This update finally fixes the dkms compile issue with binutils 2.36.1 but it introduces a strange bug. As soon as the guest OS is up an running, the sound on the host is distorted. I have tested with EndeavourOS, Linux Mint and Windows guest. And the sound on the host was either coming via youtube or via shortwave internet radio.
I have to change the audio driver for the host to ASLA-Audio to prevent the distortions. Before that it was PulseAudio by default and that does not work anymore.
I tried it all. Basically all combination of driver and controller. It does not help. With PulseAudio as driver the sound on guest AND host is distorted. This is really weird.
Thanks for the confirmation and pointing out the workaround!
I don’t know why I didn’t try that before. It works for me too!
Recently I have had my head in the …
Another workaround is to switch to Pipewire. I built my Distro ditching PulseAudio completely. A choice I made after I had very similar issue plus fact that using Pulse with custom AMD Ryzen Kernel resulted in audio recording coming out as if I was one of the Chip N Dale Chipmunks xD
Pulse out, PipeWire in no more vBox or Recording issues
I keep having distorted sound on all my linux distros, Debian- or Arch-based, in the past till today as host -vm in VirtualBox throughout the years. No VBox update ever changed that…
Could turning off all pulse-audio and replacing it with pipewire completely be a possible solution to that?
Unfortunately, on Arch-Gnome it only improves the situation a little bit. It doesn’t resolve the two issues (distorted and / or laggy audio) completely.
Mind, this is not working at all for EOS- and Fedora-VBox-VMs in my case.
My suspicion: pipewire and/or gnome-shell as they are both not running under Xfce-desktop.
Unfortunately, after changing lots of things, it isn’t as error-free in Fedora 36, as it is on Arch based systems. But I could achieve some improvements!
