hello ![]()
I’m trying to understand the differences between the Daemons to perform CPU power scaling and if there is a recommended choice.
power-profiles-daemon, TLP, tuned
I do not know which one to choose, have you some recommendations?
That would depend on your hardware.
For AMD CPUs, which are at least of the Zen2 architecture, they would be supported by the AMD pstate driver.
thanks ![]()
laptop with AMD CPU
so in your opinion I do not need to install TLP or tuned?
The AMD pstate driver works totally fine in combination with the power profiles daemon.
thanks, I try with this
see theses topics
