but may this idea is better then using sizes that do not fit for both normal dpi and hidpi only to have something that fit for all needs … if it is possible to detect hidpi it should be possible to sed the config files to fit that needs, this could be helpful for xfce4-offline install also?
Yes! Although for xfce there is a button in the welcome menu to scale the screen, but would make better first impression to make it readable out of the box.
personally i like this But i understand why @joekamprad not put it in ( possible head explode for new user )
#Set Gaps
set $mode_gaps Gaps: (o)uter, (i)nner, (h)orizontal, (v)ertical, (t)op, (r)ight, (b)ottom, (l)eft
set $mode_gaps_outer Outer Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_inner Inner Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_horiz Horizontal Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_verti Vertical Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_top Top Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_right Right Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_bottom Bottom Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_left Left Gaps: +|-|0 (local), Shift + +|-|0 (global)
bindsym $mod+Shift+g mode "$mode_gaps"
mode "$mode_gaps" {
bindsym o mode "$mode_gaps_outer"
bindsym i mode "$mode_gaps_inner"
bindsym h mode "$mode_gaps_horiz"
bindsym v mode "$mode_gaps_verti"
bindsym t mode "$mode_gaps_top"
bindsym r mode "$mode_gaps_right"
bindsym b mode "$mode_gaps_bottom"
bindsym l mode "$mode_gaps_left"
bindsym Return mode "$mode_gaps"
bindsym Escape mode "default"
mode "$mode_gaps_outer" {
bindsym plus gaps outer current plus 5
bindsym minus gaps outer current minus 5
bindsym 0 gaps outer current set 0
bindsym Shift+plus gaps outer all plus 5
bindsym Shift+minus gaps outer all minus 5
bindsym Shift+0 gaps outer all set 0
mode "$mode_gaps_inner" {
bindsym plus gaps inner current plus 5
bindsym minus gaps inner current minus 5
bindsym 0 gaps inner current set 0
bindsym Shift+plus gaps inner all plus 5
bindsym Shift+minus gaps inner all minus 5
bindsym Shift+0 gaps inner all set 0
mode "$mode_gaps_horiz" {
bindsym plus gaps horizontal current plus 5
bindsym minus gaps horizontal current minus 5
bindsym 0 gaps horizontal current set 0
bindsym Shift+plus gaps horizontal all plus 5
bindsym Shift+minus gaps horizontal all minus 5
bindsym Shift+0 gaps horizontal all set 0
mode "$mode_gaps_verti" {
bindsym plus gaps vertical current plus 5
bindsym minus gaps vertical current minus 5
bindsym 0 gaps vertical current set 0
bindsym Shift+plus gaps vertical all plus 5
bindsym Shift+minus gaps vertical all minus 5
bindsym Shift+0 gaps vertical all set 0
mode "$mode_gaps_top" {
bindsym plus gaps top current plus 5
bindsym minus gaps top current minus 5
bindsym 0 gaps top current set 0
bindsym Shift+plus gaps top all plus 5
bindsym Shift+minus gaps top all minus 5
bindsym Shift+0 gaps top all set 0
mode "$mode_gaps_right" {
bindsym plus gaps right current plus 5
bindsym minus gaps right current minus 5
bindsym 0 gaps right current set 0
bindsym Shift+plus gaps right all plus 5
bindsym Shift+minus gaps right all minus 5
bindsym Shift+0 gaps right all set 0
mode "$mode_gaps_bottom" {
bindsym plus gaps bottom current plus 5
bindsym minus gaps bottom current minus 5
bindsym 0 gaps bottom current set 0
bindsym Shift+plus gaps bottom all plus 5
bindsym Shift+minus gaps bottom all minus 5
bindsym Shift+0 gaps bottom all set 0
mode "$mode_gaps_left" {
bindsym plus gaps left current plus 5
bindsym minus gaps left current minus 5
bindsym 0 gaps left current set 0
bindsym Shift+plus gaps left all plus 5
bindsym Shift+minus gaps left all minus 5
bindsym Shift+0 gaps left all set 0
I like the control it give but others no need /want it , so i add ( i know it make config insane )
like i say " keep it simple " let new user add if they need
I agree totally with keeping it unbloated, but do not see how gaps are related to font and icon sizing.
Enabling readability is a vital function.
When I install and run i3wm on my high dpi screen I cannot read a single word. I need to put screen 2mm in front of my eye or use a handlense to read the config file and try to edit it makes sense?
the issue is more to use xpyinfo to detect if it is a hidpi display and then sed config to the right font size and theme option inside config text files or via command (for gtk theme)
// i do think about getting more hardware detected automatic for all different stuff currently
@anon75994754 , you sure love those gaps.
Only thing that I don’t see there is a reset to some default value. For example I have this in my config as a “startup condition”.
# Set inner/outer gaps
gaps inner 12
gaps outer -8
And for a reset command.
# reset gaps
bindsym $mod+Ctrl+g gaps inner all set 12; gaps outer all set -8
There is also exec_always which runs the script every time you restart i3 - not so practical for mounting drives, more useful for example for restarting graphic features like picom.
Also there is alway systemd.mount if you want to go fancy. It can for example make sure that the network is up before it tries to mount a network drive.
Just a quick note. Does anyone else have problems with i3 lock with this ISO? As in you select lock from rofi and it does nothing (spinning cursor)?
Second. In the past two days when updating i am receiving permission warnings about the file /etc/sudoers.d/ I have not made any changes to the install save some theming. The last one was about an hour ago when sudo got an update.
