Hi,
I have a legion 5 r7 5800H.
I’ve installed endeavour os on vmware pro.
I’m trying to change display resolution
I’m unable to change the display resolution to 1920x1080 as the option is not available. I wonder why not, its the most common resolution used world wide
Hence I switched to xandr for fix. I found a article, in which the user specified about a script. which I ran for fixing the issue. But then every time I restart it goes back to original state.
I just want to know why 1920x1080 doesn’t exist, and how do I properly fix my display resolution
If you do things like this, it’s always a good idea to at least give a link to the script, so people know, what has been done/changed. Increases chances for successful support.
I don’t have any issues either but there are a lot of variables including which version of vmware you are using, the hardware in the host(especially the gpu) and the host OS.
