Which config file are you talking about? Is it working now because the usbguard package has been added and given rules based on the currently installed devices?
There is a line in /etc/usbguard/usbguard-daemon.conf further down that you change to allow and it will default allow any usb device plugged in, but not too long after feeling relief I experienced it again. So I reloaded my system with Ubuntu and have had successful wakeups for two days now. Here is my journal from this morning, hopefully it can help. I’d much rather use Arch but unfortunatley I just don’t have the time to be messing with things much anymore, took me two weeks of dealing with this issue to get around to trying to find help. Hence, why I used Endeavour instead of vanilla lol. Hopefully I can come back around though this was my only real issue that I experienced.
Nov 16 06:34:45 latitude kernel: Filesystems sync: 0.020 seconds
Nov 16 06:34:45 latitude kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Nov 16 06:34:45 latitude kernel: OOM killer disabled.
Nov 16 06:34:45 latitude kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Nov 16 06:34:45 latitude kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 16 06:34:45 latitude kernel: sd 2:0:0:0: [sda] Synchronizing SCSI cache
Nov 16 06:34:45 latitude kernel: sd 2:0:0:0: [sda] Stopping disk
Nov 16 06:34:45 latitude kernel: e1000e: EEE TX LPI TIMER: 00000011
Nov 16 06:34:45 latitude kernel: ACPI: EC: interrupt blocked
Nov 16 06:34:45 latitude kernel: ACPI: Preparing to enter system sleep state S3
Nov 16 06:34:45 latitude kernel: ACPI: EC: event blocked
Nov 16 06:34:45 latitude kernel: ACPI: EC: EC stopped
Nov 16 06:34:45 latitude kernel: PM: Saving platform NVS memory
Nov 16 06:34:45 latitude kernel: Disabling non-boot CPUs ...
Nov 16 06:34:45 latitude kernel: smpboot: CPU 1 is now offline
Nov 16 06:34:45 latitude kernel: smpboot: CPU 2 is now offline
Nov 16 06:34:45 latitude kernel: smpboot: CPU 3 is now offline
Nov 16 06:34:45 latitude kernel: IRQ 126: no longer affine to CPU4
Nov 16 06:34:45 latitude kernel: smpboot: CPU 4 is now offline
Nov 16 06:34:45 latitude kernel: IRQ 124: no longer affine to CPU5
Nov 16 06:34:45 latitude kernel: IRQ 130: no longer affine to CPU5
Nov 16 06:34:45 latitude kernel: smpboot: CPU 5 is now offline
Nov 16 06:34:45 latitude kernel: IRQ 122: no longer affine to CPU6
Nov 16 06:34:45 latitude kernel: IRQ 128: no longer affine to CPU6
Nov 16 06:34:45 latitude kernel: smpboot: CPU 6 is now offline
Nov 16 06:34:45 latitude kernel: IRQ 123: no longer affine to CPU7
Nov 16 06:34:45 latitude kernel: smpboot: CPU 7 is now offline
Nov 16 06:34:45 latitude kernel: ACPI: Low-level resume complete
Nov 16 06:34:45 latitude kernel: ACPI: EC: EC started
Nov 16 06:34:45 latitude kernel: PM: Restoring platform NVS memory
Nov 16 06:34:45 latitude kernel: Enabling non-boot CPUs ...
Nov 16 06:34:45 latitude kernel: x86: Booting SMP configuration:
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Nov 16 06:34:45 latitude kernel: microcode: sig=0x806ea, pf=0x80, revision=0xd6
Nov 16 06:34:45 latitude kernel: microcode: updated to revision 0xe0, date = 2020-06-17
Nov 16 06:34:45 latitude kernel: CPU1 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Nov 16 06:34:45 latitude kernel: CPU2 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Nov 16 06:34:45 latitude kernel: CPU3 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
Nov 16 06:34:45 latitude kernel: microcode: sig=0x806ea, pf=0x80, revision=0xe0
Nov 16 06:34:45 latitude kernel: CPU4 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
Nov 16 06:34:45 latitude kernel: CPU5 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
Nov 16 06:34:45 latitude kernel: CPU6 is up
Nov 16 06:34:45 latitude kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Nov 16 06:34:45 latitude kernel: CPU7 is up
Nov 16 06:34:45 latitude kernel: ACPI: Waking up from system sleep state S3
Nov 16 06:34:45 latitude kernel: ACPI: EC: interrupt unblocked
Nov 16 06:34:45 latitude kernel: ACPI: EC: event unblocked
Nov 16 06:34:45 latitude kernel: sd 2:0:0:0: [sda] Starting disk
Nov 16 06:34:45 latitude kernel: i2c_hid i2c-DELL0816:00: i2c_hid_get_input: incomplete report (30/65369)
Nov 16 06:34:45 latitude kernel: usb 1-5: reset high-speed USB device number 3 using xhci_hcd
Nov 16 06:34:45 latitude kernel: ata1: SATA link down (SStatus 4 SControl 300)
Nov 16 06:34:45 latitude kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 16 06:34:45 latitude kernel: ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Nov 16 06:34:45 latitude kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Nov 16 06:34:45 latitude kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Nov 16 06:34:45 latitude kernel: ata3.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Nov 16 06:34:45 latitude kernel: ata3.00: configured for UDMA/133
Nov 16 06:34:45 latitude kernel: ata3.00: Enabling discard_zeroes_data
Nov 16 06:34:45 latitude kernel: usb 1-7: reset full-speed USB device number 5 using xhci_hcd
Nov 16 06:34:45 latitude kernel: acpi LNXPOWER:00: Turning OFF
Nov 16 06:34:45 latitude kernel: OOM killer enabled.
Nov 16 06:34:45 latitude bluetoothd[926]: Endpoint unregistered: sender=:1.205 path=/MediaEndpoint/A2DPSink/sbc
Nov 16 06:34:45 latitude goa-daemon[7350]: goa_http_client_check() failed: 7 — Could not connect: Socket I/O timed out
Nov 16 06:34:45 latitude kernel: Restarting tasks ... done.
Nov 16 06:34:45 latitude kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Nov 16 06:34:45 latitude bluetoothd[926]: Endpoint unregistered: sender=:1.205 path=/MediaEndpoint/A2DPSource/sbc
Nov 16 06:34:45 latitude goa-daemon[7350]: /org/gnome/OnlineAccounts/Accounts/account_1605498156_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Invalid password with username “link@mydomain.tld” (goa-error-quark, 0): Code: 7 — Unexpected response from server (goa-error-quark, 4)
Nov 16 06:34:45 latitude kernel: usb 2-1.3: USB disconnect, device number 3
Nov 16 06:34:45 latitude systemd[1]: Started Run anacron jobs.
-- Subject: A start job for unit anacron.service has finished successfully
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- A start job for unit anacron.service has finished successfully.
-- The job identifier is 4917.
Nov 16 06:34:45 latitude anacron[21753]: Anacron 2.3 started on 2020-11-16
Nov 16 06:34:45 latitude anacron[21753]: Will run job `cron.daily' in 5 min.
Nov 16 06:34:45 latitude anacron[21753]: Jobs will be executed sequentially
Nov 16 06:34:45 latitude systemd[1]: Starting Daily apt download activities...
-- Subject: A start job for unit apt-daily.service has begun execution
-- A start job for unit apt-daily.service has begun execution.
-- The job identifier is 5121.
Nov 16 06:34:45 latitude systemd[1]: Starting Discard unused blocks on filesystems from /etc/fstab...
-- Subject: A start job for unit fstrim.service has begun execution
-- A start job for unit fstrim.service has begun execution.
-- The job identifier is 4815.
Nov 16 06:34:45 latitude systemd[1]: Starting Refresh fwupd metadata and update motd...
-- Subject: A start job for unit fwupd-refresh.service has begun execution
-- A start job for unit fwupd-refresh.service has begun execution.
-- The job identifier is 5325.
Nov 16 06:34:45 latitude kernel: thermal thermal_zone9: failed to read out thermal zone (-61)
Nov 16 06:34:45 latitude systemd[1]: Starting Load/Save RF Kill Switch Status...
-- Subject: A start job for unit systemd-rfkill.service has begun execution
-- A start job for unit systemd-rfkill.service has begun execution.
-- The job identifier is 4807.
Nov 16 06:34:45 latitude systemd[1]: Starting Rotate log files...
-- Subject: A start job for unit logrotate.service has begun execution
-- A start job for unit logrotate.service has begun execution.
-- The job identifier is 5223.
Nov 16 06:34:45 latitude systemd[1]: Starting Daily man-db regeneration...
-- Subject: A start job for unit man-db.service has begun execution
-- A start job for unit man-db.service has begun execution.
-- The job identifier is 5019.
Nov 16 06:34:45 latitude systemd[1]: Started Load/Save RF Kill Switch Status.
-- Subject: A start job for unit systemd-rfkill.service has finished successfully
-- A start job for unit systemd-rfkill.service has finished successfully.
Nov 16 06:34:45 latitude systemd[1]: Stopped target Bluetooth.
-- Subject: A stop job for unit bluetooth.target has finished
-- A stop job for unit bluetooth.target has finished.
-- The job identifier is 5427 and the job result is done.
Nov 16 06:34:45 latitude kernel: PM: suspend exit
Nov 16 06:34:45 latitude systemd-sleep[21639]: System resumed.
-- Subject: System sleep state suspend left
-- The system has now left the suspend sleep state.
Nov 16 06:34:45 latitude systemd[1]: fwupd-refresh.service: Succeeded.
-- Subject: Unit succeeded
-- The unit fwupd-refresh.service has successfully entered the 'dead' state.
Nov 16 06:34:45 latitude systemd[1]: Finished Refresh fwupd metadata and update motd.
-- Subject: A start job for unit fwupd-refresh.service has finished successfully
-- A start job for unit fwupd-refresh.service has finished successfully.
Nov 16 06:34:45 latitude systemd[1]: logrotate.service: Succeeded.
-- The unit logrotate.service has successfully entered the 'dead' state.
Nov 16 06:34:45 latitude systemd[1]: Finished Rotate log files.
-- Subject: A start job for unit logrotate.service has finished successfully
-- A start job for unit logrotate.service has finished successfully.
Nov 16 06:34:45 latitude kernel: usb 2-1: USB disconnect, device number 2
Nov 16 06:34:45 latitude systemd-sleep[21812]: /dev/sda:
Nov 16 06:34:45 latitude systemd-sleep[21812]: setting Advanced Power Management level to 0xfe (254)
Nov 16 06:34:45 latitude systemd-sleep[21812]: APM_level = 254
Nov 16 06:34:45 latitude systemd[1]: systemd-suspend.service: Succeeded.
-- The unit systemd-suspend.service has successfully entered the 'dead' state.
Nov 16 06:34:45 latitude systemd[1]: Finished Suspend.
-- Subject: A start job for unit systemd-suspend.service has finished successfully
-- A start job for unit systemd-suspend.service has finished successfully.
-- The job identifier is 4803.
Nov 16 06:34:45 latitude systemd[1]: Stopped target Sleep.
-- Subject: A stop job for unit sleep.target has finished
-- A stop job for unit sleep.target has finished.
-- The job identifier is 5428 and the job result is done.
Nov 16 06:34:45 latitude systemd[1]: Reached target Suspend.
-- Subject: A start job for unit suspend.target has finished successfully
-- A start job for unit suspend.target has finished successfully.
-- The job identifier is 4802.
Nov 16 06:34:45 latitude systemd[1]: Stopped target Suspend.
-- Subject: A stop job for unit suspend.target has finished
-- A stop job for unit suspend.target has finished.
-- The job identifier is 5431 and the job result is done.
Nov 16 06:34:45 latitude systemd-logind[966]: Operation 'sleep' finished.
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.4036] manager: sleep: wake requested (sleeping: yes enabled: yes)
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.4037] device (enp0s31f6): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.4848] device (enp0s31f6): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 16 06:34:45 latitude kernel: e1000e: enp0s31f6 NIC Link is Down
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.6847] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 16 06:34:45 latitude kernel: iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
Nov 16 06:34:45 latitude kernel: usb 2-1.4: USB disconnect, device number 4
Nov 16 06:34:45 latitude systemd[1]: man-db.service: Succeeded.
-- The unit man-db.service has successfully entered the 'dead' state.
Nov 16 06:34:45 latitude systemd[1]: Finished Daily man-db regeneration.
-- Subject: A start job for unit man-db.service has finished successfully
-- A start job for unit man-db.service has finished successfully.
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Device revision is 16
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Secure boot is enabled
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: OTP lock is enabled
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: API lock is enabled
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Debug lock is disabled
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
Nov 16 06:34:45 latitude kernel: Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
Nov 16 06:34:45 latitude systemd[1931]: Reached target Bluetooth.
-- Subject: A start job for unit UNIT has finished successfully
-- A start job for unit UNIT has finished successfully.
-- The job identifier is 1397.
Nov 16 06:34:45 latitude systemd[1]: Reached target Bluetooth.
-- Subject: A start job for unit bluetooth.target has finished successfully
-- A start job for unit bluetooth.target has finished successfully.
-- The job identifier is 5432.
Nov 16 06:34:45 latitude kernel: iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
Nov 16 06:34:45 latitude avahi-daemon[925]: Interface enxe4b97adb30c6.IPv6 no longer relevant for mDNS.
Nov 16 06:34:45 latitude avahi-daemon[925]: Leaving mDNS multicast group on interface enxe4b97adb30c6.IPv6 with address 2601:2c0:8b00:9ff:c9d1:3a56:8adb:5498.
Nov 16 06:34:45 latitude whoopsie[1918]: [06:34:45] Cannot reach: https://daisy.ubuntu.com
Nov 16 06:34:45 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:45 latitude avahi-daemon[925]: Interface enxe4b97adb30c6.IPv4 no longer relevant for mDNS.
Nov 16 06:34:45 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “autodiscover.outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:45 latitude avahi-daemon[925]: Leaving mDNS multicast group on interface enxe4b97adb30c6.IPv4 with address 10.1.0.121.
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9146] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for fd81:77c2:c730:0:8d10:f69f:409b:b38b on enxe4b97adb30c6.
Nov 16 06:34:45 latitude goa-daemon[7350]: /org/gnome/OnlineAccounts/Accounts/account_1605497415_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Invalid password with username “link@workemail.com” (goa-error-quark, 0): Cannot resolve hostname (goa-error-quark, 4)
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for 2601:2c0:8b00:9ff:8d10:f69f:409b:b38b on enxe4b97adb30c6.
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for 2601:2c0:8b00:9ff::25c on enxe4b97adb30c6.
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for fd81:77c2:c730::25c on enxe4b97adb30c6.
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for fd81:77c2:c730:0:1d13:cd:ea6e:92d1 on enxe4b97adb30c6.
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for 2601:2c0:8b00:9ff:c9d1:3a56:8adb:5498 on enxe4b97adb30c6.
Nov 16 06:34:45 latitude avahi-daemon[925]: Withdrawing address record for 10.1.0.121 on enxe4b97adb30c6.
Nov 16 06:34:45 latitude ModemManager[1024]: <info> (net/enxe4b97adb30c6): released by device '/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4'
Nov 16 06:34:45 latitude ModemManager[1024]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4': Operation was cancelled
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9182] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9197] device (enxe4b97adb30c6): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Nov 16 06:34:45 latitude goa-daemon[7350]: g_socket_client_connect_to_host() failed: Error resolving “mail.mydomain.tld”: Name or service not known (g-resolver-error-quark, 0)
Nov 16 06:34:45 latitude goa-daemon[7350]: /org/gnome/OnlineAccounts/Accounts/account_1605498272_1: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Invalid imap-password with username “link@mydomain.tld” (goa-error-quark, 0): Error resolving “mail.mydomain.tld”: Name or service not known (goa-error-quark, 4)
Nov 16 06:34:45 latitude snap-store[7597]: not handling error failed for action refresh: remote lvfs has no cache signature
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9457] dhcp4 (enxe4b97adb30c6): canceled DHCP transaction
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9457] dhcp4 (enxe4b97adb30c6): state changed bound -> done
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9461] dhcp6 (enxe4b97adb30c6): canceled DHCP transaction
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9461] dhcp6 (enxe4b97adb30c6): state changed bound -> done
Nov 16 06:34:45 latitude NetworkManager[933]: <info> [1605530085.9481] manager: NetworkManager state is now DISCONNECTED
Nov 16 06:34:45 latitude NetworkManager[933]: <warn> [1605530085.9501] dns-sd-resolved[ed4c5d7827e119fb]: send-updates failed to update systemd-resolved: GDBus.Error:org.freedesktop.resolve1.NoSuchLink: Link 3 not known
Nov 16 06:34:45 latitude PackageKit[17028]: uid 1000 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
Nov 16 06:34:45 latitude nm-dispatcher[21907]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Nov 16 06:34:45 latitude whoopsie[1918]: [06:34:45] Could not determine if /org/freedesktop/NetworkManager/ActiveConnection/1 is a default route:
Nov 16 06:34:45 latitude whoopsie[1918]: [06:34:45] GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/1
Nov 16 06:34:45 latitude PackageKit[17028]: uid 1000 obtained auth for org.freedesktop.packagekit.system-sources-refresh
Nov 16 06:34:46 latitude NetworkManager[933]: <info> [1605530086.0436] sup-iface[0x55869277b210,wlp2s0]: supports 5 scan SSIDs
Nov 16 06:34:46 latitude NetworkManager[933]: <info> [1605530086.0442] device (wlp2s0): supplicant interface state: starting -> ready
Nov 16 06:34:46 latitude NetworkManager[933]: <info> [1605530086.0443] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 16 06:34:46 latitude NetworkManager[933]: <info> [1605530086.0446] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 16 06:34:46 latitude PackageKit[17028]: refresh-cache transaction /53_ddceaeab from uid 1000 finished with failed after 293ms
Nov 16 06:34:46 latitude snap-store[7597]: not handling error no-network for action refresh: Cannot refresh cache whilst offline
Nov 16 06:34:46 latitude kernel: usb 2-1: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
Nov 16 06:34:46 latitude kernel: usb 2-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.47
Nov 16 06:34:46 latitude kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 16 06:34:46 latitude kernel: usb 2-1: Product: Dell dock
Nov 16 06:34:46 latitude kernel: usb 2-1: Manufacturer: Dell Inc.
Nov 16 06:34:46 latitude kernel: hub 2-1:1.0: USB hub found
Nov 16 06:34:46 latitude kernel: hub 2-1:1.0: 4 ports detected
Nov 16 06:34:46 latitude PackageKit[17028]: refresh-cache transaction /54_cccdcadb from uid 1000 finished with failed after 266ms
Nov 16 06:34:46 latitude gnome-software[8927]: not handling error no-network for action refresh: Cannot refresh cache whilst offline
Nov 16 06:34:46 latitude kernel: usb 2-1.3: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
Nov 16 06:34:46 latitude kernel: usb 2-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.21
Nov 16 06:34:46 latitude kernel: usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 16 06:34:46 latitude kernel: usb 2-1.3: Product: Dell dock
Nov 16 06:34:46 latitude kernel: usb 2-1.3: Manufacturer: Dell Inc.
Nov 16 06:34:46 latitude kernel: hub 2-1.3:1.0: USB hub found
Nov 16 06:34:46 latitude kernel: hub 2-1.3:1.0: 4 ports detected
Nov 16 06:34:46 latitude kernel: usb 2-1.4: new SuperSpeed Gen 1 USB device number 7 using xhci_hcd
Nov 16 06:34:46 latitude kernel: usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
Nov 16 06:34:46 latitude kernel: usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Nov 16 06:34:46 latitude kernel: usb 2-1.4: Product: USB 10/100/1000 LAN
Nov 16 06:34:46 latitude kernel: usb 2-1.4: Manufacturer: Realtek
Nov 16 06:34:46 latitude kernel: usb 2-1.4: SerialNumber: 111000001
Nov 16 06:34:46 latitude kernel: usb 2-1.4: reset SuperSpeed Gen 1 USB device number 7 using xhci_hcd
Nov 16 06:34:46 latitude kernel: r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Using pass-thru MAC addr e4:b9:7a:db:30:c6
Nov 16 06:34:46 latitude NetworkManager[933]: <info> [1605530086.8747] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/7)
Nov 16 06:34:46 latitude kernel: r8152 2-1.4:1.0 eth0: v1.10.11
Nov 16 06:34:46 latitude mtp-probe[22147]: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4"
Nov 16 06:34:46 latitude mtp-probe[22147]: bus: 2, device: 7 was not an MTP device
Nov 16 06:34:47 latitude goa-daemon[7350]: g_socket_client_connect_to_host() failed: Error resolving “mail.mydomain.tld”: Name or service not known (g-resolver-error-quark, 0)
Nov 16 06:34:47 latitude mtp-probe[22152]: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4"
Nov 16 06:34:47 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “autodiscover.outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:47 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:47 latitude goa-daemon[7350]: goa_http_client_check() failed: 2 — Error resolving “cloud.mydomain.tld”: Temporary failure in name resolution
Nov 16 06:34:47 latitude mtp-probe[22152]: bus: 2, device: 7 was not an MTP device
Nov 16 06:34:47 latitude systemd-udevd[21779]: Using default interface naming scheme 'v245'.
Nov 16 06:34:47 latitude systemd-udevd[21779]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 16 06:34:47 latitude kernel: r8152 2-1.4:1.0 enxe4b97adb30c6: renamed from eth0
Nov 16 06:34:47 latitude NetworkManager[933]: <info> [1605530087.7340] device (eth0): interface index 6 renamed iface from 'eth0' to 'enxe4b97adb30c6'
Nov 16 06:34:47 latitude NetworkManager[933]: <info> [1605530087.7410] device (enxe4b97adb30c6): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 16 06:34:47 latitude NetworkManager[933]: <info> [1605530087.7473] settings: (enxe4b97adb30c6): created default wired connection 'Wired connection 2'
Nov 16 06:34:47 latitude ModemManager[1024]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
Nov 16 06:34:47 latitude ModemManager[1024]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Waiting for firmware download to complete
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Firmware loaded in 2178306 usecs
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Waiting for device to boot
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Device booted in 11740 usecs
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
Nov 16 06:34:47 latitude kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
Nov 16 06:34:48 latitude bluetoothd[926]: Endpoint registered: sender=:1.205 path=/MediaEndpoint/A2DPSink/sbc
Nov 16 06:34:48 latitude bluetoothd[926]: Endpoint registered: sender=:1.205 path=/MediaEndpoint/A2DPSource/sbc
Nov 16 06:34:48 latitude goa-daemon[7350]: g_socket_client_connect_to_host() failed: Error resolving “mail.mydomain.tld”: Name or service not known (g-resolver-error-quark, 0)
Nov 16 06:34:48 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:48 latitude goa-daemon[7350]: goa_ews_client_autodiscover() failed: 2 — Error resolving “autodiscover.outlook.office.com”: Temporary failure in name resolution
Nov 16 06:34:48 latitude goa-daemon[7350]: goa_http_client_check() failed: 2 — Error resolving “cloud.mydomain.tld”: Temporary failure in name resolution
Nov 16 06:34:49 latitude systemd[1]: apt-daily.service: Succeeded.
-- The unit apt-daily.service has successfully entered the 'dead' state.
Nov 16 06:34:49 latitude systemd[1]: Finished Daily apt download activities.
-- Subject: A start job for unit apt-daily.service has finished successfully
-- A start job for unit apt-daily.service has finished successfully.
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4723] policy: auto-activating connection '' (274d63eb-4499-463a-b41d-a5df42861e3c)
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4728] device (wlp2s0): Activation: starting connection '' (274d63eb-4499-463a-b41d-a5df42861e3c)
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4729] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4733] manager: NetworkManager state is now CONNECTING
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4737] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4741] device (wlp2s0): Activation: (wifi) access point '' has security, but secrets are required.
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4741] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4769] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4774] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4777] device (wlp2s0): Activation: (wifi) connection '' has security, and secrets exist. No new secrets needed.
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'ssid' value ''
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'scan_ssid' value '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'bgscan' value 'simple:30:-70:86400'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'auth_alg' value 'OPEN'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4778] Config: added 'psk' value '<hidden>'
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: SME: Trying to authenticate with 30:23:03:de:1d:22 (SSID='' freq=5180 MHz)
Nov 16 06:34:49 latitude kernel: wlp2s0: authenticate with 30:23:03:de:1d:22
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4991] device (wlp2s0): supplicant interface state: ready -> authenticating
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.4992] device (p2p-dev-wlp2s0): supplicant management interface state: ready -> authenticating
Nov 16 06:34:49 latitude kernel: wlp2s0: send auth to 30:23:03:de:1d:22 (try 1/3)
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: Trying to associate with 30:23:03:de:1d:22 (SSID='' freq=5180 MHz)
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5049] device (wlp2s0): supplicant interface state: authenticating -> associating
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5049] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Nov 16 06:34:49 latitude kernel: wlp2s0: authenticated
Nov 16 06:34:49 latitude kernel: wlp2s0: associate with 30:23:03:de:1d:22 (try 1/3)
Nov 16 06:34:49 latitude kernel: wlp2s0: RX AssocResp from 30:23:03:de:1d:22 (capab=0x11 status=0 aid=3)
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: Associated with 30:23:03:de:1d:22
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 16 06:34:49 latitude kernel: wlp2s0: associated
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5339] device (wlp2s0): supplicant interface state: associating -> 4-way handshake
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5339] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4-way handshake
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: WPA: Key negotiation completed with 30:23:03:de:1d:22 [PTK=CCMP GTK=CCMP]
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 30:23:03:de:1d:22 completed [id=0 id_str=]
Nov 16 06:34:49 latitude kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-24 noise=9999 txrate=6000
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5460] device (wlp2s0): supplicant interface state: 4-way handshake -> completed
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5461] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network ""
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5462] device (p2p-dev-wlp2s0): supplicant management interface state: 4-way handshake -> completed
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5464] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5471] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Nov 16 06:34:49 latitude avahi-daemon[925]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::ad42:2e9a:bf3f:db86.
Nov 16 06:34:49 latitude avahi-daemon[925]: New relevant interface wlp2s0.IPv6 for mDNS.
Nov 16 06:34:49 latitude avahi-daemon[925]: Registering new address record for fe80::ad42:2e9a:bf3f:db86 on wlp2s0.*.
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5681] dhcp4 (wlp2s0): option dhcp_lease_time => '43200'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5682] dhcp4 (wlp2s0): option domain_name => 'lan'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5682] dhcp4 (wlp2s0): option domain_name_servers => '10.1.0.1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5682] dhcp4 (wlp2s0): option expiry => '1605573289'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5683] dhcp4 (wlp2s0): option host_name => 'latitude'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5683] dhcp4 (wlp2s0): option ip_address => '10.1.0.134'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5683] dhcp4 (wlp2s0): option next_server => '10.1.0.1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5683] dhcp4 (wlp2s0): option requested_broadcast_address => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5684] dhcp4 (wlp2s0): option requested_domain_name => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5684] dhcp4 (wlp2s0): option requested_domain_name_servers => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5684] dhcp4 (wlp2s0): option requested_domain_search => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5684] dhcp4 (wlp2s0): option requested_host_name => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5684] dhcp4 (wlp2s0): option requested_interface_mtu => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5685] dhcp4 (wlp2s0): option requested_ms_classless_static_routes => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5685] dhcp4 (wlp2s0): option requested_nis_domain => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5685] dhcp4 (wlp2s0): option requested_nis_servers => '1'
Nov 16 06:34:49 latitude avahi-daemon[925]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 10.1.0.134.
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5685] dhcp4 (wlp2s0): option requested_ntp_servers => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5686] dhcp4 (wlp2s0): option requested_rfc3442_classless_static_routes => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5686] dhcp4 (wlp2s0): option requested_root_path => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5686] dhcp4 (wlp2s0): option requested_routers => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5686] dhcp4 (wlp2s0): option requested_static_routes => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5687] dhcp4 (wlp2s0): option requested_subnet_mask => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5687] dhcp4 (wlp2s0): option requested_time_offset => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5687] dhcp4 (wlp2s0): option requested_wpad => '1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5687] dhcp4 (wlp2s0): option routers => '10.1.0.1'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5688] dhcp4 (wlp2s0): option subnet_mask => '255.255.255.0'
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5688] dhcp4 (wlp2s0): state changed unknown -> bound
Nov 16 06:34:49 latitude avahi-daemon[925]: New relevant interface wlp2s0.IPv4 for mDNS.
Nov 16 06:34:49 latitude avahi-daemon[925]: Registering new address record for 10.1.0.134 on wlp2s0.IPv4.
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5768] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5851] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5855] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5862] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5887] manager: NetworkManager state is now CONNECTED_SITE
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5888] policy: set '' (wlp2s0) as default for IPv4 routing and DNS
Nov 16 06:34:49 latitude NetworkManager[933]: <info> [1605530089.5895] device (wlp2s0): Activation: successful, device activated.
Nov 16 06:34:49 latitude wpa_supplicant[971]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-25 noise=9999 txrate=866700
Nov 16 06:34:49 latitude systemd-resolved[900]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Nov 16 06:34:50 latitude dbus-daemon[930]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.181' (uid=1000 pid=7281 comm="/usr/bin/gnome-shell " label="unconfined")
Nov 16 06:34:50 latitude systemd[1]: Starting Fingerprint Authentication Daemon...
-- Subject: A start job for unit fprintd.service has begun execution
-- A start job for unit fprintd.service has begun execution.
-- The job identifier is 5536.
Nov 16 06:34:50 latitude ModemManager[1024]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4': not supported by any plugin
Nov 16 06:34:50 latitude dbus-daemon[930]: [system] Successfully activated service 'net.reactivated.Fprint'
Nov 16 06:34:50 latitude systemd[1]: Started Fingerprint Authentication Daemon.
-- Subject: A start job for unit fprintd.service has finished successfully
-- A start job for unit fprintd.service has finished successfully.
Nov 16 06:34:50 latitude gdm-password][22383]: pam_unix(gdm-password:auth): Couldn't open /etc/securetty: No such file or directory
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3921] device (enxe4b97adb30c6): carrier: link connected
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3928] device (enxe4b97adb30c6): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enxe4b97adb30c6: link becomes ready
Nov 16 06:34:50 latitude kernel: r8152 2-1.4:1.0 enxe4b97adb30c6: carrier on
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3936] policy: auto-activating connection 'Wired connection 2' (f6ebe62a-be4f-304e-8fc9-77200045f815)
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3941] device (enxe4b97adb30c6): Activation: starting connection 'Wired connection 2' (f6ebe62a-be4f-304e-8fc9-77200045f815)
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3943] device (enxe4b97adb30c6): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3948] device (enxe4b97adb30c6): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3952] device (enxe4b97adb30c6): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.3954] dhcp4 (enxe4b97adb30c6): activation: beginning transaction (timeout in 45 seconds)
Nov 16 06:34:50 latitude avahi-daemon[925]: Joining mDNS multicast group on interface enxe4b97adb30c6.IPv6 with address fe80::a01c:3305:59d1:3429.
Nov 16 06:34:50 latitude avahi-daemon[925]: New relevant interface enxe4b97adb30c6.IPv6 for mDNS.
Nov 16 06:34:50 latitude avahi-daemon[925]: Registering new address record for fe80::a01c:3305:59d1:3429 on enxe4b97adb30c6.*.
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option dhcp_lease_time => '43200'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option domain_name => 'lan'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option domain_name_servers => '10.1.0.1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option expiry => '1605573290'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option host_name => 'latitude'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option ip_address => '10.1.0.121'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4157] dhcp4 (enxe4b97adb30c6): option next_server => '10.1.0.1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_broadcast_address => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_domain_name => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_domain_name_servers => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_domain_search => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_host_name => '1'
Nov 16 06:34:50 latitude avahi-daemon[925]: Joining mDNS multicast group on interface enxe4b97adb30c6.IPv4 with address 10.1.0.121.
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_interface_mtu => '1'
Nov 16 06:34:50 latitude avahi-daemon[925]: New relevant interface enxe4b97adb30c6.IPv4 for mDNS.
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_ms_classless_static_routes => '1'
Nov 16 06:34:50 latitude avahi-daemon[925]: Registering new address record for 10.1.0.121 on enxe4b97adb30c6.IPv4.
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_nis_domain => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_nis_servers => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_ntp_servers => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_rfc3442_classless_static_routes => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_root_path => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_routers => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_static_routes => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_subnet_mask => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_time_offset => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4158] dhcp4 (enxe4b97adb30c6): option requested_wpad => '1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4159] dhcp4 (enxe4b97adb30c6): option routers => '10.1.0.1'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4159] dhcp4 (enxe4b97adb30c6): option subnet_mask => '255.255.255.0'
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4159] dhcp4 (enxe4b97adb30c6): state changed unknown -> bound
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4170] device (enxe4b97adb30c6): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4198] device (enxe4b97adb30c6): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4201] device (enxe4b97adb30c6): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4214] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4215] manager: NetworkManager state is now CONNECTED_SITE
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4216] policy: set 'Wired connection 2' (enxe4b97adb30c6) as default for IPv4 routing and DNS
Nov 16 06:34:50 latitude NetworkManager[933]: <info> [1605530090.4222] device (enxe4b97adb30c6): Activation: successful, device activated.
Nov 16 06:34:50 latitude systemd-resolved[900]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Nov 16 06:34:50 latitude systemd[1]: systemd-rfkill.service: Succeeded.
Yes i understood the allow in the usbguard rules i just thought the way you explained it that you had configured some other conf file.
I see the journal but i think it would only be helpful if you had the exact journal from EndeavourOS to compare. It could be that you need to set some ACPI parameter because of a missing ACPI functionality in the DSDT table. (DSDT table is the code run on ACPI (Power Management) events.) Or it could be related to any of the USB pwr management or sleep.
Sometimes setting acpi_osi=“Windows2018” as a kernel parameter or acpi_osi=“Linux”
I think where i would start is looking at your hardware. Check if there is a Bios update and try that first. I realize these things take time. That is the logical place to start. If there is an update then i would start there.
Yeah I did first. All firmware is up to date, grub cmdline only has “quiet splash”
Okay …well I’m sure it’s solvable but it will take some time, effort, & trying different things that you can learn from the Arch Wiki or other sources. You may have to look at more logs and journals too.
why sending text as a picture? insert text as text, if someone want to help and do a research for you mostlikely needs the text
lspci > log.txt && lsusb >> log.txt && journalctl -b -0 >> log.txt && cat log.txt | curl -F 'f:1=<-' ix.io
