NM5TF
January 6, 2022, 4:44am
#1
After a “recent update”, my desktop display never powers down . I have the following settings in Power Manager:
All Buttons= do nothing
Sleep= suspend
Display Blank= 5 mins Sleep= 6 mins Off= 7 mins
It did work perfectly in the past, so something changed “somewhere”…
Any help much appreciated,
Tommy
Dump of Neofetch:
tommy@THOTH-OPTOPLEX-9020
./sssso- -------------------------
`:osssssss+- OS: EndeavourOS Linux x86_64
`:+sssssssssso/. Host: OptiPlex 9020 00
`-/ossssssssssssso/. Kernel: 5.15.12-arch1-1
`-/+sssssssssssssssso+:` Uptime: 14 hours, 48 mins
`-:/+sssssssssssssssssso+/. Packages: 983 (pacman)
`.://osssssssssssssssssssso++- Shell: bash 5.1.12
.://+ssssssssssssssssssssssso++: Resolution: 1920x1080
.:///ossssssssssssssssssssssssso++: DE: Xfce 4.16
`:////ssssssssssssssssssssssssssso+++. WM: Xfwm4
`-////+ssssssssssssssssssssssssssso++++- WM Theme: Arc-Dark
`..-+oosssssssssssssssssssssssso+++++/` Theme: Arc-Dark [GTK2], Arc-Darker [
./++++++++++++++++++++++++++++++/:. Icons: Adwaita [GTK2], Arc-X-D [GTK3
`:::::::::::::::::::::::::------`` Terminal: xfce4-terminal
Terminal Font: Source Code Pro Mediu
CPU: Intel i5-4570 (4) @ 3.600GHz
GPU: Intel HD Graphics
Memory: 1543MiB / 15908MiB
EDIT: Added code tags.
eosbtw
January 6, 2022, 5:49am
#2
An alternative way to present neofetch output is to use neofetch --stdout
While that is a neat option in neofetch (one I was unfamiliar with), the system info neofetch displays is almost always inadequate for any practical troubleshooting.
It’s much more productive to use inxi for this purpose:
inxi -Faz
Edited: thanks @keybreak , very cool!
btw, -Fxxxza
is overkill
inxi -Fxxxz
is same as (-a
have some additional options though)
inxi -Faz
NM5TF
January 6, 2022, 2:57pm
#6
here is output of inxi -Faz
[tommy@THOTH-OPTOPLEX-9020 ~]$ inxi -Faz
Kernel: 5.15.12-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=6c2f45b8-5c10-415b-9e37-54e44473c70f rw quiet loglevel=3
nowatchdog
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 9020 v: 00
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: Dell model: 00V62H v: A01 serial: <superuser required> BIOS: Dell
v: A15 date: 11/08/2015
Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2783 high: 3386 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3386 2: 1191 3: 3193
4: 3364 bogomips: 25549
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: mds mitigation: Clear CPU buffers; SMT disabled
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: eno1 state: down mac: <filter>
Device-2: Edimax EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
type: USB driver: rtl8192cu bus-ID: 3-11:5 chip-ID: 7392:7811
class-ID: 0000 serial: <filter>
RAID:
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: f060 bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 110.84 GiB (23.2%)
ID-1: /dev/sda maj-min: 8:0 model: 30TT253X2-512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 0A0 scheme: MBR
ID-1: / raw-size: 234.07 GiB size: 229.33 GiB (97.98%)
used: 20.75 GiB (9.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Processes: 187 Uptime: 1d 1h 2m wakeups: 0 Memory: 15.54 GiB
used: 1.68 GiB (10.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 993 pacman: 983 lib: 224 snap: 10 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
thank you…now I know how to use code tags…it’s different on different forums
Tommy
