I got home and I’m not on the Intel iGPU laptop anymore and instead on my AMD dGPU desktop, but now I’m having a different issue with DaVinci Resolve - it now seems to crash (with no error message) whenever it attempts to render text in Fusion.
The error I’m getting when running it from the terminal is [1] 16814 segmentation fault (core dumped) /opt/resolve/bin/resolve, and I’ll paste the contents of ResolveDebug.txt below as well:
ResolveDebug.txt
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:33,761 | Running DaVinci Resolve v19.1.4.0011 (Linux/Clang x86_64)
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:33,761 | BMD_BUILD_UUID be7a4cb2-27a9-4ac0-9889-f9250e5b955c
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:33,761 | BMD_GIT_COMMIT 755196be3de2c6b815963568c83e02811d250cbb
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,761 | Starting GPUDetect 1.2_6-a2
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Done in 41 ms.
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Detected System:
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - OS: Linux EndeavourOS
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - Model: ASUSTeK PRIME X370-A
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - System ID: ec5fbaa491eb4bcb87ede0c358e76127
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - CPU: AMD Ryzen 7 3700X, 16 threads, x86-64
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - RAM: 8.3 GiB used of 31.2 GiB
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Detected 1 GPUs:
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | - "AMD Radeon RX 5700 XT 50th Anniversary" (gpu:58f2b386.180866a3) <- Main Display GPU
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Discrete, 248 MiB used of 8.0 GiB VRAM, PCI:12:0.0
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Matches: OpenCL, XOrg
0x7a8fc523b000 | GPUDetect | INFO | 2025-05-05 15:00:33,803 | Detected 1 monitors:
0x7a8fc523b000 | Main.GPUConfig | INFO | 2025-05-05 15:00:33,804 | Compute API set to automatic, defaulting to OpenCL.
0x7a8fc523b000 | Main.GPUConfig | INFO | 2025-05-05 15:00:33,804 | Selected compute API: OpenCL
0x7a8fc523b000 | Main.GPUConfig | INFO | 2025-05-05 15:00:33,804 | Automatic GPU Selection:
0x7a8fc523b000 | Main.GPUConfig | INFO | 2025-05-05 15:00:33,804 | - "AMD Radeon RX 5700 XT 50th Anniversary" (gpu:58f2b386.180866a3)
0x7a8fc523b000 | IO | INFO | 2025-05-05 15:00:33,804 | RED InitializeSdk with library path at /opt/resolve/libs
0x7a8fc523b000 | IO | INFO | 2025-05-05 15:00:33,836 | R3DAPI 8.5.1-53601 (20240308 Lx64S) R3DSDK 8.5.1-53601 (20240308 Lx64D C3B1) RED OPENCL 8.5.1-53598 (20240308) [/opt/resolve/libs/] init is successful
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:33,836 | 0 RED rocket cards available
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:33,836 | Decklink model name: '', version: ''
0x7a8fc523b000 | DVIP | INFO | 2025-05-05 15:00:33,836 | DVIP release/19.1.4 build 4 (0b70832d74dda2ba4124989ece4ec149296504f0). Release, version 19.1.4.
0x7a8e779ee000 | IO | INFO | 2025-05-05 15:00:33,925 | Using DNxHR library v2.7.5.873r
0x7a8e71bfe000 | SyManager | ERROR | 2025-05-05 15:00:33,926 | GetProjectLibraries() - Access token is empty
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
0x7a8e781ef000 | Fusion | INFO | 2025-05-05 15:00:34,017 | Fusion Build: 716d4ba8_0006 (Mar 18 2025 12:31:01)
0x7a8e693fd000 | Fusion | INFO | 2025-05-05 15:00:34,022 | fusionsystem: = "/opt/resolve/libs/Fusion/libfusionsystem.so"
0x7a8e779ee000 | IO | ERROR | 2025-05-05 15:00:34,023 | Error initializing ArriImageSdk Some requested platforms could not be loaded. See log for details.
0x7a8e779ee000 | IO | INFO | 2025-05-05 15:00:34,023 | IO codec library load completed in 98 ms.
0x7a8e693fd000 | Fusion | INFO | 2025-05-05 15:00:34,026 | FusionLibs: = "/opt/resolve/libs/Fusion/"
0x7a8e693fd000 | Fusion | INFO | 2025-05-05 15:00:34,026 | UserData: = "/home/hazelnot/.local/share/DaVinciResolve/Fusion"
0x7a8e693fd000 | Fusion | INFO | 2025-05-05 15:00:34,026 | Profiles: = "UserData:Profiles/"
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:34,052 | UI language is set to "Auto", and system language is "en".
Attribute Qt::AA_ShareOpenGLContexts must be set before QCoreApplication is created.
0x7a8e5b3e4000 | DbCommon2 | INFO | 2025-05-05 15:00:34,052 | Loading dblist file: /home/hazelnot/.local/share/DaVinciResolve/configs/.dblist
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,085 | Finished loading Application style sheet
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,097 | Show splash screen
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,097 | Show splash screen message: Starting Up
0x7a8fc523b000 | UI.GLContext | INFO | 2025-05-05 15:00:34,173 | Creating shared OpenGL context for this thread (1 total).
0x7a8fc523b000 | UI.GLContext | INFO | 2025-05-05 15:00:34,175 | Initialized OpenGL 4.6 (requested 4.5) on device 'AMD AMD Radeon RX 5700 XT 50th Anniversary (radeonsi, navi10, LLVM 19.1.7, DRM 3.61, 6.14.4-arch1-2)'
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,175 | Local SysId:88D7F6C3D558 Hostname:silent-cartographer Timezone:Europe/Bucharest UTC+0300
0x7a8fc523b000 | BtCommon | INFO | 2025-05-05 15:00:34,179 | Memory config: reserved=6239M pinned=4000M log=0
0x7a8e431f9000 | LeManager | INFO | 2025-05-05 15:00:34,179 | 521, 29
0x7a8fc523b000 | BtCommon | INFO | 2025-05-05 15:00:34,179 | Using default pooled memory manager
0x7a8e42703000 | BtCommon | INFO | 2025-05-05 15:00:34,179 | BtResourceManager Process Thread Started
0x7a8fc523b000 | SyManager | INFO | 2025-05-05 15:00:34,183 | Total: 20, NumDtThreads: 8, NumComms: 0, NumSites: 1
0x7a8fc523b000 | SyManager | INFO | 2025-05-05 15:00:34,183 | Lookaheads -> playback = 20, record = 20, stop = 2
Sy High Command Handler Thread ----- (134751381921792)
SY high priority cmd handler thread starts: 4040A000
Sy Low Command Handler Thread ----- (134751373529088)
SY low priority cmd handler thread starts: 3FC09000
Sy Data Handler Thread ----- (134751365136384)
SY data handler thread starts: 3F408000
Gs High Command Handler Thread ----- (134751348350976)
GS high priority cmd handler thread starts: 3E406000
Gs Low Command Handler Thread ----- (134751339958272)
GS low priority cmd handler thread starts: 3DC05000
0x7a8e3d404000 | GsManager | INFO | 2025-05-05 15:00:34,184 | Gs Processor Thread ----- (134751331565568)
GS processor thread starts: 3D404000
Dp High Command Handler Thread ----- (134751323172864)
DP high priority cmd handler thread starts: 3CC03000
Dp Low Command Handler Thread ----- (134751314780160)
DP low priority cmd handler thread starts: 3C402000
Dt High Command Handler Thread ----- (134751306387456)
DT high priority cmd handler thhread starts: 3BC01000
Dt Low Command Handler Thread ----- (134751297994752)
DT low priority cmd handler thread starts: 3B400000
0x7a8fc523b000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Using 8 generic IO threads
0x7a8e3abff000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Dt Data Handler Thread Started
DT data handler thread starts: 3ABFF000
0x7a8fc523b000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Total of 16 IO threads (including 8 generic and 8 Red decode threads)
0x7a8e3a3fe000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Dt Worker Thread Started
0x7a8e39bfd000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Dt Worker Thread Started
0x7a8e393fc000 | DtManager | INFO | 2025-05-05 15:00:34,184 | Dt Worker Thread Started
0x7a8e38bfb000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e383fa000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e37bf9000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e373f8000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e36bf7000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e363f6000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e35bf5000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e353f4000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e34bf3000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e343f2000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e33bf1000 | DtManager | INFO | 2025-05-05 15:00:34,185 | Dt Worker Thread Started
0x7a8e333f0000 | DtManager | INFO | 2025-05-05 15:00:34,186 | Dt Worker Thread Started
0x7a8e32bef000 | DtManager | INFO | 2025-05-05 15:00:34,186 | Dt Worker Thread Started
0x7a8e323ee000 | DtManager | INFO | 2025-05-05 15:00:34,186 | Dt Worker Thread Started
0x7a8e31bed000 | DtManager | INFO | 2025-05-05 15:00:34,186 | Dt Worker Thread Started
Ls High Command Handler Thread ----- (134751130140672)
Ls Low Command Handler Thread ----- (134751121747968)
LS low priority cmd handler thread starts: 30BEB000
Ls Data Handler Thread ----- (134751113355264)
LS data handler thread starts: 303EA000
Ls High Command Handler Thread ----- (134751104962560)
Ls Low Command Handler Thread ----- (134751096569856)
LS low priority cmd handler thread starts: 2F3E8000
Ls Data Handler Thread ----- (134751088177152)
LS data handler thread starts: 2EBE7000
Ls High Command Handler Thread ----- (134751079784448)
Ls Low Command Handler Thread ----- (134751071391744)
LS low priority cmd handler thread starts: 2DBE5000
Ls Data Handler Thread ----- (134751062999040)
Mem Data Transmitter Thread ----- (134751054606336)
Mem data transmitter thread starts: 2CBE3000
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,187 | Show splash screen message: Loading Project Libraries
0x7a8e2d3e4000 | GPU.MultiBoardMgr | INFO | 2025-05-05 15:00:34,189 | Let There Be OpenCL Light!
0x7a8e2d3e4000 | GPU.MultiBoardMgr | INFO | 2025-05-05 15:00:34,189 | Initializing OpenCL board manager for Main Display GPU gpu:58f2b386.180866a3.
0x7a8e2bbe1000 | UI.GLContext | INFO | 2025-05-05 15:00:34,189 | Creating shared OpenGL context for this thread (2 total).
sh: line 1: python2: command not found
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,223 | Show splash screen message: Initializing system components
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,225 | Show splash screen message: Loading video codecs
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,229 | Show splash screen message: Loading video plugins
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:34,229 | Show splash screen message: Loading Fairlight Engine
0x7a8e2bbe1000 | DVIP | INFO | 2025-05-05 15:00:34,785 | Created OpenCL context for devices gpu:58f2b386.180866a3
0x7a8e779ee000 | IO | INFO | 2025-05-05 15:00:34,794 | IO codec initialization completed in 565 ms.
Unable to read VR Path Registry from /home/hazelnot/.config/openvr/openvrpaths.vrpath
0x7a8fc523b000 | BtCommon | ERROR | 2025-05-05 15:00:34,922 | mkdir failed for directory '/opt/resolve/Fairlight' (errno 13)
0x7a8e2bbe1000 | DVIP | INFO | 2025-05-05 15:00:35,140 | Opened cache "/home/hazelnot/.local/share/DaVinciResolve/DVIP/Cache/OpenCL.cache", version 2 is current. Total size 0.4 MiB.
0x7a8fc523b000 | BtCommon | ERROR | 2025-05-05 15:00:35,152 | mkdir failed for directory '/opt/resolve/Fairlight' (errno 13)
0x7a8e2bbe1000 | GPU.SingleBoardMgr | INFO | 2025-05-05 15:00:35,153 | Board manager thread for "AMD Radeon RX 5700 XT 50th Anniversary" (gpu:58f2b386.180866a3) is ready.
0x7a8e2d3e4000 | UI.GLInterop | INFO | 2025-05-05 15:00:35,153 | OpenGL interop was initialized.
0x7a8da96d9000 | DVIP | INFO | 2025-05-05 15:00:35,153 | Re-using OpenCL context for devices gpu:58f2b386.180866a3
LS data handler thread starts: 2D3E4000
0x7a8fc523b000 | BtCommon | ERROR | 2025-05-05 15:00:35,244 | mkdir failed for directory '/opt/resolve/Fairlight' (errno 13)
0x7a8fc523b000 | Fairlight | INFO | 2025-05-05 15:00:35,254 | 00.00.00.464(000): Running Fairlight (ad73dcd41e8bc871d6ab38a49e2245c5bbee795b)
0x7a8fc523b000 | FairlightLoader | INFO | 2025-05-05 15:00:35,254 | Fairlight lib initialized in 1024 ms.
0x7a8e781ef000 | UI.GLContext | INFO | 2025-05-05 15:00:35,255 | Creating shared OpenGL context for this thread (3 total).
0x7a8e781ef000 | DVIP | INFO | 2025-05-05 15:00:35,257 | Re-using OpenCL context for devices gpu:58f2b386.180866a3
0x7a8e781ef000 | UI.GLIO | INFO | 2025-05-05 15:00:35,259 | Initialized MainPlayer OpenGL I/O on OpenCL device 'gfx1010:xnack-'
0x7a8fc523b000 | UI.GLIO | INFO | 2025-05-05 15:00:35,259 | MainPlayer: OpenGL I/O setup done.
0x7a8d8b9ff000 | UI.GLContext | INFO | 2025-05-05 15:00:35,259 | Creating shared OpenGL context for this thread (4 total).
0x7a8d8b9ff000 | DVIP | INFO | 2025-05-05 15:00:35,261 | Re-using OpenCL context for devices gpu:58f2b386.180866a3
0x7a8d8b9ff000 | UI.GLIO | INFO | 2025-05-05 15:00:35,263 | Initialized AuxPlayer OpenGL I/O on OpenCL device 'gfx1010:xnack-'
0x7a8fc523b000 | UI.GLIO | INFO | 2025-05-05 15:00:35,263 | AuxPlayer: OpenGL I/O setup done.
0x7a8d893ff000 | UI.GLContext | INFO | 2025-05-05 15:00:35,263 | Creating shared OpenGL context for this thread (5 total).
0x7a8d893ff000 | DVIP | INFO | 2025-05-05 15:00:35,266 | Re-using OpenCL context for devices gpu:58f2b386.180866a3
0x7a8d893ff000 | UI.Scopes | INFO | 2025-05-05 15:00:35,267 | Initialized GPU Scopes Manager on OpenCL device 'gfx1010:xnack-'
libScannerAPI.so: cannot open shared object file: No such file or directory
0x7a8fc523b000 | UI.MenuBar | WARN | 2025-05-05 15:00:35,358 | Main menu action [workspaceLayoutFusion_sub001Default]'s slot is not defined: workspaceLayoutFusion_sub001Default_triggered()
0x7a8fc523b000 | FusionUtils | WARN | 2025-05-05 15:00:35,369 | Fusion DoAction ACTION_SET_FUSION_HOTKEY ignored, init not completed
0x7a8d85ffe000 | SyManager | ERROR | 2025-05-05 15:00:35,370 | Failed to connect to panel socket
0x7a8d85ffe000 | SyManager | ERROR | 2025-05-05 15:00:35,370 | DRIVER: open /var/tmp/davinci_socket failed
SY panel handler thread starts: 85FFE000
0x7a8d847fb000 | SyManager | INFO | 2025-05-05 15:00:35,375 | Starting keyboard device monitor thread...
Opening communication to resolve..
*** CreateListenSocketUDS[200]: Failed to set SO_REUSEPORT
Failed to create listener
Unsupported DaVinci Panel API Version (0.0), please update
0x7a8fc523b000 | UI | WARN | 2025-05-05 15:00:35,379 | Text default font [Open Sans] is not available in font database.
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:35,391 | Show splash screen message: Loading Project Settings
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:35,985 | Show splash screen message: Loading Media Page
0x7a8e2c3e2000 | Fusion | INFO | 2025-05-05 15:00:35,992 | 347 templates scanned in 0.11 secs
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:36,023 | Action [fairlightImmersiveAmbisonicsMetering] is not a global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:36,024 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:36,024 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:36,024 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:36,024 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | UI.FairlightInterface | WARN | 2025-05-05 15:00:36,105 | SetActionEnabled: Failed to find action [viewTimelineScrollingFixed]'s action connector for handler Id [1]
Unknown property letter-spacing
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:36,232 | Show splash screen message: Loading Cut Page
0x7a8fc523b000 | UI.SpeedTimeline | INFO | 2025-05-05 15:00:36,301 | Replay UI is enabled.
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:36,424 | OFX - plugin not supported on this platform, is being skipped
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:36,448 | Show splash screen message: Loading Edit Page
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:36,635 | OFX - plugin not supported on this platform, is being skipped
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:36,642 | Show splash screen message: Loading Fusion Page
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:36,690 | Show splash screen message: Loading Fairlight Page
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:36,823 | Show splash screen message: Loading Color Page
libpng warning: iCCP: known incorrect sRGB profile
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:36,922 | OFX - plugin not supported on this platform, is being skipped
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:38,018 | Show splash screen message: Loading Waveform Monitor
0x7a8d85ffe000 | SyManager | ERROR | 2025-05-05 15:00:38,080 | Failed to connect to panel socket
****************** Flushing GPU Buffers
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:38,251 | Show splash screen message: Loading Audio Plugins
0x7a8fc523b000 | SyManager | INFO | 2025-05-05 15:00:38,314 | Collaboration IP Port 0
0x7a8fc523b000 | DbCommon2 | INFO | 2025-05-05 15:00:38,314 | Sm2SysIdEntry is not supported in local project library (xml) mode
0x7a8fc523b000 | SyManager | ERROR | 2025-05-05 15:00:38,314 | Failed to parse key (SkipVersion) from JsonObject
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:38,320 | Show splash screen message: Loading Projects
QFont::fromString: Invalid description 'Inter,11,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
QFont::fromString: Invalid description 'SF Mono,12,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:38,334 | Current user pointer is changed
0x7a8fc523b000 | IO | INFO | 2025-05-05 15:00:38,366 | RED rocket decode has been disabled in the config file
0x7a8fc523b000 | BtCommon | ERROR | 2025-05-05 15:00:38,712 | mkdir failed for directory '/opt/resolve/Fairlight' (errno 13)
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,848 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,848 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,848 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,848 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,854 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,854 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,854 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,854 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,857 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,857 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,857 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,857 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,890 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,890 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,890 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:38,890 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | SyManager.Gallery | INFO | 2025-05-05 15:00:38,991 | Start purging still caches
0x7a8fc523b000 | SyManager.Gallery | INFO | 2025-05-05 15:00:38,991 | Finish purging still caches
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:39,029 | Media pool relink status changed to 0
0x7a8fc523b000 | FusionUtils | WARN | 2025-05-05 15:00:39,039 | Fusion DoAction ACTION_SET_FUSION_HOTKEY ignored, init not completed
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:39,051 | Launching project manager
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:39,058 | Main view page is changed to 12
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:39,074 | Show splash screen message: Ready
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:39,077 | Gallery pointer is changed, refreshing color gallery
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:39,082 | Gallery pointer is changed, refreshing gallery browser
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:39,135 | Close splash screen
0x7a8fc523b000 | Main | INFO | 2025-05-05 15:00:39,136 | Launching main loop
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:39,413 | Fusion templates changed
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:43,469 | Start deleting project Untitled Project 2025-05-05_150008
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/hazelnot/Videos/Resolve Project Backups/c9626f70-23f8-4702-bd77-adf9d3dfe958'
### DEL_DBG IOFileSys::DeletePath[1505] p_OSErrCode = 0, p_ErrMsg =
0x7a8fc523b000 | SyManager | WARN | 2025-05-05 15:00:43,482 | No reply received from file system, assume successfully deleted folder /home/hazelnot/Videos/Resolve Project Backups/c9626f70-23f8-4702-bd77-adf9d3dfe958.
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/hazelnot/Videos/CacheClip/c9626f70-23f8-4702-bd77-adf9d3dfe958'
0x7a8fc523b000 | SyManager | WARN | 2025-05-05 15:00:43,492 | No reply received from file system, assume successfully deleted folder /home/hazelnot/Videos/CacheClip/c9626f70-23f8-4702-bd77-adf9d3dfe958.
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/hazelnot/Videos/.gallery/c9626f70-23f8-4702-bd77-adf9d3dfe958'
0x7a8fc523b000 | SyManager | WARN | 2025-05-05 15:00:43,502 | No reply received from file system, assume successfully deleted folder /home/hazelnot/Videos/.gallery/c9626f70-23f8-4702-bd77-adf9d3dfe958.
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:43,502 | Deleting project took 34 ms
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:44,250 | Main view page is changed to 1
0x7a8fc523b000 | UI | WARN | 2025-05-05 15:00:44,250 | Failed to get auto update information.
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:44,284 | Main view page is changed to 17
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:44,360 | Main view page is changed to 17
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:44,363 | Launching main window
0x7a8d435e1000 | Fusion | INFO | 2025-05-05 15:00:46,573 | Started FusionAudio Worker thread
0x7a8fc523b000 | UI.FusionPanel | INFO | 2025-05-05 15:00:46,640 | Widget [MEDIAPOOL] is not created by Fusion, does not need to return widget.
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:46,722 | Main view page is changed to 16
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:46,852 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:46,852 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:50,272 | Current timeline pointer (Timeline 1) is changed
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,280 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,280 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,280 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,280 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8e2bbe1000 | GPU.SingleBoardMgr | INFO | 2025-05-05 15:00:50,341 | Flushing GPU memory...
0x7a8e2bbe1000 | UI.GLTexPool | INFO | 2025-05-05 15:00:50,341 | Released 0 MiB in 0 unused textures.
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,377 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,377 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,377 | Action [fairlightImmersiveEditADMScene] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,377 | Action [fairlightImmersiveAmbisonicsMetering] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,419 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:50,419 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:50,472 | Start saving project Untitled Project 2025-05-05_150050
0x7a8fc523b000 | DbCommon2 | INFO | 2025-05-05 15:00:50,472 | Initializing fresh project library /home/hazelnot/.local/share/DaVinciResolve/Resolve Project Library/Resolve Projects/Users/guest/Projects/Untitled Project 2025-05-05_150050/Project.db @ Local Database
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:51,147 | Saving project took 675 ms
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:51,147 | Current project pointer changed to (Untitled Project 2025-05-05_150050) from DB (Local Database : Local)
0x7a8fc523b000 | SyManager.Signals | INFO | 2025-05-05 15:00:51,147 | Current timeline pointer (Timeline 1) is changed
0x7a8fc523b000 | SyManager | INFO | 2025-05-05 15:00:51,155 | 'Timeline 1' timeline backup is created in 1 ms.
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:51,161 | Start saving project Untitled Project 2025-05-05_150050
0x7a8e3f408000 | SyManager.ActionExecutor | INFO | 2025-05-05 15:00:51,164 | Database transaction is ongoing, user initiated action SmActIOCPSigInvoker is postponed
0x7a8e3f408000 | SyManager.ActionExecutor | INFO | 2025-05-05 15:00:51,167 | Database transaction is ongoing, user initiated action SmActIOCPSigInvoker is postponed
0x7a8fc523b000 | SyManager.ActionExecutor | INFO | 2025-05-05 15:00:51,169 | Database transaction completed, enqueueing 2 postponed actions
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:51,169 | Saving project took 8 ms
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:51,261 | Gallery pointer is changed, refreshing color gallery
0x7a8fc523b000 | UI | INFO | 2025-05-05 15:00:51,270 | Gallery pointer is changed, refreshing gallery browser
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:51,271 | Start saving project Untitled Project 2025-05-05_150050
0x7a8fc523b000 | SyManager.ProjectManager | INFO | 2025-05-05 15:00:51,277 | Saving project took 6 ms
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:51,419 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:51,419 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:53,517 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:53,517 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:54,453 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:54,453 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI | WARN | 2025-05-05 15:00:54,542 | CC thumbnail buffer: TIME out
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:55,716 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:55,716 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,550 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,550 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,846 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,846 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,917 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:57,917 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:58,997 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:58,997 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:59,065 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:00:59,065 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,060 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,061 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,114 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,114 | Action owner [FusionWidget] is not active when refreshing shortcut [editCopy] due to [No focused widget is set yet]
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,114 | Action owner [FusionWidget] is not active when refreshing shortcut [editPaste] due to [No focused widget is set yet]
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,114 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:00,114 | Action owner [FusionWidget] is not active when refreshing shortcut [editSelectAll] due to [No focused widget is set yet]
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:02,179 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:02,179 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:02,498 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:02,498 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:06,530 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:06,530 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:07,351 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:07,351 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:07,559 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:07,559 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:10,494 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:10,494 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:11,480 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:11,480 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:11,971 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:11,971 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:15,601 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:15,601 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:15,661 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:15,661 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:16,142 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:16,142 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:18,877 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:18,877 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:18,935 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:18,935 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:23,593 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:23,593 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:23,648 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:23,648 | Action [editBackspace] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:25,740 | Action [editCut] is not a valid global action
0x7a8fc523b000 | UI.ActionManager | WARN | 2025-05-05 15:01:25,740 | Action [editBackspace] is not a valid global action
