Deepin features
Interesting Deepin features…
You can, if using multiple kernels, select the default boot option in control center>general.
Screen Capture_20200626182728
You can also chose to remove the grub delay timer as well as the theme.
Deepin has some interesting keybindings, for example F11
It can full screen your terminal and your browser (I use chromium, it also works on firefox)
Screen Capture_20200626191044
Screen Capture_20200626190429
in I3wm I can do same thing :wink: long, long time :smiley: xfce4terminal and firefox :slight_smile:
I like the default selection of wallpapers and screensavers that can be accessed by right-clicking on the desktop and that a different wallpaper can be set for every workspace (the whole 2 of them :smile:).
I only discovered it at all after you posted a workaround for the dock issues…
I’ve been using the Boot Menu, but didn’t know about F11 shortcut :slight_smile:
They have updated quake terminal. Previously you could not resize the window. This is possible now by simply using the mouse to drag the bottom of the window. It also remembers how it has been set upon re-Iaunch. I haven’t yet tried to see if it can be bound to a hotkey and used as a drop down similar to yakuake.
I’ve been always using it as a drop-down terminal and it still works :slight_smile: Doesn’t seem to be resizable though… Unless I missed something (I’ve been mostly using dwm lately).
It could be my bad. I forgot I installed system settings. That might be why the window is resizeable for me. Nothing broke on my system doing it but ymmv.
Do you mean this?
extra/systemsettings 5.19.2-1 (328.6 KiB 1.1 MiB) [plasma]
    KDE system manager for hardware, software, and workspaces
Yes sorry was on my phone and a pain to do this : systemsettings :laughing: Use at your own risk and it pulls quite alot of dependencies with it. Back on version 15 you needed it to fix a grainyness issue with the panels.
Just 42 little packages :sweat_smile: Unfortunately, it doesn’t seem to work, the quake is still the same (I did reboot :slight_smile:). Deepin is weird, maybe it is just not working for me for whatever reason.
I’ll look a bit later for you when I get home. :wink:
I’m a little stumped. It just works here.
Screen Capture_20200702162917
Hmm…well, not for me. I will be reinstalling the system anyways (with Deepin as DE), maybe it is going to work after that…
It won’t! :disappointed: I’m giving up dealing with some stuff works and other stuff doesn’t.
472uha
@anon53396576
I wish it was like the version 15 which worked no problem. Everything worked and matter of fact even Htop worked. I’m sooooo disappointed. Who works on this for Arch?
@felixonmars he posts on the manjaro forums now. I really think it’s a driver thing on your end since turning off window effects (which is really the kwin compositor) breaks your system. You can also ping a user named @ant over there (not the same as here) he’s very knowledgeable.
The issue, as I understand it, is that the Deepin drops one version and focuses solely on the next. This works fine for them because they are not on a rolling base. Once v15 works, it will always work until they re-base. v15 was archived while they were working on 20.
On Arch, that doesn’t work and eventually felixonmars felt like he had no choice but to switch to 20. However, calling 20 beta software seems fairly generous. There are a lot of bugs and they are still implementing features.
If you want to report bugs, the right place is probably here:
Here is a recent quote from felixonmars on the subject of trying to get v15 running in a maintainable fashion on Arch. For context, it was in response to someone claiming that switching to version 20 was not the Arch way:
Please don’t get Tasia after me. I promise I’ll be good! :innocent:
Deepin is my friend…
:smile:
This can be done as well. I bound the default keyboard shortcut for quake terminal in control center to F12 works just like yakuake behaviour.
@anon53396576
Okay so now i am running Deepin without Windows effects on the latest kernel and updated virtualbox. So far it’s not freezing yet! The minimize feature is also working. Htop still doesn’t launch i guess unless you install Gnome terminal? Multitasking view requires window effect to be on but doesn’t work when it is on and then the minimize doesn’t work properly. So this is better as it’s not freezing!
The other issue is when you open the EndeavourOS log tool you get multiple icons in tray that won’t close.
