on my AMD machine worked like a charm but now something is weird.
I have a 4k drawing tablet. With x11 there are minor issues with the pen precision is off. On Wayland it’s perfect spot on.
- Anyway out of nowhere my drawing tablet stopped displaying on Wayland.
- When I turn on the tablet, the system just freezes and making multiple USB connection sounds.
- On boot I started seeing
amd_pstate: min_freq(0) or max_freq(0) or nominal_freq(0) value is incorrect(this same message is displayed 10 times) and finishes withamd_pstate: failed to register with return -19
This message was not there before. I also tried to update the system but same thing is still happening.
On x11 the tablet turns on and displays but as I said above it has problem with pen. On Wayland it was working perfectly, but now it just not working for no reason.
I also tied sudo reinstall-kernels and nothing
Update:
Okay out of nowhere the tablet now works on Wayland after couple of reboots and switching from Wayland to X11 to Wayland.
Still though that message worries me and I have noticed it only appears when I load with 6.11.2-arch1-1 kernel.
My PC:
CPU: AMD Ryzen 5 3600 6-Core Processor
GPU: AMD Radeon RX 580 Series
Kernel: 6.11.2-arch1-1
