None, if we are talking tiling and moving windows on the fly… The best is a wm, and I can highly recommend i3wm as it is relatively easy to learn and come preconfigured in eos and works well with the xfce install as alternative session.
That being said KDE and gnome can be configured to use some sort of tiling.
If you need tilling then KDE can do that by configuring KWin using an extension called Kröhnkite. I think GNOME also has something similar (don’t know not a big NOME user).
But personally, I use XFCE. Yeah, it’s not as polished as the big 2 DE’s when it comes to looks but if one can spend a little bit of time then they can mold it to look like mine or something even better.
If you wish to go with hardcore tilling and keyboard navigation then use a WM. My top 3 are Awesome, spectrwm(I created this but was archived due to me being not that active here), and i3wm.
But as many have stated here DE is totally a personal preference. Just go with the one that works for you and with the one that appeals to you. Resource usage is not a big issue nowadays due to new computers having mammoth amounts of RAM and other needed resources.
Thanks. I am looking for something at least like it is on Windows 11. xD
But yes, I think I will need to try all of them to check .
I used i3 before, even with Xfce
Gnome would be very similar concerning the window overview but I think KDE implemented that too now borrowing from gnome. Both gnome and KDE snap and maximize windows when dragging them to left/right border. If you want to tile more than two windows and have more control I would definitely install krohnkit on kde or on gnome pop shell for tiling windows.
I think AwsomeWM is the easiest out of them all it is almost like a featherweight DE. You don’t need to know lua to configure Awesome there are many config files out there that one can copy or download and use. But anyways best try them all and go with the one you like.
One more thing System76 is also creating a DE called Cosmos (I think). Written in Rust, they are trying to replicate the functions of the GNOME DE without using GNOME and its plugins.
Well, I run QEMU/KVM almost all the time. I just run a script with xrandr. It set’s the resolution every time I boot or log into the OS. I do this with my MX Linux install.
When DE logs me in it sets the resolution without me having to do it manually. Remember to change the command to fit your VM. My monitor is listed as Virtual-1, change it to fit yours. Or you can use arandr to generate the command.
