I’ve been having this issue lately and am having trouble deciphering the log. I do sudo journalctl -b -1 > log and then tail the log.
Essentially the CTRL ALT F2 doesn’t work (or maybe does, I can’t tell) because the screens themselves don’t wake up, this is an issue when I’ve locked or suspended the system for an extended period of time. If I come back in like five minutes it doesn’t happen. Hoping someone can help me figure this out:
Nov 11 10:54:11 latitude rtkit-daemon[1168]: Supervising 10 threads of 5 processes of 1 users.
Nov 11 10:56:03 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 10:56:04 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 10:56:05 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 10:56:48 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 10:58:15 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 10:58:15 latitude gnome-shell[1384]: libinput error: event5 - Logitech G403 HERO Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
Nov 11 10:59:18 latitude gnome-shell[1980]: IPDL protocol error: Handler returned error code!
Nov 11 10:59:18 latitude gnome-shell[1980]: ###!!! [Parent][DispatchAsyncMessage] Error: PLayerTransaction::Msg_ReleaseLayer Processing error: message was deserialized, but the handler returned false (indicating failure)
Nov 11 10:59:56 latitude rtkit-daemon[1168]: Supervising 10 threads of 5 processes of 1 users.
Nov 11 10:59:57 latitude rtkit-daemon[1168]: Supervising 10 threads of 5 processes of 1 users.
Nov 11 10:59:58 latitude systemd[1277]: vte-spawn-0f5fec10-2661-4480-9934-83e3eca42b75.scope: Succeeded.
Nov 11 10:59:58 latitude systemd[1277]: gnome-terminal-server.service: Succeeded.
Nov 11 11:00:34 latitude systemd[1]: Starting Cleanup of Temporary Directories...
Nov 11 11:00:34 latitude systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Nov 11 11:00:34 latitude systemd[1]: Finished Cleanup of Temporary Directories.
Nov 11 11:00:34 latitude audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:00:34 latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:00:34 latitude kernel: audit: type=1130 audit(1605114034.460:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:00:34 latitude kernel: audit: type=1131 audit(1605114034.460:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:01:18 latitude rtkit-daemon[1168]: Supervising 10 threads of 5 processes of 1 users.
Nov 11 11:03:25 latitude systemd[1277]: Started Application launched by gsd-media-keys.
Nov 11 11:03:25 latitude dbus-daemon[730]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.448' (uid=0 pid=4681 comm="sudo systemctl suspend ")
Nov 11 11:03:25 latitude dbus-daemon[730]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Nov 11 11:03:25 latitude sudo[4681]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Nov 11 11:03:25 latitude audit[4681]: USER_ACCT pid=4681 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dustin" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude audit[4681]: CRED_REFR pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude sudo[4681]: dustin : TTY=unknown ; PWD=/home/dustin ; USER=root ; COMMAND=/usr/bin/systemctl suspend
Nov 11 11:03:25 latitude sudo[4681]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Nov 11 11:03:25 latitude audit[4681]: USER_START pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: audit: type=1101 audit(1605114205.479:80): pid=4681 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dustin" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: audit: type=1110 audit(1605114205.479:81): pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: audit: type=1105 audit(1605114205.479:82): pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.4962] manager: sleep: sleep requested (sleeping: no enabled: yes)
Nov 11 11:03:25 latitude audit[4681]: USER_END pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude audit[4681]: CRED_DISP pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.4964] device (enp0s31f6): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 11 11:03:25 latitude sudo[4681]: pam_unix(sudo:session): session closed for user root
Nov 11 11:03:25 latitude systemd[1277]: app-gnome-sudo-4681.scope: Succeeded.
Nov 11 11:03:25 latitude kernel: audit: type=1106 audit(1605114205.489:83): pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: audit: type=1104 audit(1605114205.489:84): pid=4681 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude gnome-shell[1384]: Ignoring excess values in shadow definition
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.5823] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.5825] manager: NetworkManager state is now ASLEEP
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.5827] device (wlan0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Nov 11 11:03:25 latitude evolution[1997]: Network disconnected. Forced offline.
Nov 11 11:03:25 latitude dbus-daemon[730]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=731 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 11 11:03:25 latitude systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 11 11:03:25 latitude kernel: e1000e: enp0s31f6 NIC Link is Down
Nov 11 11:03:25 latitude dbus-daemon[730]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 11 11:03:25 latitude systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 11 11:03:25 latitude audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: audit: type=1130 audit(1605114205.589:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 11 11:03:25 latitude kernel: wlan0: deauthenticating from 30:23:03:de:1d:22 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 11 11:03:25 latitude wpa_supplicant[786]: wlan0: CTRL-EVENT-DISCONNECTED bssid=30:23:03:de:1d:22 reason=3 locally_generated=1
Nov 11 11:03:25 latitude wpa_supplicant[786]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6096] device (wlan0): supplicant interface state: completed -> disconnected
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6099] device (wlan0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for 2601:2c0:8b00:9ff::cf7 on wlan0.
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for fd81:77c2:c730::cf7 on wlan0.
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for fd81:77c2:c730:0:9ff1:3610:7971:6fea on wlan0.
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for 2601:2c0:8b00:9ff:e5df:b6d5:e61e:f474 on wlan0.
Nov 11 11:03:25 latitude avahi-daemon[727]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2601:2c0:8b00:9ff:e5df:b6d5:e61e:f474.
Nov 11 11:03:25 latitude avahi-daemon[727]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::70d6:ccd:2e2e:f9ca.
Nov 11 11:03:25 latitude avahi-daemon[727]: Registering new address record for fe80::70d6:ccd:2e2e:f9ca on wlan0.*.
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for fe80::70d6:ccd:2e2e:f9ca on wlan0.
Nov 11 11:03:25 latitude avahi-daemon[727]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::70d6:ccd:2e2e:f9ca.
Nov 11 11:03:25 latitude avahi-daemon[727]: Interface wlan0.IPv6 no longer relevant for mDNS.
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6132] dhcp4 (wlan0): canceled DHCP transaction
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6132] dhcp4 (wlan0): state changed bound -> done
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6135] dhcp6 (wlan0): canceled DHCP transaction
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6135] dhcp6 (wlan0): state changed bound -> done
Nov 11 11:03:25 latitude avahi-daemon[727]: Interface wlan0.IPv4 no longer relevant for mDNS.
Nov 11 11:03:25 latitude avahi-daemon[727]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.1.0.134.
Nov 11 11:03:25 latitude avahi-daemon[727]: Withdrawing address record for 10.1.0.134 on wlan0.
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6192] device (wlan0): set-hw-addr: set MAC address to 0A:F1:E7:8A:A6:00 (scanning)
Nov 11 11:03:25 latitude avahi-daemon[727]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.1.0.134.
Nov 11 11:03:25 latitude avahi-daemon[727]: New relevant interface wlan0.IPv4 for mDNS.
Nov 11 11:03:25 latitude avahi-daemon[727]: Registering new address record for 10.1.0.134 on wlan0.IPv4.
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6366] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6367] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 11 11:03:25 latitude NetworkManager[731]: <info> [1605114205.6391] device (wlan0): set-hw-addr: reset MAC address to A0:A4:C5:00:D3:A4 (unmanage)
Nov 11 11:03:25 latitude blueman-tray[1778]: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
Nov 11 11:03:25 latitude wpa_supplicant[786]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Nov 11 11:03:25 latitude gnome-shell[1384]: DWifi Debug: Device Current State: 100
Nov 11 11:03:25 latitude gnome-shell[1384]: An active wireless connection, in infrastructure mode, involves no access point?
Nov 11 11:03:26 latitude wpa_supplicant[786]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Nov 11 11:03:26 latitude gnome-shell[1384]: Bogus presentation time 0 travelled back in time, using current time.
Nov 11 11:03:26 latitude gsd-usb-protect[1573]: Error calling USBGuard DBus to change the protection after a screensaver event: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Nov 11 11:03:26 latitude systemd[1]: Reached target Sleep.
Nov 11 11:03:26 latitude systemd[1]: Starting Suspend...
Nov 11 11:03:27 latitude systemd-sleep[4739]: Suspending system...
Nov 11 11:03:27 latitude kernel: PM: suspend entry (deep)
Nov 11 11:03:27 latitude kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 11 11:03:27 latitude kernel: ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Nov 11 11:03:27 latitude kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Nov 11 11:03:27 latitude kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Nov 11 11:03:27 latitude kernel: ata3.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Nov 11 11:03:27 latitude kernel: ata3.00: configured for UDMA/133
Nov 11 11:03:27 latitude kernel: ata3.00: Enabling discard_zeroes_data
