Darktable won't start
darktable cannot be started, it displays the following error:
darktable-cltest
     0.0370 [dt_get_sysresource_level] switched to 1 as `default'
     0.0370   total mem:       32017MB
     0.0370   mipmap cache:    4002MB
     0.0370   available mem:   16008MB
     0.0370   singlebuff:      250MB
     0.0370   OpenCL tune mem: OFF
     0.0370   OpenCL pinned:   OFF
[opencl_init] opencl related configuration options:
[opencl_init] opencl: ON
[opencl_init] opencl_scheduling_profile: 'default'
[opencl_init] opencl_library: 'default path'
[opencl_init] opencl_device_priority: '*/!0,*/*/*/!0,*'
[opencl_init] opencl_mandatory_timeout: 400
[opencl_init] opencl library 'libOpenCL' found on your system and loaded
[opencl_init] found 2 platforms
[opencl_init] found 2 devices
[dt_opencl_device_init]
   DEVICE:                   0: 'cpu-AMD Ryzen 5 2600X Six-Core Processor'
   PLATFORM NAME & VENDOR:   Portable Computing Language, The pocl project
   CANONICAL NAME:           portablecomputinglanguagecpuamdryzen52600xsixcoreprocessor
   DRIVER VERSION:           4.0
   DEVICE VERSION:           OpenCL 3.0 PoCL HSTR: cpu-x86_64-pc-linux-gnu-znver1
   DEVICE_TYPE:              CPU
   GLOBAL MEM SIZE:          29969 MB
   MAX MEM ALLOC:            8192 MB
   MAX IMAGE SIZE:           16384 x 16384
   MAX WORK GROUP SIZE:      4096
   MAX WORK ITEM DIMENSIONS: 3
   MAX WORK ITEM SIZES:      [ 4096 4096 4096 ]
   ASYNC PIXELPIPE:          NO
   PINNED MEMORY TRANSFER:   NO
   MEMORY TUNING:            NO
   FORCED HEADROOM:          400
   AVOID ATOMICS:            NO
   MICRO NAP:                1000
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   CHECK EVENT HANDLES:      128
   TILING ADVANTAGE:         0.000
   DEFAULT DEVICE:           NO
   *** marked as disabled ***
   DEVICE:                   1: 'gfx1031'
   PLATFORM NAME & VENDOR:   AMD Accelerated Parallel Processing, Advanced Micro Devices, Inc.
   CANONICAL NAME:           amdacceleratedparallelprocessinggfx1031
   DRIVER VERSION:           3570.0 (HSA1.1,LC)
   DEVICE VERSION:           OpenCL 2.0
   DEVICE_TYPE:              GPU
   GLOBAL MEM SIZE:          12272 MB
   MAX MEM ALLOC:            10431 MB
   MAX WORK GROUP SIZE:      256
   MAX WORK ITEM SIZES:      [ 1024 1024 1024 ]
   ASYNC PIXELPIPE:          NO
   MEMORY TUNING:            NO
   AVOID ATOMICS:            NO
   MICRO NAP:                250
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   DEFAULT DEVICE:           NO
   KERNEL BUILD DIRECTORY:   /usr/share/darktable/kernels
   KERNEL DIRECTORY:         /home/xbox/.cache/darktable/cached_v1_kernels_for_AMDAcceleratedParallelProcessinggfx1031_35700HSA11LC
   CL COMPILER OPTION:       -cl-fast-relaxed-math
PHI node has multiple entries for the same basic block with different incoming values!
  %967 = phi float [ %largephi.extractslice0, %sw.default ], [ %largephi.extractslice055, %sw.bb667 ], [ %largephi.extractslice059, %sw.bb663 ], [ %largephi.extractslice063, %sw.bb659 ], [ %largephi.e
xtractslice067, %sw.bb655 ], [ %largephi.extractslice071, %sw.bb646 ], [ %largephi.extractslice075, %_Z4fmodff.exit16 ], [ %largephi.extractslice079, %_Z4fmodff.exit13 ], [ %largephi.extractslice083,
%_Z4fmodff.exit ], [ %largephi.extractslice087, %sw.bb562 ], [ %largephi.extractslice091, %sw.bb555 ], [ %largephi.extractslice095, %sw.bb533 ], [ %largephi.extractslice099, %if.then502 ], [ %largephi
.extractslice0103, %if.else517 ], [ %largephi.extractslice0107, %if.then456 ], [ %largephi.extractslice0111, %if.else471 ], [ %largephi.extractslice0115, %if.then393 ], [ %largephi.extractslice0119, %
if.else408 ], [ %largephi.extractslice0123, %if.then338 ], [ %largephi.extractslice0127, %if.else353 ], [ %largephi.extractslice0131, %if.then283 ], [ %largephi.extractslice0135, %if.else298 ], [ %lar
gephi.extractslice0139, %if.then224 ], [ %largephi.extractslice0143, %if.else241 ], [ %largephi.extractslice0147, %sw.bb193 ], [ %largephi.extractslice0151, %sw.bb180 ], [ %largephi.extractslice0155,
%sw.bb168 ], [ %largephi.extractslice0159, %sw.bb158 ], [ %largephi.extractslice0163, %sw.bb147 ], [ %largephi.extractslice0167, %if.then116 ], [ %largephi.extractslice0171, %if.else131 ], [ %largephi
.extractslice0175, %sw.bb71 ], [ %largephi.extractslice0179, %sw.bb ], [ %largephi.extractslice0183, %if.end ], [ %largephi.extractslice0187, %if.end ], [ %largephi.extractslice0191, %if.end ], [ %lar
gephi.extractslice0195, %if.end ], [ %largephi.extractslice0199, %if.end ]
label %if.end
  %largephi.extractslice0199 = extractelement <4 x float> %div, i64 0
  %largephi.extractslice0187 = extractelement <4 x float> %div, i64 0
in function blendop_Lab
LLVM ERROR: Broken function found, compilation aborted!
[1]    11805 IOT instruction (core dumped)  darktable-cltest
My opencl installation is working fine opencl based programs are working like davinci resolve
Does anyone know how to deal with this problem?
Start it from terminal and share output, let’s see where it fails.
The error is as follows
 darktable
label %if.end
[1]    25638 IOT instruction (core dumped)  darktable
I assume darktable is running fine (it does not need opencl). What you are showing is an error with the opencl test command darktable-cltest
What exactly have you installed? I have this:
ocl-icd 2.3.2-1
opencl-amd 1:5.6.0-2
darktable 2:4.4.2-1
I’m in the same boat as you, but my opencl driver installation is opencl-clover-mesa
I bet this is your issue. Similar to this darktable issue
I suppose it’s possible, but I’ve seen on other forums that darktable has had similar problems with llvm recently. I’m working on a solution. I was keys working fine before, I don’t know when since I updated my system I can’t open it anymore
I can’t uninstall AMD rocm because blender and davinci resolve, both rely on it and have used it before without any problems.
