If I change the wallpaper, the layout or change to slideshow etc. these are not saved.
Log: http://ix.io/3qcL
Have you tried:
sudo chown username:username ~ -R
Where username is your user name.
As posted in this thread:
https://forum.endeavouros.com/t/logout-from-kde-resets-desktop-to-default/14896
by onyxnz
Interesting idea, but unfortunately it’s not working.
Is this an installed system or the live environment?
What is not working? sudo chown
I’m surprised this works given the normal usage:
Usage: chown [OPTION]... [OWNER][:[GROUP]] FILE...
I’d probably write it as
sudo chown -R $USER: $HOME
just to make it explicit and not reliant on shell-specific expansions (e.g. ~
installed
the command does not result in me being able to save my wallpaper in a way that it is still present after a reboot.
this doesn’t work, either. (the command doesn’t give me errors, but the wallpaper is not saved)
Problem was fixed with an update. I accidentally switched my wallpaper and it stayed. Everything is working fine now.
