Display port 1.2 vs 1.4
should i even consider a monitor with a display port version 1.2?
i’m looking at 32 inch 1440p monitors with 1 ms response time and displayport 1.4 for under 400$ looking. hard to find…
Sceptre 30-inch Curved Gaming Monitor 21:9 2560x1080 Ultra Wide Ultra Slim HDMI DisplayPort up to 200Hz Build-in Speakers, Metal Black (C305B-200UN)
is not 32 inches and is 412.50
Sounds like a lotta bang for the buck. Does anyone even use built-in speakers? Presumably if you’re gaming you’d be using a headset anyway?
i dont use a headset
Fair enough! External speakers?
If it’s for gaming you could check this one https://www.mi.com/global/monitor34/
It’s not 1 ms response time but 4 ms for the rest it seems to be ok !
You have HDMI 2.0 x 2 / DP1.4 port x 2 / AUDIO port x 1 / AC power cable IN port x 1
They announced it at 369 Euros in France so I imagine it will be on sell very soon…
If you are looking for the best Photo Monitor EIZO or BENQ but the price is really UP than yours, at minimum the double !
I’ve got the BenQ 35" EX3501R. An older, but still brilliant display. It’s only 100Hz refreshrate, but IMO for my gaming anything north 100 Hz is a waste. Great quality all purpose display. This one is still being sold for over 600 euros in Finland, which is crazy. I actually paid around 700 for mine. Add a monitor arm and the VESA adapter and it’s closer to 800. :sweat_smile:
Item#: N82E16824012012
GIGABYTE G32QC 32" 165Hz 1440P Curved Gaming Monitor, 2560 x 1440 VA 1500R Display, 1ms(MPRT), 94% DCI-P3, VESA Display HDR400, FreeSync Premium Pro, 1x Display Port 1.2, 2x HDMI 2.0, 2x USB 3.0
359 us but dp 1.2
That price is tight with those specs but the Samsung G5 Odyssey 32" curved screen is available right now on sale @399.00 Cdn so US would be less. It is Display port version 1.2 with 1ms response time max 144Hz WQHD screen 2560x1440
Model # LC32G55TQWNXZA
ca-odyssey-g5-g95t-lc32g55tqwnxza-frontblack-292067982
Edit: Only has headphone no speakers no audio in.
F.Y.I. Maximum Display Port cable length 1.5 metres
Sale just ended
It’s on sale here. :wink:
https://www.newegg.com/p/N82E16824022901
That one is 27 inches though at least that’s what it pulled up
500$ on Amazon from scalpers. Sold out everywhere else
Sorry you are right. I wasn’t paying attention. :man_facepalming:
you picked good one though. everyone loves it. maybe i should get 2 27 in ones?
Sceptre 32 inch QHD IPS LED Monitor HDR400 2560x1440 HDMI DisplayPort up to 144Hz 1ms Height Adjustable, Build-in Speakers Gunmetal Black 2021 (E325B-QPN168)
this one is sitting right at 400
aspact ratio = 1.77:1 ? 15.93:9
Screen Size 32 Inches
Resolution 1920x1080
Display Technology LED
Brand Sceptre
Aspect Ratio 16:9
Sceptre Curved 32" Gaming Monitor Up to 240Hz 1ms AMD FreeSync Premium Build-in Speakers, HDMI Displayport Gunmetal 2021 (C325B-FWD240)
369$ us
as an owner of 2 sceptre tv’s currently and at least one more previously i feel like i should buy stock in the company… i seriously dont work for them
i think i want the 2k over the 1k even if the 1k has a 240hz refresh rate
SALE ends: March 18, 2021 sale was extended on bestbuy.com
Every monitor is advertised as 1ms nowadays. Find out about frame-time latency if you can.
For example the 1080p 27" 75Hz Freesync Samsung monitor i bought recently (out of sudden necessity and 2nd monitor use for when i get something more expensive) is advertised as 1ms but my frame times are around 25ms.
Sadly none list that
Not all advertise 1msrt. Some show 5 or 6
