Display port 1.2 vs 1.4
This youtube channel does testing and comparison with charts, there are other videos in the same vein as well, you should check out:
There are 5 of these in stock here.
27114
This would also be a decent choice @449 Cdn
I won’t buy anything less than 32 inch. I arch from my couch. Giving up a 43” tv For performance will be hard enough
Maybe I should get 2 24 inch bezel less 1440p then I’d have a 48 inch extra wide? Mount them to the wall?
Well it’s hard to get into that price range @ 32" with those specs. The 32" version is $519 Cdn Also in stock here.
Edit: I’m talking locally so i can reach out and touch it! :smile:
Kinda a Necro but if youre looking for a good 1440p display you can always go used. Its not 1ms response time but old dell ultrasharps go for dirt cheap and are some of the best monitors around for color work.
If gaming is the goal keep in mind that as long as the displays response time is lower than your frame time it doesnt make a ton of difference to get a 1ms display unless you have REALLY low frame times. This also doesnt account for what your mouse latency is or what your physical response time is (unless youre training for e sports) and display port has little to do with your monitors response time.
Yeah, to me picking a monitor by port version doesn’t make sense. I mean the monitor surely has at least the port version that allows it to reach its advertised specs. So whatever the monitor comes with is perfect, if all other specs fit in the requirement.
exactly, worrying about port version doesnt make sense as itll have exactly what is needed to reach the spec its designed for
